Old 05-18-2012, 11:36 AM   #12126
Commander Keen
Member#: 319157
2012 Impreza 4DR 5MT
The mounting holes are about 3 inches apart. The tweeters mount with screws. I suggest a stubby (short) Philips screwdriver for this. You can reuse the screws that came with the stock tweeters, or use the ones that come with the Kicker tweeters.
Thanks. The reason I ask is I'm wondering if one of these might be a good alternative. I'm sure there's a high-pass somewhere, so I wanted to see if it was on the speaker side or the head unit side.
Old 05-18-2012, 12:12 PM   #12127
tomwi53092
Member#: 316315
2012 Imp HB/Prem/CVT
DCP
I can't say for sure, I didn't give it a good look, but I'd be very surprised if it wasn't built into the tweeter to protect it. That's pretty common.The filter would just be a fairly small and cheap capacitor, so it would be crazy not to include it.
tomwi53092 is offline   Reply With Quote
Old 05-18-2012, 12:15 PM   #12128
nubsub
Member#: 313575
2012 Impreza 2.0i HB
To access the screws, you pry off the cover. Pry it off the front edge (closest to you). I just used a short, flat-edge screw driver with a thin blade. Insert the blade about 1 inch over from the rounded edge, push forward a bit and lift up about a quarter inch. Hold the corner up in place, then do the same on the other edge (insert screwdriver about an inch from the edge, push forward and lift up. Once the front edge is free, you can lift up the cover, pivoting off the back edge.
As for the high-pass filter, it must have one or the bass frequencies would blow it out. I don't know the crossover point, but based on the sound, I'd say 2K or 3K.
this is awesome info! thanks for sharing the detailed directions and experience. i need to get off my butt and order these! i was fretting over needing to get some prying tools, but it sounds like i probably have something (maybe even an exacto blade would work) around the house to remove those covers safely.
Old 05-18-2012, 12:22 PM   #12129
nubsub
Member#: 313575
bummer: seems subarupartsmall is now out of the tweeter upgrade. i know it was there the other day but not it's gone. hopefully they'll have it back in stock. tomwi's post inspired me to order it but alas: it's not meant to be...at least today...
Old 05-18-2012, 12:36 PM   #12130
tomwi53092
Member#: 316315
DCP
Glad to help. I'll probably break down at some point and get the door speakers, but it's a lot more work than the tweeters.
I'd be looking mainly for better bass with the kicker door speakers. I'm sure they have bigger magnets and better low end than the stock speakers. Perhaps not as good a low end as the subwoofer, but probably close, given the extra surface area of four speakers to physically move the air vs. a single subwoofer. The low octave on a four-string bass guitar is from 42hz to 84hz. The stock door speakers probably don't play this octave well, if at all, hence the muddiness when you increase the bass - you're increasing the higher octaves.
Old 05-18-2012, 12:39 PM   #12131
tomwi53092
Member#: 316315
DCP
I ordered from subarupartswarehouse.com. Maybe this is a different outfit than subarupartsmall.com
http://parts.subarupartswarehouse.co...catalogid=5511
Don't forget to use the discount code, SPW-630
Old 05-18-2012, 12:50 PM   #12132
nubsub
Member#: 313575
ah! i don't know how i messed that up, but i went to a different site today. duh!
thank you so much! i ordered it with the discount code and it came to $96 and change. that's about $13 cheaper after shipping, etc. than the other places i found on the web.
Old 05-18-2012, 03:32 PM   #12133
2007imprezi
Member#: 199120
2012 Impreza 2.0i
Obsidian black pearl
Originally Posted by ST Eye View Post
I was in the process of writing to Subaru as per lemon statutes, but ended up not needing to. I worked things out with a senior representative at SOA. This is why you need to contact them.
I have been in contact with SOA since late Feb early March .I have a case opened up and I've saved the papers from the dealer when I've had the car down there both times.
2007imprezi is offline   Reply With Quote
Old 05-18-2012, 03:54 PM   #12134
TObject
Member#: 320185
2012 Impreza 2.0i
Guys installing speakers, you must know which clips fit the trim panels; or anybody else. I am planning on taking some trim panels off to chase squeaks, and would like to have a few clips on hand in case I break any. So, which are the right clips? Thanks.
TObject is offline   Reply With Quote
Old 05-18-2012, 04:12 PM   #12135
ST Eye
Member#: 73068
2008 STI Boost Wagon
2014 Honda Accord Hybrid
How long has your car been at the dealership this past time? You said your car was in 2 times previously as well? If you're nearing the 30 days, I would talk to SOA (a senior rep, there are at least 2 tiers of reps) and tell them you're going to be sending a certified letter as per the statutes.
Old 05-18-2012, 04:25 PM   #12136
2007imprezi
Member#: 199120
2012 Impreza 2.0i
The first time they had my car I got it back the same day, they reset the light and did the oil change.Second time they had it for 1 day and claimed a plastic zip lock baggie and 2 water bottles under the seat were to blame .Third time they have had it since 5-7-12 Do you suggest calling SOA or just wait a little while longer?
Old 05-18-2012, 08:04 PM   #12137
3rdSubie
Member#: 295513
2012 Imp Prem Hatch
Camellia Red Pearl
I thank you too. I just ordered it, but I'll have to get Subaru to do the installation when I figure out how/where to get the door speakers and woofer upgrades. I'll search back about the door speakers and call my dealer.
3rdSubie is offline   Reply With Quote
Old 05-18-2012, 11:24 PM   #12138
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
so I am driving through the subaru dealer tonight after hours to check out the OBP/DGM they have on the lot and in rolls a car hauler with what looked like MY DGM Sport onboard! if it is i won't be able to get it until next thursday or saturday though
Old 05-18-2012, 11:53 PM   #12139
ST Eye
Member#: 73068
It's been 11 days, I don't think it could hurt to contact SOA to document your situation. When you talk to them on the phone, I would ask to speak to a senior representative. Tell them what's going on.
Old 05-19-2012, 07:08 PM   #12140
apexracer
Member#: 257754
2012 Impreza Sport P
Camilla Red Pearl
Anybody have a Graco stroller that has any fitment issues for transporting it in the back?
apexracer is offline   Reply With Quote
Old 05-19-2012, 07:46 PM   #12141
ammo_umb
Member#: 316152
2012 Sport Limited
Camellia
Auskip,
Do the aftermarket speakers weigh the same as the OEM speakers? I'd like to put some better speakers in but I don't want to affect the MPG's or have to leave my washer fluid home.
BTW I'm curious how extra coolant is more important to you than visibility. For most people unless they own a POS that overheats a lot, do a lot of desert driving or drive a rock crawler they are going to go through substantially more wiper fluid per year than coolant. I bet in the last 10 years I've used less than a gallon of coolant and 50 gallons of wiper fluid an for several years I did drive a rock crawler.
ammo_umb is offline   Reply With Quote
Old 05-19-2012, 09:26 PM   #12142
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
got my car today!!!
2 questions.
1. the shifter on my 5sp vibrates, I assume normal due to solid metal linkages unlike my Jetta that uses cables so there is no vibration.
2. the seats, not sure I like the lumbar support. The jetta is ok because I can turn it down, my buick really has none and that is really what I am used to, so maybe it will just be an adjustment.
btw, averaged 35.7mpg according to the trip computer on the way home, average speed 60mph, but varied from 40-70, PZEV version
oh, and I actually like the stereo, I did order it with the kicker tweeters, so at this point I am tempted to just add a basslink for depth and and leave everything else alone.
the audio controls on my type "B" radio were not locked out while in motion
Old 05-19-2012, 10:32 PM   #12143
jr0bb5
Member#: 315353
2012 Impreza Sp Prem
5MT OBP/DGM
Originally Posted by flyboy1100 View Post
got my car today!!!
2 questions.
Congrats man! Hope you're enjoying the car. About your 1st question, I already posted a thread asking about the shifter vibration. Everyone who responded said it's perfectly normal.
Old 05-19-2012, 11:53 PM   #12144
Commander Keen
Member#: 319157
I thought about the kicker tweeters, but went for a set of Polk DB6501 components instead. For a little more cash I can upgrade the dash "tweeters" and those sorry looking woofers in the doors. I've had the 6501s in another car and they sounded fantastic.
Old 05-20-2012, 12:34 AM   #12145
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
that's what I figured, the only thing stopping vibration is the bushings. just figured i would check
Old 05-20-2012, 12:37 AM   #12146
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
i'm still debating going to the polk 651 non S for the doors, haven't decided yet, not sure how they would sound off the stop HU. pretty cheap to do so though. like i said, the stereo doesn't actually sound horrible to me (i only listened to bluetooth on the drive home), which I am suprised by because the 2 cars i test drove only had the factory "tweeters" and i didn't think they sounded very good, and i am a bit of an audiophile.
Old 05-20-2012, 12:43 AM   #12147
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
oh ya, kinda annoyed, but oh well. The dealer didn't understand my request for Popular Package 1, so I didn't get it the price he told me was "correct" for what I was expecting, but when I got there today, none of that stuff was there. The price was "correct" because I was forced to get PZEV due to production change.
so I ordered the autodimming mirror, and cargo tray (he gave me rubber mats for free) and I will try to get them in this week
Old 05-20-2012, 01:32 AM   #12148
nubsub
Member#: 313575
got my car today!!!
2 questions.
Congrats! Great mileage off the bat!
Old 05-20-2012, 08:35 AM   #12149
somebody else
Member#: 21618
Just out of curiosity is anyone else having an issue with air bag light anymore , or was it just a few of us ?Its not looking good for my car .The dealership was suppose to special order the seat base or some part in the base ,and its been 2 weeks now and the car hasn't moved on the lot from where they parked it and they haven't called me.Guess its a waiting game now
I have the problem.
I haven't turned it in to the dealer though.
somebody else is offline   Reply With Quote
Old 05-20-2012, 09:01 AM   #12150
somebody else
Member#: 21618
They are Toyota/Lexus clips, shaped like tiny butt plugs!
Au-ve-co Products
#21102
(90467-A0005)
Head Dia: 20mm
16mm & 18mm
Stem Length: 14mm
Toyota/Lexus
2001-On
I bought a box and have extras. Could mail a couple for a few bucks.
2012 Impreza STI concept art khaki_man Member's Car Gallery 37 03-15-2011 02:02 AM
Newsflash: 2012 Impreza looks like BigElm's Butt WagonMonster Off-Topic 4 02-28-2011 07:11 PM
2012 Impreza Concept Zakster87 General Community 14 11-17-2010 04:09 PM
