Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 05-15-2012, 11:52 PM   #1
shemoves
Member#: 80663
2005 STi
Default Diag drivetrain issue
The front binds during sharp turns. I can feel it in the car/steering wheel. This is a '99 Legacy.
shemoves is offline   Reply With Quote
Old 05-16-2012, 12:15 AM   #2
Evil Imports
Member#: 14732
+ 13 B8
i will say its the center diff
Evil Imports is offline   Reply With Quote
Old 05-16-2012, 02:48 AM   #3
shemoves
Member#: 80663
2005 STi
Any idea on cost to overhaul or replace? Would it be better to just replace the entire trans? (car has 135k and otherwise feels good for the mileage)
Old 05-16-2012, 09:54 AM   #4
Evil Imports
Member#: 14732
+ 13 B8
Do a search for center diff binding and see if the feeling/noise fit your problem,
http://www.rs25.com/forums/f105/t962...ter-diffs.html
Old 05-16-2012, 01:44 PM   #5
-=Lobstah=-
Member#: 132792
2007 Impreza WRX WG
Auto or manual?
Are tires all the same wear?
-=Lobstah=- is offline   Reply With Quote
Old 05-16-2012, 03:14 PM   #6
JapCarRealGood
Pirates > Your Mom
Member#: 104055
96 RHD555 98RHDSTi
99OBSTi 91NSX 06 9-2xAero
Its most likely an auto.
Its time to buy a used trans.
I've messed around with a fair share of autos..
The price you'd pay to rebuild one,
you could buy 2 used ones.
I could find one for ya,
call me 602-456-1-STi (784)
-DBB
JapCarRealGood is offline   Reply With Quote
Old 05-16-2012, 07:40 PM   #7
Evil Imports
Member#: 14732
+ 13 B8
If its the center diff, I have a wrx center diff in my garage i can sell you
Old 05-17-2012, 09:01 PM   #8
shemoves
Member#: 80663
2005 STi
It's actually a manual, and I would much rather replace it all with a rebuilt unit to start fresh. This is for a car I was thinking of buying so I may just let it go. That said, any idea on the cost for a rebuilt trans that'll bolt up to a '99 Legacy wagon?
Old 05-19-2012, 07:06 PM   #9
bobturismo
Member#: 42145
6-4 jockin da bish-
es and slappin the hoes.
If the trans isn't making noise or having problems, then there is not point in rebuilding it other than having someone check out the internals and replacing anything that needs to be.
Manuals are very simple devices, you have gears on some shafts with bearings and synchros.
If it doesn't have any problem engaging, then the synchros are fine. If you don't hear any whining noises and the fluid isn't abnormally dirty, then the bearings and gears are fine.
If it's the center diff, it's easily swapped without splitting the transmission.
A stock trans on a stock NA motor should last upwards of 500k
bobturismo is offline   Reply With Quote
2002 WRX Drivetrain Issue (Center Diff.) bsbretly Transmission (AT/MT) & Driveline 13 05-06-2012 11:25 PM
Merry Christmas drivetrain issue? foxfireWRX Newbies & FAQs 8 12-25-2009 11:32 PM
clutch/drivetrain issue qwkwrx Transmission (AT/MT) & Driveline 3 01-28-2007 02:28 PM
Somewhat "Unique" drivetrain issues... What should I do? Kostamojen Transmission (AT/MT) & Driveline 10 05-13-2005 11:10 PM
Drivetrain issue. shoracer STi Forum Archive 8 09-02-2003 01:44 AM
