Old 04-08-2012, 04:48 PM   #51
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
You are gonna cream your jeans dude. Cereal. That thing is bad ass and if you have arts and crafts skills with the wrap it looks terrific. I'm really loving the sound of the EL header too as its very Porsche like and grows on you.
Old 04-08-2012, 09:43 PM   #52
xHuge
Member#: 284406
2002 WRX w/STi swap
So no spray like we did with the old wrap? Even to get a few more anal retentive degrees because...you know...racecar.
xHuge is offline   Reply With Quote
Old 04-09-2012, 08:09 AM   #53
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
that wrap is very easy to do sharp bends with. i used the 1'' and mine came out very nice and tight wrapped. it takes some time and patience though. the ends will fray like hell if you arent careful like unabomber said.
Old 04-09-2012, 09:03 PM   #54
bigdknicks
Member#: 316300
nice lookin stuff right there
bigdknicks is offline   Reply With Quote
Old 04-11-2012, 09:16 PM   #55
BlackLabelFox
Member#: 289336
2008 WRX Sedan
SSM/Clark Turner Tuned
Sweet! Just ordered the wrap you used as well as the Tomei ELH. Thanks for the lesson. I'll be taking my time with it for sure.
BlackLabelFox is offline   Reply With Quote
Old 04-11-2012, 10:04 PM   #56
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
you will love that setup! im soo happy with the el header sound. no more drone killing my ears. take your time with the wrap. it will look awesome when you are done. also, those metal ties are useless. i went on ebay and bought a box of stainless gear hose clamps. they hold nice and secure. the wraps dont stay tight and slide around during install.
Old 04-11-2012, 10:25 PM   #57
BlackLabelFox
Member#: 289336
2008 WRX Sedan
Ya I have some extra clamps around somewhere. I'm pretty excited to get it all set up. Did you have enough room to wrap each runner individually or did you have to pair them up?
Old 04-12-2012, 08:05 AM   #58
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
i wrapped each one individually. it takes a little patience. keep it tight with plastic zipties as you work done each tube. then remove them when finished. the stock uppipe is a pita to remove. i had to lift the pass side of my engine about an inch to get room to pull it out from the bottom.
Old 04-26-2012, 06:44 PM   #59
tazswing
Member#: 63767
2009 OXT 5-spd
2011 STi hatch
This was the warp-type used for my UP/DP and EWG pipe that runs back into the DP.
So, headers are on their way and the wrap has already arrived.
Question is this: With headers like Perrin, with the runners fairly close together, is it best to wrap 2 into 1 or work it like a champ and wrap the runners as individually as possible? Which would net the best heat retention property?
This (though it has both)
vs
tazswing is offline   Reply With Quote
Old 04-27-2012, 12:57 AM   #60
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
It is better to wrap each runner individually. No space between runners = less heat lost. I have tired it both ways and got better results with the individually wrapped runners. I have (most of, custom job) Perrin headers.
speedyHAM is offline   Reply With Quote
Old 05-11-2012, 12:35 AM   #61
FG2toGDF
Member#: 292537
2004 STi
Awesome write up UB. Made this look easy. Attempting the DP within the next week. Thanks to this write-up, feeling a bit more confident in knocking it out.
FG2toGDF is offline   Reply With Quote
Old 05-14-2012, 01:59 PM   #62
tazswing
Member#: 63767
2009 OXT 5-spd
2011 STi hatch
Cool. I will suck it up and do my measuring and wrap the runners individually as much as possible.
Old 05-14-2012, 02:08 PM   #63
jege41
Member#: 280754
Default Call the fire truck's
Thanks Ron, another good post
I bet you had one hell of a smoke signal going on for the first 100 miles, as I sure did when I did mine.
Works like the post says though!
jege41 is offline   Reply With Quote
Old 05-22-2012, 12:05 AM   #64
paulpat
Member#: 237145
02 WRX
12 FXT
Is there a way to wrap something over this so that water, dirt and oil from getting soaked into the wrap.
I was thinking something like the silver stuff on the unabomber's turbo wrap guide. Can I just layer aluminium foil and wrap that with headers, uppipe, and downpipe?
Is it possible to retain the OEM heat shields on the headers?
I have the OEM headers and uppipe.
paulpat is offline   Reply With Quote
Old 05-22-2012, 03:58 PM   #65
paulpat
Member#: 237145
02 WRX
12 FXT
any answers to the above post? bump!
Old 05-22-2012, 06:39 PM   #66
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
Thermo-Tec 16850 could be used or for baller status (I was going to use this option then my non-baller wallet said no) http://www.aclperformance.com.au/prod_heatshield.htm is what you could use as its basically thin metal (and was/still is used to wrap APS headers). It's very expensive though, when I checked into it (my memory sucks) it was pricey as crap along with not knowing how much to order to wrap headers.
Old 05-22-2012, 06:48 PM   #67
chris the man
Member#: 287783
08 predator evo X
RR
i just picked up some PROSPORT titanium wrap. had no idea they make different types of wrap. its truely amazing from the numerous types i have used DEI and jegs. whats the best part is you can bid on it on ebay for dirt cheap i got and entire 50ft 2in thick titanium roll for 30$ thats amazing!
chris the man is offline   Reply With Quote
Old 05-22-2012, 08:37 PM   #68
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
i wouldnt put anything else around the wrap. i have my engine cover on underneath so it keeps the wrap pretty clean and dry. i dont think the oem heatshields would bolt up at all. i used the dei titanimum like unabomber on my tomei headers and uppipe. real nice stuff.
Old 05-22-2012, 10:21 PM   #69
paulpat
Member#: 237145
02 WRX
12 FXT
Eh thats what I was afraid of. I would love for the heat sheilds to somewhat bolt up because my OEM plastic skidplate is dead. I might try this some time if I am ever taking off the up pipe and cross pipes again. I would have done this soon but now my motivation is gone... I'll stick to just the turbo blanket wrap like Ron did.
Old 05-23-2012, 02:37 PM   #70
Faster_Gun
Member#: 180217
2001 Porsche 911 TT
1990 Nissan Skyline GTR
Just picked up 2 1"x50' rolls for 60 bucks shipped off of Autoplicity. Thoughts on laying down some thermal paint before wrapping?
My plan was to paint and wrap my uppipe, dump tube, and ported stock headers and use whatever is left on my FMIC plumbing. If I still have a lot left I'll wrap my ceramic coated downpipe.
Faster_Gun is offline   Reply With Quote
Old 05-23-2012, 03:16 PM   #71
Dale2011WRX
Member#: 304299
2011 WRX, white
2014 Crosstrek, tangerine
The wrap is meant to hold heat in (as an insulator), so I wouldn't use it on FMIC plumbing. For that (FMIC plumbing) you want to keep engine heat out, so wrap it in some brand of heat-reflective tape.
Why aren't you wrapping your downpipe?
Old 05-23-2012, 03:25 PM   #72
Faster_Gun
Member#: 180217
2001 Porsche 911 TT
My FMIC piping wouldn't be dissipating heat via tubing, it would be soaking. Wrapping my FMIC piping in key areas would insulate from heat soak.
I'm not wrapping my dp because I think the ceramic coating is sufficent.
Am I off my rocker?
Old 05-23-2012, 04:18 PM   #73
paulpat
Member#: 237145
02 WRX
12 FXT
insulation is insulation. Its not like it can tell which way the heat is going. Reference -Physics.
the wrap on the dp can only help right?
Old 05-23-2012, 04:50 PM   #74
Faster_Gun
Member#: 180217
2001 Porsche 911 TT
My thought process behind wrapping the piping first is that the engine itself gets pretty toasty. I have a turbo blanket and heatshield that I can touch so I don't think that much heat escaping off the turbo. I want to keep the colder side of the I/C as insulated as possible because presumably the charge is cooler than the engine bay temp.
Old 05-23-2012, 07:51 PM   #75
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
Yes, wrap the pipe into throttle first, do you more good than wrapping the exhaust with a FMIC...
wrxdrvr is offline   Reply With Quote
How to wrap your turbo Unabomber General Community 143 03-21-2016 12:59 AM
Why its a good idea to wrap your headers PolarisSnT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 10-30-2007 09:38 AM
How to wrap header? AWD>FWD Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 33 05-22-2007 02:06 PM
To wrap or not to wrap borla header?? scoobysnack69 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 08-08-2006 06:04 PM
Is it possible to heat wrap your stock uppipe? blackie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 02-22-2005 08:52 PM
