Welcome to the North American Subaru Impreza Owners Club Monday March 2, 2015
Old 05-20-2012, 01:17 AM   #101
Junior2JZ
Member#: 64908
10.8 XT+10.0@143 GR+
2x9.0@170mph GTRs
Still rocking the 6265 for now. I want him to switch up to a 6466 once we hit our goal of 9.6s in a real deal street car. Then we go for some low 9s.
Jr
Old 05-21-2012, 03:11 PM   #102
slowgenius
Member#: 48350
0304 0712 WRX/Sti
What are your impressions of the 6265 as a daily driver?
Old 05-21-2012, 03:39 PM   #103
TehSubaruHasAPosse
Member#: 202580
04 AW STi
Jr
Jr what do you think the 6466 can do for a trap speed and power. This car is crazy and makes me want to copy it
-Aaron-
TehSubaruHasAPosse is offline   Reply With Quote
Old 05-22-2012, 12:13 PM   #104
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
I always said optimizing the exhaust wheel (EGBP) vs inlet pressure will result in faster spool, even with a bigger turbine wheel, turbine housing. Its all about matching everything up properly.
how Would one optimize this. Header/up-pipe, length, & diameter ?
Old 05-22-2012, 12:56 PM   #105
Junior2JZ
Member#: 64908
2x9.0@170mph GTRs
The 6266 would be my choice for all around perfect street car.
Properly setup you can expect to see boost in the low 4 high 3k range and make enough on 93 to go 10s and 9s on e85 easily.
-Aaron-
I expect this 6265 to trap in the 144-146mph range with the new gear box. The 6466 should get us into the high 140s low 150.
I don't think the owner really cares for that though, he just wants a 9sec pass and he will get it very soon. After that he might just be content with a mid 9s full weight street car.
Old 05-24-2012, 10:54 PM   #106
Md05STI
Member#: 76974
2005 CGM STI
10.03 @ 135
Junior, kinda off topic but couldnt remember your email to ask you this What size oil feed line should i use on my journal bearing 6766?
Md05STI is offline   Reply With Quote
Old 05-25-2012, 01:41 PM   #107
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
-4 IIRC -3an for ball bearing turbo's works fine.
Old 08-23-2012, 01:28 PM   #108
Junior2JZ
Member#: 64908
2x9.0@170mph GTRs
**Update**
Put the Missile back on the dyno last Friday to check the tune with the new gear ratios and setup the LC/Boost control a little better. She now sits at 670whp and on our first pass for the year cut a 1.50 60ft. Unfortunately the throwout bearing clip popped and we were left with no clutch.
The 1.50 alone would have put the car into the 9.9 range. I cant wait to see what the car will do with 1 less shift and 20-30whp more
Jr
Old 08-23-2012, 07:07 PM   #109
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
That's really alot of power for 6265. I didn't think they made that much without 34 plus psi. Bet it's fast!!
Old 08-23-2012, 07:08 PM   #110
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
Wonder what the 6266 would do if it would be much better.
Old 08-23-2012, 07:28 PM   #111
C J
Member#: 132587
2006 JrTuned STi
Stock block 10.34@134mph
Any street videos Junior?
C J is offline   Reply With Quote
Old 08-31-2012, 11:16 AM   #112
subarubruce
Member#: 203947
This thread has me super stoked about my 6466. Cant wait to get it in
subarubruce is offline   Reply With Quote
Old 09-01-2012, 01:18 AM   #113
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
super soaked!
Old 09-03-2012, 06:52 PM   #114
Junior2JZ
Member#: 64908
2x9.0@170mph GTRs
We are on a 3.5bar AEM map, so boost is being kept below 35psi. I want to say we are at 33-34psi now. No plans to go much more then that. We feel we have plenty of power to go 9s reliably.
I think the 66 CEA wheel would free up another 10-20whp at the same boost level. Its just is not worth the extra cash right now.
None that I am aware of
Originally Posted by spoolinsti05 View Post
super soaked!
Old 09-03-2012, 07:08 PM   #115
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
sweeet man good info.
Old 09-03-2012, 07:16 PM   #116
Junior2JZ
Member#: 64908
2x9.0@170mph GTRs
Sucks you are so far away from Miami. I will be down there for 2 week starting next Sunday. We could hit up the track with your car.
Old 09-04-2012, 01:01 PM   #117
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
if you meant me, i have the motor out to swap to a new sleeved block but id love for you to make some passes in it and lmk what you think of gear box and why it feels knotchy.
Old 10-04-2012, 01:13 AM   #118
Junior2JZ
Member#: 64908
2x9.0@170mph GTRs
Well back to the track, cut a 1.50 again missed 3rd, then cut another 1.50 and broke the output shaft.
P&L is on top of it and we hope to make some passes before the season ends.
The short time is ironed out, 1.50s every pass is pretty nice for a real deal street car. I cant wait to see it make a full pass.
Old 10-04-2012, 01:27 AM   #119
teesutt
Member#: 127940
Evil shenanigans
i went 11.3@128 tonight, 1.7 short time. Only second time at the track, still learning, but getting there.
teesutt is offline   Reply With Quote
Old 10-04-2012, 01:35 AM   #120
Junior2JZ
Member#: 64908
2x9.0@170mph GTRs
Very nice for your first time out. Lets get a slip break down, also what map were you on? The street one or the good one?
Old 10-04-2012, 01:37 AM   #121
teesutt
Member#: 127940
Evil shenanigans
the good one.
Old 10-04-2012, 01:41 AM   #122
Junior2JZ
Member#: 64908
2x9.0@170mph GTRs
Originally Posted by teesutt View Post
the good one.
We are missing about 10mph
Old 10-04-2012, 04:25 PM   #123
teesutt
Member#: 127940
Evil shenanigans
driver needs help.
Old 10-09-2012, 05:26 PM   #124
Junior2JZ
Member#: 64908
2x9.0@170mph GTRs
driver needs help.
Lets get to the track before the season ends!! End it with some mid 130s and 10s at least!
Cleared 05 sti headlights FOR stock 05 sti headlights GallardoKing NWIC Private Classifieds 4 11-07-2011 01:13 PM
FS : 05 sti Project Mu. Rear brake pads FO FREE!!!! sundayWRX Suspension/Brakes/Handling 10 01-04-2011 04:13 PM
05 sti project, soon on 18x9.5 rota grids stilv Member's Car Gallery 88 09-25-2009 05:04 PM
05 sti project car.. only 25k miles! michsti Private Vehicle 'For Sale' Classifieds 1 07-13-2009 04:06 PM
05 STi stage 2 dynotuned... at AMS? EarlQHan Proven Power Bragging 76 08-17-2007 03:57 AM
