#426 |
Member#: 220629
SCIC
Vehicle:2010 WRX Hatchback Satin White Pearl |
Is it common to not use lexan for the rear windshield, or are you guys just not considering it for this build at this point?
#427 |
NASIOC Manufacturer
Member#: 95419
E. Canada
You can use it for sure to save weight. performance plastics has some nice kits.
It is easy to replace afterwards though, so we kept a few $$ here as the originals we had at the shop were in good shape, and as it is the RA units for groupN cars are 1mm thinner (hence lighter) than the USDM items. |
#428 |
NASIOC Manufacturer
Member#: 95419
E. Canada
Radiator piping all installed and hooked up, SPAL fans hooked up (at 1350 CFM each !!!)
Rear doors all installed and fixed into place. Onto turbo installation and manifold setup with the 321ss. Easy to make a CFD approved design, but another to make it happen now .... This is one of those examples that an engineer says "do this" and the reality is "ah ****ttt" .... |
#429 | |
Member#: 211057
Vehicle:2006 STI Matte Black |
#430 |
NASIOC Manufacturer
Member#: 95419
E. Canada
coming, coming. Need to upload them!
#431 |
NASIOC Manufacturer
Member#: 95419
E. Canada
Finally getting pictures posted of some progress. Started to layout items for the wiring loom installation and came across this, anyone spot what is wrong??
![]() Preparing the main bus bars as well as the DCCD controller unit to be mounted to the floorpanels as low as possible. ![]() We then made a mock-up table to put all the items in there proper location. This helps when you need to order wire / supplies as well. Lets you calculate easier what is needed, and what goes were. ![]() Lightweight Fireproof sheathing helps slow the spread of fire and keeps everything neat and tidy. Not expensive, easy to work with, and does a really nice job. Better than std electrical tape, that's for sure! ![]() Lots more to go .... ![]() A good trick when using any signal sensors (cam, crank, wheel speed, etc) twist the wires together. This helps minimize field distortions. This is IN ADDITION to using the proper magnetically shielded wire as well. ![]() All the chassis loom comes in under 10 lbs now. This is a saving of over 60lbs. ![]() After laying out a template on cardboard, we drilled out the locations for the fuses and LED lights. This is a clean way to make a nice loom without spending 6$k on a PDM. The PDM makes it much cleaner, lighter, and easier to configure the loom though. Especially when coupled with and OBR membrane switch panel... ![]() Finally, rear trunk latches installed as well. The carbon trim is bonded to the trunk lid, and the latches are riveted through both. This helps reduce the chance of things cracking with the vibrations. ![]() |
#432 |
Member#: 47915
Vehicle:2003 WRX Wagon HC TT 08 STI WRB 06 OBXT |
#433 |
NASIOC Manufacturer
Member#: 95419
E. Canada
Yeah, luckily that was caught before the car goes out !
#434 |
Top Scoob 009
Member#: 68273
Vehicle:2012 WRX GD Race Car in progress |
Nice work. No need to spend $6k on a PDM though, the MoTeC PDM15 can be had for about 1/3 of that
#435 |
NASIOC Manufacturer
Member#: 95419
E. Canada
I was actually referring to the OBR unit with the membrane dash.
The PDM15 I don't think has enough channels for a touring car with flashers, horns, wipers, etc, etc, etc |
#436 |
Member#: 29879
TXIC
Vehicle:2002 WRX Wagon Silver |
subscribed
#437 |
Top Scoob 009
Member#: 68273
That's true unless you double things up on one output. We ended up needing to upgrade to a PDM30 (still about 1/2 the cost of the OBR).
#438 |
NASIOC Manufacturer
Member#: 95419
E. Canada
hehehe, you baller you
![]() Might as well get the membrane switch panel as well Dan ... I mean you are already there more or less. |
#439 |
NASIOC Manufacturer
Member#: 95419
E. Canada
Forgot to add, we finished the turbo inlet pipe today with "X" design that was worked out by an engineering friend of mine. So turbo and exhaust are almost wrapped up as well.
I am getting REALLY close to starting the car, how far are you still? hehehehe ![]() |
#440 |
Member#: 179783
W. Canada
Vehicle:2002 WRX Silver STi swap 380wph!! |
i love this build, so many inspirational ideas.
2 questions: where did you get all your goodridge lines and fittings supplied from I'm in canada (calgary) to but can't find any online suppliers close to here? more info on the harness. fireproof sheathing and maybe a diy on redoing/ pinning the connectors? looking forward to see Leo in action tomorrow at RMR |
#441 | |
Member#: 262871
I second this! Been looking for Goodridge stuff as well, and the only results are a few brake line kits I'm in Toronto. |
#442 |
Member#: 195711
Vehicle:STi 04/05/06/07 JBP / OBP for now |
Anplumbing.com!
#443 |
NASIOC Manufacturer
Member#: 95419
E. Canada
We stock a lot of the higher end goodridge items here. Well, we stock what we use anyhow.
Send me an e-mail with what you are looking for. We can do the crimp fittings as well if you need. I don't have a tester rig though, and brake lines I will only sell the bulk bits with re-usable ends, or the G-Stop kits that are crimped from Goodridge directly. The only ends I will crimp will be fuel / oil lines in the 600, 811, or 911 series hoses. Steel or Aluminum (in the 600 series) aluminum in the 811 or 911 series. -mark |
#444 | |
Top Scoob 009
Member#: 68273
It's actually very reasonably priced, probably not much more than a bunch of mil spec switches and all the extra wiring. |
#445 |
NASIOC Manufacturer
Member#: 95419
E. Canada
Probably... but I had the items in stock and it is done. Next car ... maybe the BRZ that arrives in 2 weeks will see something more trick ...
#446 |
Member#: 116317
South East
Vehicle:2002 WRX...sold:-( |
BRZ?! Ooo, more info please! Will you be starting another build thread to show us your plans and progress on that one?
#447 |
NASIOC Manufacturer
Member#: 95419
E. Canada
Need to sell this car first!
#448 |
Member#: 12694
Vehicle:02 WRX/JDM EJ207RA Unabomber Eeee-thug |
#449 |
NASIOC Manufacturer
Member#: 95419
E. Canada
Not the greatest picture, but it is a picture.
We finished the NEW MSI fuel rails for testing, one set going on our race car, the other going out to Fine Line Imports. ![]() |
#450 |
Member#: 176134
SCIC
Vehicle:07' Impreza STi wrb 95 L... |
| Thread Tools | |
| Display Modes | |
| FS : TX: 2007 STI Show Car...Bride,Project Mu,Advan... | Speedelements | Private Vehicle 'For Sale' Classifieds | 30 | 08-14-2012 03:23 PM |
| I finally did it, 2007 STI - Thanks Carter | Remnex | North West Impreza Club Forum -- NWIC | 11 | 01-26-2007 03:19 AM |
| 2004 WRX STi Project Car For Sale | billy720 | Private 'For Sale' Classifieds | 0 | 03-30-2006 08:46 PM |
| 04 STi project car part out! | Subaruist | Private 'For Sale' Classifieds | 45 | 11-29-2005 12:51 PM |
| 04 GReddy/Prodrive STi project car for sale | gc8white | Private Vehicle 'For Sale' Classifieds | 1 | 08-25-2005 10:31 AM |
