Old 05-14-2012, 10:12 PM   #251
infinite012
Member#: 74392
2015 Forester
Did you install anything else or put the car in valet mode or something?
Old 05-15-2012, 06:30 AM   #252
Barrettrw11
Member#: 316765
2012 WRX Base
I figured it out. The "backup" fuse blew on me somehow.
Barrettrw11 is offline   Reply With Quote
Old 05-17-2012, 12:07 PM   #253
dr1ftz
Member#: 294208
2012 5-Door WRX Ltd.
How is the bluetooth audio streaming quality with this unit? Really thinking about picking one up.
dr1ftz is offline   Reply With Quote
Old 05-17-2012, 12:24 PM   #254
slowhat
Member#: 304175
2012 WRX Limited
PBP
i've had no problems. i'm guessing it's about as good as the file or service being streamed.
slowhat is offline   Reply With Quote
Old 05-17-2012, 01:20 PM   #255
badz
Member#: 297312
2011 WRX Hatch
Dark Gray Metallic
This is exactly my experience. If I stream pandora on "low" bandwidth, it will sound crappy, and in my experience cause distortion and even some crackling on my speakers. If I stream pandora on high bandwidth I have none of those issues. Playing Google Music also offers great results (I have the settings set to stream high quality).
I use the BT audio feature with my phone every day to/from work, and pretty much any other time I'm in the car.
badz is offline   Reply With Quote
Old 05-17-2012, 02:44 PM   #256
Barrettrw11
Member#: 316765
2012 WRX Base
I got everything to work finally and I love this headunit. Def worth the money.
Old 05-18-2012, 07:43 AM   #257
Jojo29er
Member#: 320372
Sorry if this was asked, I read through and didn't see it.
Can the middle console USB plug work for this system or are u required to use the pioneer USB?
Is there a stock microphone in the car that can be used to prevent extra floating devices?
Thanks for the insightful thread, may upgrade to this hu with the money I can save installing myself.
Jojo29er is offline   Reply With Quote
Old 05-18-2012, 08:14 AM   #258
slowhat
Member#: 304175
2012 WRX Limited
PBP
without modification, no, the USB in the console cannot be used. One member said he was able to sue it with some modification, but i'm not sure f he used the OEM plug or managed to remove that and replace it with the female end of a cable running from the H/U.
At this point, stock mic cannot be used. I believe you could run the Pioneer mic into the stock location, but the Pioneer mic is pretty small and blends in nicely if mounted neat the speedo, so it may not be necessary
and you're welcome. now go buy it already!
Old 05-18-2012, 08:28 AM   #259
Ying
Member#: 166490
You can not use the OEM console USB. You will need to run the Pioneer USB to that location and it will require modification. Namely some dremeling to the plate where the OEM USB and AUX inputs mount to make the Pioneer inputs fit. If you chose later to go back to stock, you would need to get a new OEM center console liner. Just depends on what you think about that if you decided to ever trade the car in or sell it. I have mine run to the glove box and moved some of my glove box "stuff" to the center console. Wasn't crazy about it at first but I rarely have to get in there for anything.
As said, you can't use the stock mic. You can use the stock mic location with the pioneer mic if you choose to go through the trouble. Might not be worth the hassle though. I mounted mine to the headliner above the rearview mirror.
Ying is offline   Reply With Quote
Old 05-18-2012, 08:37 AM   #260
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
Still haven't installed my XM module. Need to get off butt and do it today.
BWX is offline   Reply With Quote
Old 05-18-2012, 09:25 AM   #261
Jojo29er
Member#: 320372
Thanks for the replies, one more quick question.
Does the Wiring harness from Crutchfield or Axxcess contol Bluetooth features or does the Axxcess ASWC steering wheel adaptor work these controls?
Can't decide whether to get a new hu or an ap for them new ride, decisions.
Old 05-18-2012, 10:09 AM   #262
slowhat
Member#: 304175
2012 WRX Limited
PBP
do you mean bluetooth steering wheel buttons? if so, the Axxcess and the 4400 will allow you to use "oh hook" and "off hook" buttons, not push to talk.
Old 05-18-2012, 10:37 AM   #263
Jojo29er
Member#: 320372
Yes the bt steering wheel buttons, I am assuming that I would need the nice 20 port adaptor to do this and not the 14 port from Crutchfield. Do you lose push to talk or retain with the ASWC?
Old 05-18-2012, 10:41 AM   #264
slowhat
Member#: 304175
2012 WRX Limited
PBP
yeah, get the harness from SVXdc. saves time.
either way with this unit, you will lose the push to talk function.
Old 05-18-2012, 11:02 AM   #265
Jojo29er
Member#: 320372
Cool, thanks.
Old 05-18-2012, 04:23 PM   #266
twizhimself
Member#: 58294
2004 WRX / 1998 Foz
SoCal F4 #20 / Area1320
has anyone had an issue with their iphone connecting via the dock connector since the newest iOS update?
twizhimself is offline   Reply With Quote
Old 05-19-2012, 07:28 AM   #267
luisv
Member#: 266098
2011 Outback Sport
Steel / Spark Silver
Every now and then my iPhone connects as Bluetooth instead of the dock connector. Other than that it's been rock solid.
luisv is offline   Reply With Quote
Old 05-21-2012, 09:38 PM   #268
StackSmasher
Member#: 316928
2012 STI limited
Sorry to thread jack, but I figured I would post here instead of starting a new thread.
I have this head unit and want to install some Polk db6501 components. Would the 14 watts rms that the head unit produces be enough to make them sound decent? I really don't want to have to install an external amplifier.
StackSmasher is offline   Reply With Quote
Old 05-21-2012, 09:42 PM   #269
odingrey
Member#: 287866
2016 WRX
Oh man, so close. I have db6501s up front, and db651s in back, with a AVH-p4400BH aaannnddd a polk 4 channel speaker amp.
What I can say is I switched head units while maintaining the same speakers and amp and this new HU does sound better. My guess is the higher preamp output.
odingrey is offline   Reply With Quote
Old 05-21-2012, 10:02 PM   #270
MtnXfreeride
Member#: 228010
2012 WRX Prem Hatch
Dark Gray Metalic
Also, spotify has really good streaming quality.. just make some awesome playlists and youll be set.
MtnXfreeride is offline   Reply With Quote
Old 05-22-2012, 12:07 AM   #271
CamaroSS
Member#: 30626
2015 BRZ Limited
1999 Miata Track Car
Just finished wiring the harness and the SWC and attaching the mounting kit. I cant say that I like the free mounting kit from Crutchfield. But I can replace that later with the JDM one...
Decided to wait to install everything until tomorrow when the ipod cable is supposed to be delivered...
CamaroSS is offline   Reply With Quote
Old 05-22-2012, 12:18 AM   #272
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
It'll sound decent at low volume levels, that's about it.
Old 05-22-2012, 08:01 PM   #273
CamaroSS
Member#: 30626
2015 BRZ Limited
Newb question: the stock radio has four harness connections. What do I do with all them on the pioneer unit, leave them disconnected? Looks like one might fit in the yellow port?
Also, there was a grey wire screwed on to the side of the stock head unit. Is this a ground? Does it need to be attached to the new harnesses ground wire? Ive git the bypass, axxess swc, and svx's 20 pin harness as well...
Old 05-22-2012, 08:11 PM   #274
CamaroSS
Member#: 30626
2015 BRZ Limited
Picture that shows the four harness ports and the antenna port.
Old 05-22-2012, 09:20 PM   #275
slowhat
Member#: 304175
2012 WRX Limited
PBP
The only wires i plugged in to the new H/U, that originated from my WRX, were the antenna and those that were attached to the new harness.
I believe the plugs that will remain unused are those for the bluetooth mic and the center console AUX and USB
Clutch "clicking" in 2012 wrx STIDAWG Transmission (AT/MT) & Driveline 7 03-16-2013 11:22 PM
Where to ground in 2012 wrx hatch? slowhat Car Audio, Video & Security 3 02-24-2012 11:35 PM
pioneer avh-p4000 install in 06sti nation1979 Car Audio, Video & Security 25 02-26-2009 01:47 AM
Pictures of Hid's installed in '02 WRX :) paultg New England Impreza Club Forum -- NESIC 7 12-16-2001 04:22 PM
Found out a short throw shifter wasn't installed in my WRX.. cout Bay Area Impreza Club Forum -- BAIC 5 05-03-2001 05:59 PM
