Go Back   NASIOC > NASIOC Subaru Models > BRZ Forum
Old 05-11-2012, 07:37 PM   #1
dompower
Member#: 236576
Default Oil drain plug size?
hi! I am looking to order a Fumoto Qwick valve for oil change...
but i can't find Information on thet BRZ oil plug size....
somebody here know it? and what kind of extension do I use with the valve?
is it the same as a ej25?
thanks for the help!
dompower is offline   Reply With Quote
Old 05-17-2012, 03:27 PM   #2
2point0
Member#: 150248
'13 BRZ Ltd WRB
'67 Mustang
Someone who has already picked one up will likely have to tell you the size. But what do you mean by extension? You just use a 17mm (I think...been a while) wrench to tighten. Or an adjustable wrench works fine, even channel locks. Can't use a socket.
2point0 is offline   Reply With Quote
Old 05-17-2012, 04:36 PM   #3
Tainen
Member#: 82251
2001 e46 330i sport
13 SWP BRZ
Call up a service department and ask. They will have the part number in their parts computer (I know Toyota has the parts catalogue now for sure)
Tainen is offline   Reply With Quote
Old 05-18-2012, 11:10 AM   #4
dompower
Member#: 236576
I've order a F-105 one for Forester 2012 who have a FB25.
the difference is 4mm in length
F-105 20mm-1.5 for "all subaru"
F-108 F-108 16mm-1.5 for (outback 2010+ EJ253)
Am I right?
Quick question: Oil drain plug size, with gauge pack? Siper2 General Community 10 07-27-2005 08:12 AM
Rear differential oil fill and drain bolts, same size as the oil drain plug? scooterforever Transmission (AT/MT) & Driveline 4 01-24-2005 06:06 PM
Oil Drain Plug Size AlanTheWoo Service & Maintenance 6 06-10-2002 08:54 AM
oil drain plug size tofu86 Service & Maintenance 3 11-26-2001 04:39 PM
Oil drain plug size... Suba-RAW Newbies & FAQs 4 09-30-2001 03:25 AM
Message Board Statistics All times are GMT -4. The time now is 08:40 AM.
