Old 05-17-2012, 01:09 PM   #1
DetailersDomain
Member#: 165558
Default Sonax Full Effect Cleaner is truly an effective wheel cleaner
Just wanted to show you guys what this wheel cleaner can do.
2000 miles were logged on to this Q7 on 21's.
2000 miles of brake dust/dirt/grime
Close up - showing caked on brake dust and grime
Sonax Full Effect Wheel Cleaner and various brushes were used to clean up this mess.
DetailersDomain is offline   Reply With Quote
Old 05-17-2012, 01:11 PM   #2
DetailersDomain
Member#: 165558
Afters
Old 05-17-2012, 01:33 PM   #3
pushatam
Member#: 258897
2011 Impreza WRX
Dark Grey Metallic
Is the process to spray, rinse with hose, scrub, and then wipe?
pushatam is offline   Reply With Quote
Old 05-17-2012, 02:06 PM   #4
DetailersDomain
Member#: 165558
that would be the best way to use it.
Old 05-17-2012, 05:06 PM   #5
Notyab
Member#: 56028
???? -In between-
Used it on my BBS which probably had years of built in grime in areas, a little scrubbing with a toothbrush and they look new. Absolutely love this stuff.
Notyab is offline   Reply With Quote
Old 05-17-2012, 05:10 PM   #6
dumpstercrusher
Member#: 134940
2006 Impreza WRX TR
vf39 ewg tuned ppg gears
I did spray, scrub with a brush and soap(same for the car, but different buckets), then rinsed. Looked great after.
dumpstercrusher is offline   Reply With Quote
Old 05-17-2012, 07:09 PM   #7
cenix
Member#: 246027
2011 STI
i've been using this for the past couple years and it's awesome!
cenix is offline   Reply With Quote
Old 05-17-2012, 07:17 PM   #8
therealratfink
Member#: 192817
2010 WRX STi
Bright Freakin' Red
To bad your site charged as much for shipping as the product costs....
therealratfink is offline   Reply With Quote
Old 05-17-2012, 07:42 PM   #9
nightcrawler60
Member#: 126438
2004 Impreza
#Winning
I need this and a good wheel wax/sealant...Stoptech pads dust like crazy.
nightcrawler60 is offline   Reply With Quote
Old 05-17-2012, 07:45 PM   #10
nightcrawler60
Member#: 126438
2004 Impreza
#Winning
Damn, $28 for a bottle shipped.
Old 05-17-2012, 08:54 PM   #11
kenlee
Member#: 49341
Thats why if I only need one or two things I'll go through amazon as they offer it with free shipping if you spend $25.00 For larger orders that I'd get free shipping I'd rather support the vendors on the forums like detailersdomain or autogeek (not sure if they are a vendor) as they both have a wealth of knowledge to lend. Also sometimes if you watch the vendor sale sections they offer up free shipping on a lower total purchase requirement.
kenlee is offline   Reply With Quote
Old 05-17-2012, 09:51 PM   #12
xbeamelite
Member#: 281250
2007 STi Ltd
UGM
Expensive but amazing stuff. Get the 5L from Amazon, transfer to small spray bottle to ration. That's what I'm doing.
xbeamelite is offline   Reply With Quote
Old 05-17-2012, 11:11 PM   #13
itsover9000
Member#: 309498
2012 STI Limited
bought the two gallon bundles. It deff needs agitation for caked on brembo dust
itsover9000 is offline   Reply With Quote
Old 05-20-2012, 01:07 AM   #14
eurospek
Member#: 96944
2005 SAAB 9-2X AERO
4eat Stage 2 Protuned
Any full shots? Q7 looks lowered.
eurospek is offline   Reply With Quote
Old 05-20-2012, 09:04 AM   #15
DetailersDomain
Member#: 165558
look out for a full write up on the Q7
Old 05-20-2012, 06:31 PM   #16
csullivan
Member#: 111653
2011 WRX STi
In my experience, Meguiar’s Wheel Brightener is very nearly as good, but instead of $25 a bottle, it's $20 for 5 gallons of it.
csullivan is offline   Reply With Quote
Old 05-20-2012, 06:32 PM   #17
eurospek
Member#: 96944
2005 SAAB 9-2X AERO
That's what I've been using, heavily diluted. But it did kind of mess with the finish on my calipers (but back then I only diluted equal parts of it). I still have 1/4 of the bottle left, purchased in 2006.
Old 05-20-2012, 06:39 PM   #18
csullivan
Member#: 111653
2011 WRX STi
Holy ****, it's supposed to be 4:1 AT MOST.
Old 05-20-2012, 11:08 PM   #19
eurospek
Member#: 96944
2005 SAAB 9-2X AERO
Definitely got the wheels clean though lmao. No damage to the finish on the Enkeis and I've found myself even using it less and less since switching away from Hawk HPS pads.
Old 05-21-2012, 09:43 AM   #20
xCONWRATHx
Member#: 175840
2005 LGT Wagon
1999 Sentra SE-R
The difference is that Meguiar's Wheel Brightener is an acid based wheel cleaner, and that Sonax is an acid-free deironizer. Although they both have the ability to get the wheel very clean, the Sonax will do a better job of it with respect to embedded iron particles. When cleaning exceptionally gnarly wheels, or when prepping them for a permanent coating, I always use a deironizer like Sonax.
xCONWRATHx is offline   Reply With Quote
Old 05-23-2012, 08:14 AM   #21
csullivan
Member#: 111653
2011 WRX STi
Sure, in that specific example, there's a clear advantage that I'll in no way deny. I have a bottle on the shelf I used for really nasty winter wheels that had never been cleaned. Worked like a champ.
But if we're talking regular cleaning, Sonax is 20 times more expensive.
Old 05-23-2012, 10:33 AM   #22
MSMStannyl
Member#: 267225
2011 WRX Limited 4DR
Actually, I have a question about this product. A while back, I stupidly used some stuff on my wheels. I can't remember what it is called but I think it was made by ArmorAll and it was called "Wheel Protectant" or something like that. Basically, after cleaning and drying the wheels, you spray this stuff on and it basically forms a protective coating on the wheels.
Well, it's horrible and I wouldn't recommend it to anyone. It left all these blotchy areas all over the wheel that I'm still having problems getting off. As far as wheel cleaners, I've only used cheap stuff from the local auto parts store. Nothing has really been able to get it off. I'm wondering if this stuff will do the trick. Any suggestions?
EDIT: BTW, this is the Armor All stuff I used that I'm trying to get off (almost a year later!): http://www.armorall.com/products/vie...?product_id=33
MSMStannyl is offline   Reply With Quote
Old 05-23-2012, 12:26 PM   #23
DetailersDomain
Member#: 165558
you may need to clean the wheels and polish the protectant off.
Old 05-25-2012, 07:57 PM   #24
msdss
Member#: 117347
I just got my order from detailersdomain. a six pack of this stuff that came with 10 micro fiber towels. Great deal. I gave it a test run on a BMW that probably hasn't been washed in 2-3 years. The pictures don't do it justice. The wheels were basically black when I started. The only thing I used was sonax, and a touch of soap and water on a mcirofiber mitt. probably the easiest wheel cleaning i've ever done. This stuff is amazing!
msdss is offline   Reply With Quote
Old 05-26-2012, 04:03 PM   #25
War Bunny
Member#: 268446
2013 STi sedan
I love the stuff, but Amazon has it for the same price, free two day shipping. Cheapest shipping for DD is $11 for FedEx. Adam's does the same crap, and I definitely buy less product because of it.
War Bunny is offline   Reply With Quote
Stock up and Save Big on Sonax Full Effect Wheel Cleaner! DetailersDomain Car Care & Detailing 0 11-17-2011 01:00 AM
Stock up and Save Big on Sonax Full Effect Wheel Cleaner! DetailersDomain Wheels/Tires 0 11-17-2011 12:59 AM
Sonax Full Effect Wheel Cleaner, Adam's APC, Prima Nero/Wheel Armour in action DetailersDomain Car Care & Detailing 21 09-07-2010 03:40 PM
PSA: Gasoline is not an effective head lice treatment. Unless you light it. Wagon Of Fury Off-Topic 24 02-26-2009 06:49 PM
looking for an amazing wheel cleaner jawbrkr Car Care & Detailing 37 08-09-2005 12:42 AM
Message Board Statistics All times are GMT -4. The time now is 08:49 PM.
