Old 04-19-2012, 05:07 PM   #726
xcdhridr
Member#: 58865
2004 WRX
99ESP - Drew =)
what are you doing with the old tmic
xcdhridr is offline   Reply With Quote
Old 04-19-2012, 09:31 PM   #727
mccanixx
Member#: 60566
2002 WRX Unicorn
2001 Legacy L 2005 XT 5sp
Idk. Do you want it, or know someone who does? It's kooky ya know?
mccanixx is offline   Reply With Quote
Old 05-23-2012, 11:10 PM   #728
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
Originally Posted by mccanixx View Post
Yes TD04. Haven't gotten there yet but either make the piping, or drill the center of the inlet side and weld a connector on.
Any update on your TMIC?
BeBop86 is offline   Reply With Quote
Old 05-23-2012, 11:18 PM   #729
mccanixx
Member#: 60566
2002 WRX Unicorn
No. Pretty sure a ringland or something went this past Sunday. Haven't done a compression check yet. Don't really need to though, it's borked. Accelerated the rebuild.
May go back to standard intake to alleviate intercooler woes. It'll allow a vertical flow intercooler. Idk in full think mode right now.
Old 05-24-2012, 11:17 AM   #730
sklindz2
Member#: 321182
I am so jealous of your wrx. Looks amazing!
sklindz2 is offline   Reply With Quote
Old 05-24-2012, 03:40 PM   #731
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
How many engines/ringlands have you gone through with this car?
Any ESP legal way to prevent it?
Old 05-24-2012, 03:42 PM   #732
sureshot007
Member#: 142405
#716 G5 Cherokee
nyscoob.com
Yeah - Fbody.
But what's the fun of that?
sureshot007 is offline   Reply With Quote
Old 05-24-2012, 05:30 PM   #733
mccanixx
Member#: 60566
2002 WRX Unicorn
Umm 2 engines. Still don't know the true issue with number one. Haven't done a compression check on the current. I'll do that tomorrow.
Bit of history. Feb 2009 change to a 2007 2.5 w/12K on it tune on 94oct at ~18 psi, car's fine the entire 2009 season. Spring 2010 tune to e85 at 24 psi. Starts smoking July 2010 compression check bad #'s...start the tear down and realize that the drivers side, center headbolts, are finger tight. Order new short block reassemble. Never investigate further, I still have the assembled block
Fast forward...down on power, sputtering, lots of oil in intake... we'll see.
So really lessons learned through the process. To correct the ringland issue if that is the issue in both, I will be having custom standard or .020 pistons made.
Other considerations are head studs, gaskets, etc to deal with the increased boostorz. The allowable head work, etc.
Originally Posted by sureshot007 View Post
Yeah - Fbody.
Werd. although I will be driving a sweet ass S197 for the Toledo pro....hoping I can out gun krauss in the DSM...or anyone in ESP there for that matter. lol
Old 08-11-2012, 12:19 PM   #734
mccanixx
Member#: 60566
2002 WRX Unicorn
Rut Roh. The first full 2.5 wrx esp engine build.
Probably won't make nationals this year and I'm pretty bummed about it. Mainly because the car should be much faster and more reliable in the engine department.
Short off season in S.D. so I have a bit of work to do.
Going to do somethings different in regards to fuel delivery, catch can etc. So I'll try to get back into it and resuscitate this :deadthread:
Old 08-11-2012, 12:31 PM   #735
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
Reliability would be nice
Old 08-11-2012, 03:22 PM   #736
CamaroFS34
Member#: 6850
Lots of ESP cars
'06 IAG WRX & LT1 Z28s :)
Good to see the engine in your hands. Now, get it in the car.
CamaroFS34 is offline   Reply With Quote
Old 08-12-2012, 09:52 AM   #737
Hold_Fast
Member#: 175837
#61 ESP
Awwwweeeesome. Looking forward to updates.
Hold_Fast is offline   Reply With Quote
Old 08-14-2012, 06:26 PM   #738
KpT KiM
Member#: 242422
'02 18G-XT 2.5L WRX
'01 RS Coupe
Are there forged pistons in this one? Stock compression?
KpT KiM is offline   Reply With Quote
Old 08-14-2012, 06:44 PM   #739
mccanixx
Member#: 60566
2002 WRX Unicorn
Pistons are custom .020 over JE's. So weight and dish are correct. Compression alteration will come from decking the heads to the FSM .012 limit.
Crank, rods are stock and balanced.
Heads were fresh'nd up as I had 6 intake valves leaking, no porting done. Rules allow 1" in. Everything you want is below that point so...
I'll wait for breakin and kinda guesstimate the CR from the compression readings.
All I'm hoping for is no more ringland, or engine issues really, and getting some off boost HP from the compression bump. IDK
Dig your car listing BTW
Old 08-15-2012, 02:56 PM   #740
KpT KiM
Member#: 242422
'02 18G-XT 2.5L WRX
'01 RS Coupe
Thanks! Hope the engine holds up. Been following your car since I first started really autoxing in high school. Fingers crossed I can start again soon. Gotta love bugeyes.
Old 08-15-2012, 03:40 PM   #741
gtsmicooo
Member#: 329233
Nice build so far
gtsmicooo is offline   Reply With Quote
Old 08-15-2012, 03:52 PM   #742
wrx wagone
Member#: 97301
2005 WRX Wag-Tow Rig
95 FM - QRE Invader
This sounds like something Greg would do. Looking forward to it.
wrx wagone is offline   Reply With Quote
Old 08-15-2012, 06:48 PM   #743
Mechie3
Member#: 120152
2006 06 WRX, 86 FMOD
Blue, White/Red
Did you at least gasket match the heads up to the 1" point? I did on mine, but can't really say if it made a difference or not.
Old 08-15-2012, 06:52 PM   #744
mccanixx
Member#: 60566
2002 WRX Unicorn
No. I thought about it and talked to people about it. The general concensus was, at these power levels, it would be insignificant.
I wish I had the $ and resources to determine "insignificant" though. :/
Old 08-15-2012, 06:57 PM   #745
sureshot007
Member#: 142405
#716 G5 Cherokee
nyscoob.com
I've been researching head porting lately as on option for the rallycar, and from what I've read, gasket matching doesn't always produce gains, and sometimes actually hurts. This is mostly because the gasket isn't necessarily the "master template" for proper airflow, and most of the time the real gains are inside the runners themselves. I've seen bench flow results from various attempts of gasket and port matching on Jeep heads, and I'd definitely agree with the notion that gasket matching isn't worth it. However, I haven't researched Subaru heads as much.
Old 08-19-2012, 11:46 PM   #746
loggingroadrally
Member#: 329649
Default Cool
thats an awesome sti.....
loggingroadrally is offline   Reply With Quote
Old 08-19-2012, 11:51 PM   #747
mccanixx
Member#: 60566
2002 WRX Unicorn
Awwwww. It's ok you're retarded. Really.
Old 08-20-2012, 08:45 AM   #748
ButtDyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 05 Saabaru
He was just posting **** to get enough posts to start this thread.
http://forums.nasioc.com/forums/show....php?t=2396446
ButtDyno is offline   Reply With Quote
Old 10-14-2012, 04:14 PM   #749
the-805-bugeye
Member#: 335087
0203 WTB : Bugeye
silver/white/black
love your car man.
the-805-bugeye is offline   Reply With Quote
Old 10-29-2012, 10:27 PM   #750
subiefan19
Member#: 336497
2002 wrx
black with green flames
like the wheels
subiefan19 is offline   Reply With Quote
CT: 2002 WRX, Project car, everything you need included! bdr2488 Private Vehicle 'For Sale' Classifieds 1 01-10-2010 10:05 PM
What are the differences between the 2002 WRX and the 2003 WRX? Red Rexx Newbies & FAQs 43 04-18-2008 07:02 PM
FS: Oakland CA 2002 WRX Project car ratboy Private Vehicle 'For Sale' Classifieds 2 04-04-2008 01:16 AM
feeler: 2002 wrx project car bWRX MAIC Private Classifieds 1 03-28-2008 02:53 PM
2002 WRX Project Car for sale. Scoob Private Vehicle 'For Sale' Classifieds 7 07-22-2007 12:43 AM
Message Board Statistics All times are GMT -4. The time now is 12:09 AM.
