Old 05-19-2012, 07:13 PM   #51
jjasonn
Member#: 208653
2004 V-Limited
Spec C
I have explained way back that I'm not working for Kamak or kinugawa . Just a wry satisfied customer Thats all.
jjasonn is offline   Reply With Quote
Old 05-22-2012, 12:38 AM   #52
teiva-boy
Member#: 22825
Originally Posted by Unabomber View Post
They just got back to me. Stand back....I'm about to make magic happen!
In for gang ban.... Err wait.
So where's the magic?
teiva-boy is offline   Reply With Quote
Old 05-22-2012, 01:17 AM   #53
murrdogg24
Member#: 50586
04 WRX
Flappy bird edition
Been using a Kinugawa turbo for about 2 months now and so far it has performed flawlessly. I was looking for twin scroll options to get me close to 400whp and as you know there are not many options. So I figured it's worth a shot and another member on here had good results. I went with the TD05L-20G twin scroll and it's pretty good.
<Car>
04 WRX
<Mod List>
EJ207 version 8
TD05L-20G TS
Five-0 1000cc injectors-running E85
Lightweight UR under drive pulleys
AEM CAI
Perrin turbo inlet
Stock JDM STI TMIC
Grimmspeed 3 port EBCS
JDM v8 ECU w/ AVCS working
JDM STI ver8 6 speed trans w/ DCCDpro controller
Opensource Tuning with the help of Ron from PhatBotti Tuning
murrdogg24 is offline   Reply With Quote
Old 05-22-2012, 01:26 AM   #54
UK-Wagon
Member#: 232430
555 XTi
1 AW & 1 CGM
They make a couple bolt in stock location twin scroll turbos for subarus.... Not sure what HP you could squeeze out of one though. They also offer a twin scroll DP and up pipe flange.
UK-Wagon is offline   Reply With Quote
Old 05-22-2012, 01:49 AM   #55
Kill3rWill
Member#: 287837
2005 WRX
Figured I would chime in. I have their td06sl2 20g 7cm on my 05 wrx. I have nearly every supporting mod you can think of and with this turbo am making, well rather insane power for the size. On 93 pump I'm nearing 370 whp on a mustang dyno. I will soon be swapping in the 8cm housing, EWG and probably meth. I'm hoping for 400 whp. It's been running at 24 psi for months with no issues, and recently tuned it to 28 psi and it's happier than ever, this thing loves boost, and it hadn't smoked on me once yet.
Went to a local drag strip the other day, ran all night. It didn't use one drop of oil, whereas my old vf39 used nearly half a quart. The quality of the turbo was truly surprising, from the machining to the laser engraving on the compressor housing. I've worked on things from Garret's to KKK turbo's and this ranks up there with the best, if not THE best visual quality turbo I've dealt with.
So far I've had 0 issues, fitment was spot on and was even given a great deal on one by a seller on eBay. Less than 800$ shipped. I couldn't be happier with my purchase. Thumbs up to kinugawa/ kamak!
Kill3rWill is offline   Reply With Quote
Old 05-22-2012, 02:49 AM   #56
jjasonn
Member#: 208653
2004 V-Limited
Spec C
nice! i have a td06sl2-60-1 with a 10cm and 3" cover! hope u like it because i like mine too!!
Old 05-22-2012, 02:50 AM   #57
jjasonn
Member#: 208653
2004 V-Limited
Spec C
so guys, cheap doesn't mean its bad. people who have actually used and tested them have all posted nothing but good reviews about them. so stop spreading malicious news about them just because they are cheap!
i hope this is the best proof for all of you who think that this is a bad turbo. reviews from all of us.
Old 05-22-2012, 06:14 AM   #58
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
Do you have a dynosheet or graph for your 60-1 twinscroll?
Old 05-22-2012, 06:30 AM   #59
jjasonn
Member#: 208653
2004 V-Limited
Spec C
not yet. i just got into an accident when im about to go for a datalogging session. once im done with my repairs i will post some loggings up with the dynograph!
Old 05-22-2012, 07:01 AM   #60
dingobite
Member#: 82391
08 OBP Sti
td06SL2, 20g 299hp 300tq
^^ Id like to see this id been considering one of these turbos the size of a 30r to get baked on for some time.
dingobite is offline   Reply With Quote
Old 05-22-2012, 07:04 AM   #61
dingobite
Member#: 82391
08 OBP Sti
Originally Posted by eg33GC View Post
It's nasioc, what do you expect?
They don't even know the FP green/red/black are MHI turbos with a billet wheel....
I thought there was just no trust for the company and not just the consumer end.
Old 05-22-2012, 07:14 AM   #62
CobbWRX
Member#: 310040
2004 WRX and 15 sti
Unless I find a good deal on an almost new 18g on nasioc I will be going with one of these! These turbos have good reviews from dsm owners also!
CobbWRX is online now   Reply With Quote
Old 05-22-2012, 08:14 AM   #63
jjasonn
Member#: 208653
2004 V-Limited
Spec C
Compressor Wheel: 59.5 / 76mm
Turbine Wheel: 54 / 61mm
as im driving a twinscroll, power comes very gradually unlike single scroll. this turbo if im not wrong can pull u hard all the way just that i didnt had my engine worked on so i stayed safe and only went up to 22psi on EJ207.
this is the compressor map of 60-1
Old 05-22-2012, 08:15 AM   #64
jjasonn
Member#: 208653
2004 V-Limited
Spec C
trust me. u will NEVER EVER be disappointed with the quality of these turbos.
once again. i emphasize, i DO NOT work for kamak/kinugawa. just a VERY VERY satisfied customer thats all.
Old 05-22-2012, 08:56 AM   #65
Dr. octagon
Member#: 171127
GDA BW 8375 SOLD
Kinugawa ftw
Dr. octagon is offline   Reply With Quote
Old 05-22-2012, 09:28 AM   #66
CobbWRX
Member#: 310040
2004 WRX and 15 sti
Where do you guys buy these turbos from?
Old 05-22-2012, 09:49 AM   #67
Dr. octagon
Member#: 171127
GDA BW 8375 SOLD
Old 05-22-2012, 09:49 AM   #68
Kastley85891
Member#: 127704
2015 Boosted Stang
MAP tuned
I think they are from NZ, use a lot of Jap/mitsi parts and will work AOK. I am biased though, JAPAN FTW ;-)
I believe they are popular with the Aussie guys to.
OP give it a shot and report back.
If you are worried go to turbochargers.com you can get a good deal on there with a more well known variant. Personally, Id use it.
Old 05-22-2012, 10:25 AM   #69
jjasonn
Member#: 208653
2004 V-Limited
Spec C
they have it for sale on ebay usa. not only nz. just search for kinugawa.
Old 05-22-2012, 10:46 AM   #70
Kastley85891
Member#: 127704
2015 Boosted Stang
MAP tuned
Yes they do , just I think they are built in NZ
Old 05-22-2012, 10:57 AM   #71
UK-Wagon
Member#: 232430
555 XTi
1 AW & 1 CGM
Screw ebay...... their web site is much better!! same prices too.
http://shopping.kinugawaturbo.com/turbocharger.aspx
Old 05-22-2012, 11:24 AM   #72
Kastley85891
Member#: 127704
2015 Boosted Stang
MAP tuned
You know what, I think Ill just get this and tune it up on E85...standby ;-)
http://shopping.kinugawaturbo.com/ki...s-3-2-1-1.aspx
Old 05-22-2012, 11:25 AM   #73
Kill3rWill
Member#: 287837
2005 WRX
Shows what you know about eBay and retail prices! Ever asked a vendor for a deal on a part? I hope so because they are making more profit on a retail part than you would think... Same goes for eBay vendors. 9/10 times if you send them a private message asking for their best price, they'll make a deal to, the seller I used Authentic-Boosting gave me 50$ off what the eBay price was. So no, not screw eBay. Sure their website is actually decent, but there's no one to get you a deal on anything.
Old 05-22-2012, 11:34 AM   #74
UK-Wagon
Member#: 232430
555 XTi
1 AW & 1 CGM
Id rather give my $50 the the manufacturer so I dont have to deal with a middle man when or if issues arise. Its my insurance to not have to take 12x longer to get a response or a warranty problem solved. Ever thought of it that way?
Old 05-22-2012, 11:54 AM   #75
Kill3rWill
Member#: 287837
2005 WRX
Completely understandable, but I'm fairly certain that the eBay seller I used is the largest US distributor for them. I'd ask him a question and he would actually contact kinugawa and get back to me no later than a day, usually within a few hours. The turbo came from kinugawa in Taiwan, came through customs. So all he is doing is telling them to ship it. He has been a very good vendor, but I've had experiences with bad ones. I had a return on a kinugawa wastegate actuator that I didn't end up needing, and he handled it quickly. Spend more money if you'd like, but this is one vendor who has earned my business. No matter which way you go, you'll have great customer service. I'd rather support the guy in the US trying to make some money.
turbos with anti surge holes(need pics) kaneda3 Member's Car Gallery 48 08-16-2007 12:15 PM
anyone have any experence with ANTI SURGE Kit? scobaru Motorsports 9 04-24-2006 02:09 AM
Nitrous and alky injection. Anyone try it? Rickyh Water/Methanol Injection, Nitrous & Intercooler Cooling 3 04-14-2005 11:55 AM
Ding King - Anyone try it on your Subaru? cashcow Interior & Exterior Modification 8 04-14-2005 06:59 AM
The new M3 shaver anyone try it yet? NiteKids Off-Topic 1 05-29-2004 10:09 PM
