Closed Thread
Old 05-22-2012, 10:01 PM   #26
Haunty
Member#: 319378
2012 2.0i Sport Ltd.
My dipstick doesn't even have a full line, just 2 holes. Is there supposed to be an actual line?
Haunty is offline
Old 05-22-2012, 10:28 PM   #27
jr0bb5
Member#: 315353
2012 Impreza Sp Prem
5MT OBP/DGM
The top hole is max oil level and the bottom hole is min oil level.
jr0bb5 is online now
Old 05-22-2012, 10:36 PM   #28
Haunty
Member#: 319378
OK, mine is 3/8" over max then, is that bad?
Haunty is offline
Old 05-22-2012, 11:55 PM   #29
79letour
Member#: 302570
2013 XV
DGM!
My dealer has twice now filled mine about 3/8 over the top hole.
I'm really worried. I've never had a car consume that much oil in that short a time. I don't think I want a brand new car that requires +/- $10/quart "top offs" with fillups at the gas station. That reminds me of my moms old Granada back in the day... And the pinto battery under the hood doesn't quite look like it belongs, or does it???
79letour is offline
Old 05-23-2012, 08:21 AM   #30
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
It could be that the ring hasnt seated just yet. Maybe it takes a little time if your running it at low rpms.
auskip07 is offline
Old 05-23-2012, 10:02 AM   #31
79letour
Member#: 302570
2013 XV
DGM!
Its not like I granny-drive the thing.
If the rings aren't seated at 7200+ miles, I don't want the damned thing. Everythings been fine. Consumption started in the lasat 1000. That is if it is in fact consuming oil.
79letour is offline
Old 05-23-2012, 10:09 AM   #32
79letour
Member#: 302570
2013 XV
DGM!
My car didn't consume oil the night I did 100mph+ the whole way home from the beach. Lol did ya know it only gets 4 mpg at 130?
79letour is offline
Old 05-23-2012, 10:30 AM   #33
jd_24
Member#: 318301
2012 CVT Sport Prem
Ice Silver Metalic
I guess that answers my question as to why the Impreza has a speedo that goes upto 140+.
jd_24 is offline
Old 05-23-2012, 11:41 AM   #34
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
Add me to the list, 4781 miles on the car, going 70 mph on a level highway my light came on. I pulled over, waited 10 mins, checked the oil and it was slightly below full.
Started back up, and it shut off after about 10 miles, I'm bringing it to the dealer tomorrow to at least get it on the books.
BrysImpreza is offline
Old 05-23-2012, 11:46 AM   #35
nubsub
Member#: 313575
2012 Impreza 2.0i HB
I find it hard to believe your oil is low if the dipstick doesn't say so.
Aside and maybe helpful: Did anyone see the odd TSB about them changing the oil meter? Really odd and can't remember the exact wording. It made it seem like they were referring to the dipstick. Check out the tech website and tell us what you think...
nubsub is offline
Old 05-23-2012, 11:48 AM   #36
79letour
Member#: 302570
2013 XV
DGM!
Sucks, buto be honest I'm kinda relieved I'm not the only one with this PROBLEM.
If you call SOA, ask for Desire' and tell her your buddy charlie's car does the same thing. That way they can't truthfully say "no one ese has reported this".
79letour is offline
Old 05-23-2012, 12:01 PM   #37
79letour
Member#: 302570
2013 XV
DGM!
Yeah. My dipstick only was about 1/8" below the last time I'd checked it.
My dealer is the one saying my car consumed 3/4 or so of a quart in 3000 miles. They added some oil and now my level on the dipsatick is about 3/8 or 1/2" above the top indicator hole.
79letour is offline
Old 05-23-2012, 12:43 PM   #38
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
Its so tough to say when you didnt check the level right after the oil change. It could have been like that from the start. Which means you're not burning oil and there is another issue. Which might be sensor related.
auskip07 is offline
Old 05-23-2012, 01:04 PM   #39
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
when they changed your oil, did they put on the correct filter?
flyboy1100 is offline
Old 05-23-2012, 01:10 PM   #40
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
This is all that i found
02-127-12
Bulletin Description: The purpose of this bulletin is to inform you of a change made to the oil level gauge and guide. On a rare occasion, there is a possibility that the oil level gauge could get damaged if too much force is applied when installing or removing it. As a result, the diameter of the oil level gauge was increased along with the inside diameter of the oil level guide (dip stick tube).
http://techinfo.subaru.com/search/listResults.html
auskip07 is offline
Old 05-23-2012, 01:39 PM   #41
nubsub
Member#: 313575
02-127-12
yes: that is what i was referring to (thanks for posting that. i wasn't on a regular computer it wasn't easy to jump around to get that info into my post).
not sure what it means as it suggests perhaps some change was made between perhaps different production cars. but i'm not sure what to make of this.
IMHO, the problem is not lack of oil, but either a bad sensor or the pressure is somehow off. i have never had a car where the dipstick isn't correct. that wouldn't make sense at all, IMHO.
and even if the car is down 3/4 qt, it seems a bit overkill to warn the driver at that level. the car should function just fine with 3/4 qt down, or even significantly more. (i'm not endorsing this, just saying...)
nubsub is offline
Old 05-23-2012, 01:48 PM   #42
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
agreed i doubt there is anything physically wrong with the engine. Maybe the parameters on the ECU are incorrect in measureing when the warning light for the pressure should be turned on. Of course wouldnt hurt to put a sandwich plate under the oil filter and attach remote sensor to measure the oil pressure. (one of my future mods just have to figure out where to mount it.
auskip07 is offline
Old 05-23-2012, 01:53 PM   #43
jd_24
Member#: 318301
2012 CVT Sport Prem
Ice Silver Metalic
Originally Posted by flyboy1100 View Post
79,
I'm curious on this as well. Edmunds Forum had a posting on this a couple months ago?? Seems the shop put a filter on for a Forester. The implied difference being the wrong filter type might allow the oil to drain back out of the filter.
jd_24 is offline
Old 05-23-2012, 03:00 PM   #44
jr0bb5
Member#: 315353
5MT OBP/DGM
Please correct me if I'm wrong, but I thought i had read that the 2012 2.0l Impreza and the forester used the same oil filter.
Old 05-23-2012, 03:10 PM   #45
nubsub
Member#: 313575
from what i understand, the Forester can use it's "old filter" (*130) and the impreza's newer filter (*160). the impreza 2.0i can only use the *160 model.
nubsub is offline
Old 05-23-2012, 04:17 PM   #46
subiTWO
Member#: 273054
2012 Impreza CVT HB
From everything I've read over the last 25 years, if you don't get the rings seated very early in the life of the engine, they don't ever seat, and you burn oil for the life of the engine.
subiTWO is offline
Old 05-23-2012, 04:47 PM   #47
nubsub
Member#: 313575
i agree. but 79's behavior doesn't make sense where it starts consuming oil in the past 1000 miles for no apparent reason.
again, i'm not an expert, but i don't think he's low on oil at all (i have no clue how the dealer says he is 3/4 qt down unless they drained the whole system
79: did they drain your pan to find that you really were down 3/4 qts?)\
i daresay they are just guessing. )
i know some cars "go over" the high mark dot when using the recommended capacity. so, i'm speculating (and that's all it is) that they are looking at the dipstick, seeing that it is below the high oil dot, and saying that he's short and 3/4 qt brings the mark up to where it would be if you changed your oil and added the 5.3 qts.
i always have used the high dot as a good indicator in all of my cars. i haven't changed my oil yet, but i'm guessing and hoping that 5 qts (a nice convenient amount considering i can buy that in one container) should bring me beyond the half way point between the two dots and be good enough. we'll see.
nubsub is offline
Old 05-23-2012, 04:49 PM   #48
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
i wouldnt count out your engine just yet. You are still covered under the warrenty for a long long time
auskip07 is offline
Old 05-23-2012, 04:50 PM   #49
79letour
Member#: 302570
2013 XV
DGM!
Its the proper "160" filter.
And auskiPro- I already stated that I did check the oil level after they changed it. It was way above full aso I took it back and they reduced the level to the top indicator mark.
I find this whole situation to be quite unacceptable. Rings have seated on every other car I've ever owned. It ran great since new, got better than epa mpg's right away. I followed subarus break in advice. The problem, whatever it is, is new as I check all my fluids very regularly.
79letour is offline
Old 05-23-2012, 04:56 PM   #50
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
Nice, Enjoy your car.
auskip07 is offline
Closed Thread
Are there any DIY independent fog lights write ups yet for 2012 impreza sports? JDMSTA Electrical & Lighting 59 07-21-2013 09:04 AM
2012 Impreza 2.0i Mobil1 oil filter model # jr0bb5 Service & Maintenance 27 01-04-2013 06:18 PM
('11-'14) OC interval and the first oil change on 2012 Impreza 2.0 Oceanguy Impreza Forum 80 11-18-2012 01:56 PM
My Oil Light is Flickering and I have No Leak??? kakarotoni Newbies & FAQs 39 08-16-2012 11:36 AM
('11-'14) 2012 Impreza High beams = Low beams lighting Jmzda Impreza Forum 28 06-01-2012 01:14 PM
