Old 05-19-2012, 07:49 AM   #1
Dirty_WRX
Member#: 258491
2002 VF34'd Bugeye
My Other Ride's your MOM
Default Running rich 12.0-13.7 @ idle
So I just finished my vf34 swap and I noticed my WB was reading very rich at idle. During normal cruse its 14.7+-.8. The only thing that I did weird was I took the tgv sensors off and luded the mating gaskets. I noticed the flap slamed shut so I preloaded them and reinstalled the sensor.. Since it only seems to happen at idle it makes me think I didnt get the tgv senors on there right. I cant seem to find a proper sensor install instructions.Now I havent gave it WOT yet... Still data logging but nothing standing out like a sore thumb..
Ive looked over all my hosesmose of them are brand new oem replacements. so I can kind eliminate leaks to an extent..bit the wild card is that the base map is for a vf39 &GM EBCS while I have a vf34 & grimmspeed ebcs. Now im not sure if the wgdc would effect it enough to do this so advice is appreciated
Dirty_WRX is offline   Reply With Quote
Old 05-19-2012, 02:33 PM   #2
quazimoto
Member#: 70395
The WGDC has nothing to do with fueling. Sounds like your front O2 sensor is taking a crap possibly.
Old 05-20-2012, 12:57 AM   #3
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
What MAF? -Speed Density!
did you put in new injectors with the larger turbo?
Old 05-20-2012, 06:07 AM   #4
Dirty_WRX
Member#: 258491
2002 VF34'd Bugeye
I heavily dought the front o2 is going bad i replaced it with a new oem sensor a few months ago
and yes i got some 565 pinks in there...
Old 05-21-2012, 12:59 PM   #5
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
thats why putting in bigger injectors without a tune will do that!
Old 05-21-2012, 03:24 PM   #6
quazimoto
Member#: 70395
He has a tune according to his first post.
Old 05-21-2012, 09:57 PM   #7
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
It doesn't state the base map has the injectors
Old 05-28-2012, 09:07 AM   #8
ssssly
Member#: 268627
05 SpecC/FFR818
You need to rescale your injectors. For pinks your Scaler should be 552.47 and your latencies should be
6.5 9.0 11.5 14.0 16.5
2.79 1.49 0.98 0.68 0.38
If they are already set to this, either you have an injector that is sticking open or your front o2 crapped out again. To test for the o2 just unplug it while the car is at idle. If the problem goes away it's your o2. If not its a sticky injector.
ssssly is offline   Reply With Quote
Running Rich and Rough Idle after runs for a while 0wrx6 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 04-15-2011 12:23 PM
Running rich during highway use and idling spyders03 UTEC 8 12-20-2009 12:49 AM
ej207 v5 swapped from vf28 to vf34 not runs rich @ idle impreziv25 Subaru Conversions 6 05-24-2007 04:46 PM
Running rich at idle but only while fans are on..?? SubieStylez Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-01-2006 08:56 PM
1.8 idleing running rich problem scobaru Normally Aspirated Powertrain 3 04-07-2005 04:53 PM
