Welcome to the North American Subaru Impreza Owners Club Tuesday May 26, 2015
Old 05-20-2012, 02:34 PM   #1
Team Scream
Member#: 121532
2006 FXT/STi 6MT
01 Aerosim GC8 Coupe
Default Fuel line configuration
Trying to finish up my swap and I am a bit confused on the fuel line routing/configuration.
The car is a 2001 L coupe with an 07 STi swap.
The OEM hard lines the exit the firewall @ the drivers side strut tower are what I need clarification on.
I know the bottom most line is the feed/pressure line, what I need to know is which of the other 2 (middle or top) is the return line?
On the 06 STi service manual I have, it shows:
Bottom line > FEED
Middle Line > EVAP
Top Line > RETURN
I need to know if the earlier Impreza's followed this same convention?
Can anyone point me in the right direction?
Team Scream is offline   Reply With Quote
Old 05-20-2012, 03:20 PM   #2
AKGC8
Member#: 1305
2000 Impreza
You've got it right, they are the same.
The grey top line on the chassis is the return line. Middle blue is the EVAP.
AKGC8 is offline   Reply With Quote
Old 05-20-2012, 04:11 PM   #3
Team Scream
Member#: 121532
2006 FXT/STi 6MT
Thank you so much for the fast reply brother, much appreciated!
Are most guys with swaps using the original RS filter @ the strut tower to make the connections to the STi/WRX manifold fuel lines?
Old 05-20-2012, 05:19 PM   #4
AKGC8
Member#: 1305
2000 Impreza
With my 02 WRX swap I used the strut tower filter, which the 02 WRX used as well. With my STI swap I used the in tank filter because I swapped the STI tank to avoid any CELs since it's got an extra sensor on the tank the GCs didn't have. People do use the strut tower filters on STI swaps though.
Old 05-20-2012, 09:31 PM   #5
AKGC8
Member#: 1305
2000 Impreza
As per the other thread, that guy has his lines correct. They swap going from the chassis to the engine.
Delivery = top engine / bottom chassis
Return = middle engine / top chassis
EVAP = bottom engine / middle chassis
Need larger fuel lines, should I delete the EVAP system and use all three hard lines? dexterous Built Motor Discussion 19 04-09-2011 08:39 AM
3/8" fuel lines and factory hard lines? NSFW Built Motor Discussion 14 07-14-2009 10:20 AM
RS-T's... Vacuum line configuration poll... 8Complex Normally Aspirated with bolt-on Forced Induction Powertrain 21 05-30-2009 09:11 PM
vaccum lines/intake delete setup/fuel lines bloopsta26 Built Motor Discussion 2 10-24-2008 09:09 PM
Evaporation Line/ Fuel Line questions Mnstr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 09-13-2002 03:17 PM
