Notices
Old 04-26-2012, 06:35 PM   #26
m0nkey
Member#: 142325
2002 WRX Wagon
MBP
I'm about to install a set of NGK BKR7E copper sparkplugs in my wrx and while I was gapping them i used pliers to decrease the gapping and it left indentations on the sparkplugs. I was just wondering is this ok to be used or should I buy another set?
PS: I got my coilpacks in the mail but waiting to see if the proper gapped sparkplugs will do the trick.
m0nkey is offline   Reply With Quote
Old 04-26-2012, 08:49 PM   #27
UK-Wagon
Member#: 232430
555 XTi
1 AW & 1 CGM
Bahhh now you have misfire codes man!? shoulda put that in your first post, that woulda helped.
Old 04-26-2012, 08:52 PM   #28
UK-Wagon
Member#: 232430
555 XTi
1 AW & 1 CGM
Originally Posted by m0nkey View Post
it only happens at wot or under hard accerlerarion. If I apply 30% throttle the car doesn't sputter but once I flat foot it, it goes down the drain. I will check out that hose tomorrow morning. Is there any possible way that when my injector started to leak it made the fuel pressure regulator to go bad? Is there anyway to test this? I ordered the coilpacks from rockauto so I know I can return them with no doubt.
Only way to check would be to install a fuel pressure gauge, tape it to the windshield and go for a quick drive while watching it under a load.
Old 04-26-2012, 08:59 PM   #29
m0nkey
Member#: 142325
2002 WRX Wagon
MBP
Well it's just showed up with a different map. Lol I wished I had a cel now I know what I'm looking for. But it doesn't matter all the time.
Old 05-10-2012, 04:39 AM   #30
m0nkey
Member#: 142325
2002 WRX Wagon
MBP
UPDATE: I replaced all the coilpacks and the fuel pressure regulator. I recently got a misfire in cylinder 1,2, and 3. Should I regap my sparkplugs to 0.025? And I am running rich, my car back fires.
Old 05-10-2012, 04:57 AM   #31
Garrek11
Member#: 227747
2006 STI (BW S363)
SGM
When you say sputter does it buck you back and forth in your seat or is it just a sound.
Check your A/F ratio if its bouncing around in between ritch and lean you will feel that.
If you cant feel the sputter and the car is hold boost all the way to redline this might sound dumb but it could be your EWG flutter that your hearing/feeling?
EDIT: You said he tuned the car and then the injector started leaking right? I wonder if the injector was leaking the whole time and he tuned it that way.
Garrek11 is offline   Reply With Quote
Old 05-11-2012, 01:25 AM   #32
m0nkey
Member#: 142325
2002 WRX Wagon
MBP
Here is a video of what i am talking about. Does this sound like wastegate flutter?
Heres a video from 1st to 2nd
heres a video of a 3rd gear pull
Old 05-11-2012, 03:23 AM   #33
Garrek11
Member#: 227747
2006 STI (BW S363)
SGM
Hard to tell but doesn't sound like it to me. Just sounds like something is clogged or a vac leak
Old 05-11-2012, 03:37 AM   #34
m0nkey
Member#: 142325
2002 WRX Wagon
MBP
Could my wastegate be bad? It sounds like its not opening all the way when I go wot. But at 30% throttle its fine.
Could the puttering be caused by a faulty PVC valve? I saw oil leaking on my engine head from this part that has a hose connecting it to the PVC valve.
Old 05-11-2012, 04:03 AM   #35
PSBeachBum
Member#: 279870
2005 WRX Wagon
Hmm I would say wastegate cant handle it. I dunno i a noob and felt like commenting. Spring your wategate actuator with a 5lb spring from home depot or whatnot. See if it holds the boost better
PSBeachBum is offline   Reply With Quote
Old 05-11-2012, 06:03 AM   #36
Shadow27AU
Member#: 287434
That hose is not even on properly. That would be causing a pre-turbo leak letting unmetered air in. This can cause your hesitation. Get a hose clamp on that, or replace with tighter hose.
Shadow27AU is offline   Reply With Quote
Old 05-11-2012, 10:42 AM   #37
Garrek11
Member#: 227747
2006 STI (BW S363)
SGM
Dude that hose coming off your intake right there isn't clamped probably your problem right there.
Old 05-11-2012, 04:07 PM   #38
Computersare8ad
Member#: 287080
2000 Fozz
Blaaaaaack
The fluttering sound is your wastegate... it is what external wastegates sound like as they dump into atmosphere. That is assuming you're using an external waste gate. If it is internal I would guess you do not have a downpipe. (Joke.. haha)
and omg please clamp that hose... not sure why it's twisted like that either.
Normally when you turn or reset your ecu it is a good idea to let it idle for a good long while then drive around easily on it for awhile before you start really hammering on it. (Not saying you didn't.. you just didn't say you did.)
Computersare8ad is offline   Reply With Quote
Old 05-11-2012, 04:49 PM   #39
dirtslayer
Member#: 242550
2002 impreza wrx wag
olive drab
Could very well be a leaky wastegate. Simple test. Use a rod, pin , zip tie, etc to secure wastegate arm from moving.
And yeah, pull out pcv and shake it, if it rattles its fine.
dirtslayer is offline   Reply With Quote
Old 05-11-2012, 07:44 PM   #40
m0nkey
Member#: 142325
2002 WRX Wagon
MBP
Dont worry guys I just put on a clamp on that hose.
I think that would work on an internal wastegate but not on my external.
I have another problem now maybe its related to my symptoms. I was at advance auto parts and when i was leaving to turn on my car it would just crank and crank but it wouldnt start. Then finally it fired up very slowly stumbling. Any ideas? Im think about regapping my sparkplugs smaller.
Old 05-12-2012, 12:40 AM   #41
Garrek11
Member#: 227747
2006 STI (BW S363)
SGM
Whats your vacuum at now that you put a clamp on there?
Old 05-12-2012, 01:34 AM   #42
m0nkey
Member#: 142325
2002 WRX Wagon
MBP
Still the same -12 / -10 with ac
Old 05-12-2012, 01:42 AM   #43
Garrek11
Member#: 227747
2006 STI (BW S363)
SGM
Try a diff gauge from a local or something...cuz if it reads the same then you still have a vac leak somewhere.
Old 05-12-2012, 01:56 AM   #44
kimokalihi
Member#: 186972
91 Legacy SS EJ20G
Pearl White
I think you have several leaks here most likely. PCV system is almost certainly leaking with a hose like that and if that hose is that way I would suspect other hoses are also not up to the task. Also, why do you continue to seek advice and troubleshoot a problem with a vac leak like that? You know there's a leak because as it's been stated before the vac gauge should be around 20" (it's not -20, it's 20") without a leak in the system. I recently found a vacuum nipple under my throttle body that I was not aware of which wasn't hooked up and it was idling at about 18" and now it's idling at 21" vac.
Fix the vacuum leak. Then go from there if the problem persists. I haven't had much success with spraying carb cleaner. Bring it to a shop and have them hook up a smoke machine to it to verify there's no leaks.
kimokalihi is offline   Reply With Quote
Old 05-25-2012, 02:04 AM   #45
ukranianization
Member#: 238506
2003 wrx
Psm
not trying to thread jack, just a quick question...so if I'm idling at 16 on the vac gauge, theres a good possibility that i have a vac leak?
ukranianization is offline   Reply With Quote
Old 05-25-2012, 02:08 AM   #46
dirtslayer
Member#: 242550
olive drab
Yea.
Smoke test it
Old 05-25-2012, 02:30 AM   #47
ukranianization
Member#: 238506
2003 wrx
Psm
Yea.
Smoke test it
hmmm alright thanks...cuz I'm also misfiring in all four cylinders ...so I'm sure thats a big part of it
Old 05-25-2012, 07:59 AM   #48
Honest Bob
Member#: 94698
2005 30R Wagon
CGM
PS that extra wire on the passenger side of the engine bay is probably for the EGT that used to be in the uppipe.
Honest Bob is offline   Reply With Quote
Old 06-05-2012, 12:20 AM   #49
ukranianization
Member#: 238506
2003 wrx
Psm
monkey, did you end up solving your problem or no?
Old 06-15-2012, 04:49 AM   #50
m0nkey
Member#: 142325
2002 WRX Wagon
MBP
No figured out that connector was for my tgv motors. I purchased a pair of tgv deletes so now I zipped tied them down. I have a grimmspeed external wastegate up pipe so that get is deleted and I installed the resistor to turn off the CEL.
Well after reading quite a bit of threads on nasioc, I saw a video of another sti with the same problem and it's because of my grimmspeed ebcs. Another person said that it's normally with a ebcs but a good tuner should be able to tune it out. I'm going to get a retune at Cobb hopefully its gone forever.
hesitation when tapping gas, no boost reading on ap after inlet install drewvdw Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 08-05-2011 10:43 PM
wrx sputtering, but only when it's wet outside? 1WRX0003 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 01-09-2009 10:45 AM
hesitating when full boost g-unit555 Legacy Forum 3 08-10-2008 01:44 AM
Stumbles/Hesitates when under any kind of boost. NITROS UTEC 3 08-16-2007 10:52 AM
Hesitation when car hits full boost (sometimes) JDM_Scobaru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-14-2005 11:35 AM
