Welcome to the North American Subaru Impreza Owners Club Tuesday June 30, 2015
Old 05-10-2012, 12:08 PM   #276
nubsub
Member#: 313575
2012 Impreza 2.0i HB
i too would love to hear more installation details...do the wheels need to come off?
also: wow...those look really low to the ground in the website pics.
nubsub is offline   Reply With Quote
Old 05-10-2012, 12:16 PM   #277
chanomatik
Member#: 159474
2013 BRZ Ltd 6MT CBS
SNOSLO
Originally Posted by J-Rod03 View Post
Is anyone else's rocking any aftermarket wheels yet?
Check the 2012 Pictures thread, tons of aftermarket wheels on there.
chanomatik is online now   Reply With Quote
Old 05-10-2012, 12:57 PM   #278
Angelus911
Member#: 89967
2012 Impreza Sport
FWIW, they have installation instructions here for the RA:
http://www.rallyarmor.com/store/2012...structions.php
Looks like a pain in the ass for the Sport model with the Strake kit.
Old 05-10-2012, 01:02 PM   #279
ammo_umb
Member#: 316152
2012 Sport Limited
Camellia
I hope this isn't a duplicate question but I was unable to find the info so I though I should ask.
Where do you find the LED reflectors at? Is there a link to a suggested vendor or any brands/models/vendors that should be avoided?
ammo_umb is offline   Reply With Quote
Old 05-10-2012, 01:27 PM   #280
djberkner
Member#: 316828
2012 Impreza Sport
Ice Silver
I emailed Rally Armor and they advised not to add their mud flaps if you already have the strake kit or the aero splash guards installed. Also the video installation doesn't show the wheels off.
djberkner is offline   Reply With Quote
Old 05-10-2012, 01:52 PM   #281
nubsub
Member#: 313575
thanks for the good info.
Old 05-11-2012, 04:57 AM   #282
Zamdude
Member#: 319706
2012 Impreza Sport
No, you do not have to take the wheels off. All you need is an offset screw driver and a flat head screw driver. The only real pain is that you have to pull back some of the fender wells to get the retaining clips in place. I guess it was an easy install for me by the fact that these were the 3rd set I have installed. First set was on a 2010 Forester and the 2nd set on a 2011 Outback. It took about an hour to install.
Zamdude is offline   Reply With Quote
Old 05-11-2012, 04:59 AM   #283
Zamdude
Member#: 319706
2012 Impreza Sport
Originally Posted by SZRimaging View Post
Did you have to remove any body work or the wheels? I'm looking to order a set and am slightly nervous on the install.
You only have to pull back some of the fender wells to get the retaining clips in place.
Old 05-11-2012, 01:24 PM   #284
PAO56
Member#: 304676
2012 Impreza Ltd 5DR
Deep Cherry Pearl
here is where I got mine from:
http://www.customledservice.com/subaru_prod.html
PAO56 is offline   Reply With Quote
Old 05-13-2012, 09:19 PM   #285
Subupreza12
Member#: 296167
2012 Impreza Sport
Premium 5MT
Installed the Rally Armor UR flaps over the sport 'aero' flaps. Anyone attempting this install should have lots of patience and a dremel. Didn't take any pics of the install but it isn't all that complicated.
Subupreza12 is offline   Reply With Quote
Old 05-13-2012, 10:17 PM   #286
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
What did you use the dremel for. I'd like go know more details in the install....
italia490 is offline   Reply With Quote
Old 05-13-2012, 10:42 PM   #287
Subupreza12
Member#: 296167
2012 Impreza Sport
Premium 5MT
I just figured it out as I went along.. but there's a piece of the rear aero flap that sits in the exact place the Rally Armor flap goes. Part of it protrudes into the wheel well so you'll have to cut off the part that protrudes if you want to keep it in. You might even be able to leave out the piece out entirely but I wanted to leave it in. In the end you can't see where I had to cut so it isn't all that big of a deal. You'll also need to fabricate some thicker spacers that go between the fender and the flap (I cut up a thick rubber floor mat for this) because the aero parts stick out further into the wheel well than the sport model's side skirts. I also had to bend the front brackets a little because the added fender spacers move the flap further in towards the wheel. TBH, it's impractical to do a thorough write-up on the subject because you have to get a little creative with how you piece it all together.. which is probably why Rally Armor advises against it. Totally do-able though!
Old 05-13-2012, 10:43 PM   #288
apexracer
Member#: 257754
2012 Impreza Sport P
Camilla Red Pearl
Originally Posted by italia490 View Post
For those of you that will be unbolting your muffler, you are going to want to secure the muffler away from the pipe coming from the car with some tie straps or remove it completely. Reason being is that it will move back into place and you'll lose the rumble.
Here is the link from Youtube for those that are interested in how it sounds:
http://youtu.be/c6hpf-j5EqY
That's my video, I recently put a turndown on it.
find a pic here: http://forums.nasioc.com/forums/show...2314837&page=3
apexracer is offline   Reply With Quote
Old 05-15-2012, 12:31 AM   #289
J-Rod03
Member#: 116716
Does anyone know if 19x8.5 + 45 wheels will fit the sport limited, even with a slight drop? Looking to avoid rolling fenders, etc
J-Rod03 is offline   Reply With Quote
Old 05-15-2012, 01:59 AM   #290
ans2k
Member#: 315631
2012 Impreza Sport
make sure you have the right bolt pattern. not sure if that will fit, what tire do you plan on using?
Old 05-15-2012, 10:16 AM   #291
MjSub2.0
Member#: 314973
2012 Impreza Sport
Satin White
Make sure you run 35 series tires.
MjSub2.0 is offline   Reply With Quote
Old 05-20-2012, 01:43 PM   #292
outdoorsoob
Member#: 317053
Default exhaust
hey, anyone done some muffler mods? i know we were talking about it earlier, to let the subbie purr come out, but nothing yet?
outdoorsoob is offline   Reply With Quote
Old 05-21-2012, 12:23 AM   #293
apexracer
Member#: 257754
Camilla Red Pearl
If you go up a couple posts I have a link to the turn-down I had made.
Old 05-21-2012, 10:03 AM   #294
outdoorsoob
Member#: 317053
OMGHi2U
Sweeet. Love the video. Is there any chance you have a video of the turndown running? I'm totally new to exhauast mods, so a turndown is just redirecting the tailpipe? How's the sound differ?
Old 05-21-2012, 10:18 AM   #295
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
You can also check out my build thread for pics and video as well. I modded the exhaust similar to apexracer. Here is the link to my the thread: http://forums.nasioc.com/forums/show....php?t=2341230
Old 05-22-2012, 10:04 AM   #296
BryanP5555
Member#: 314731
2014 WRX
If anyone is interested i am selling a 2pc rear Strake Kit
http://forums.nasioc.com/forums/show....php?t=2357848
BryanP5555 is offline   Reply With Quote
Old 05-22-2012, 07:50 PM   #297
darkbug
Member#: 317711
2012 Impreza 5-spd
Cherry
Will the wrx sway bar fit the impreza?
darkbug is offline   Reply With Quote
Old 05-24-2012, 11:43 PM   #298
apexracer
Member#: 257754
Camilla Red Pearl
I've heard the Sti fits. And perrin makes a rear sway bar and front end links for our year. It's probably the same as the last gen impreza/wrx
Old 05-24-2012, 11:54 PM   #299
J-Rod03
Member#: 116716
PM'd!
Old 05-27-2012, 12:53 AM   #300
outdoorsoob
Member#: 317053
Default dumb question im guessing
okay, so there are people on here who plastidipped their chrome grills to look slightly more like the 250$ sport mesh grill option. i haven't plastidipped stuff for a while, is there a certain color that you all used? is it black? dark gray?
thanks
factory SS or aftermarket for 2012??? Myth21 Transmission (AT/MT) & Driveline 8 01-07-2012 11:18 AM
Anybody in SCIC-land taken possession of 2012 Impreza 2.0i yet? somebody else Southern California Impreza Club Forum -- SCIC 1 12-29-2011 11:31 PM
Has anyone test drive a 2012 Impreza yet? pRiMe DiReCtIvE General Community 25 11-28-2011 10:03 PM
Hybrid Impreza in the works for 2012? rsholland News & Rumors 43 03-12-2010 10:58 PM
