Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 02-04-2012, 09:57 PM   #1
Equilibrium Tuning
Member#: 26933
2006 STI
Default EQ - 2007 STI, EQ Built Block, VF43, EWG, 91 Octane - 290whp!
Here is another engine build we did recently. After the break-in, we installed an EWG UP and tune it. The car made great power for the simple setup.
Event: Custom Tune/Dyno
Ambient Temp: 60 degrees Fahrenheit
Elevation: ~100ft above sea level
Car: 2007 Subaru STI
Tuner: ED @ Equilibrium Tuning
Peak HP at RPM: 290whp @ 5450RPM
Peak Torque at RPM: 314ft-lbs @ 3750RPM
Target Boost: 19psi peak
Fuel: Cali 91 Octane
Engine/Power Modifications:
EQ Tuning Stage 1 Shortblock
EQ Tuning Stage 1 Heads
Catless TBE
TIGWerks EWG UP with Tial 38mm
EQ Tuning Cross-Pipe
Perrin Inlet
AEM CAI
Hallman MBC
Walbro
EQ Custom Tune
I was very happy with the numbers as well as the great power curve. This car maintained a nice flat torque curve and carried peak power really well to redline. I was especially impressed to see these numbers without aftermarket headers!
*** Standard Dyno Chart Disclaimer ***
This dyno reads low and should be compared to the lower reading mustang dynos. Here are some proven numbers and trap speeds for reference:
Stock 02-05 WRX - 155-165whp
Stock 04-07 STI - 210-220whp
Stock 08-11 STI - 195-205whp
265-275whp - 107-108mph traps
300-310whp - 112-113mph traps
325-335whp - 115-116mph traps
-- Ed
Old 02-04-2012, 10:05 PM   #2
KpT KiM
Member#: 242422
Nice. What's involved in your Stage 1 heads?
KpT KiM is offline   Reply With Quote
Old 05-17-2012, 03:57 PM   #3
bue car
Member#: 176134
07' Impreza STi wrb
95 L...
Is there headroom for more? Ill have a bigger ewg, gr tmic, complete headers, and 3.5 inch tbe.
maybe i should start over for more power. I already make 295 whp with just the cobb ots map and tbe...
bue car is offline   Reply With Quote
Old 05-17-2012, 09:17 PM   #4
Equilibrium Tuning
Member#: 26933
2006 STI
Stage 1 heads get a 5/4 angle valve job and decking.
-- Ed
Old 05-17-2012, 09:19 PM   #5
Equilibrium Tuning
Member#: 26933
2006 STI
I guarantee your car would not put down 295whp on the Cobb map on our dyno. It's nearly impossible to hit 300whp on our dyno with the stock turbo on 91 octane
-- Ed
EQ - 2007 STI, EQ Built Block, HTA68, E85 Equilibrium Tuning Proven Power Bragging 35 01-05-2012 06:52 PM
EQ - 2006 STI - FP Red, 91 Octane - 360whp! Equilibrium Tuning Proven Power Bragging 18 12-12-2011 05:15 AM
EQ: 2005 STI, VF39, 91 Octane - 290whp/325ft-lbs! Equilibrium Tuning Proven Power Bragging 0 06-18-2010 04:24 PM
Tuning: 05 STi EQ tuning stage 1 built motor, stock turbo, 91 octane OBrex05 Proven Power Bragging 5 03-18-2010 02:45 AM
EQ Tuning: 04 WRX, EQ Built Engine, ATP3076, 91 Octane - 352whp! Equilibrium Tuning Proven Power Bragging 4 03-17-2010 03:24 PM
