Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 05-27-2012, 11:25 AM   #901
2.5 turbo hyped
Member#: 158810
2005 STI and Baja
Originally Posted by schochwave View Post
Pages 51 and 61 on this thread.
This is page 37
2.5 turbo hyped is offline   Reply With Quote
Old 05-28-2012, 01:47 AM   #902
BajaSTI04
Member#: 121071
2004 Baja STi
TeamJDMFresh.com/CSJ
Originally Posted by 2.5 turbo hyped
This is page 37
It is being viewed on a phone app. So page #'s are different. So just search this thread and find the answer you seek. :-)
BajaSTI04 is offline   Reply With Quote
Old 05-29-2012, 10:59 PM   #903
Hawk296
Member#: 14555
1995 Impreza L
Baja
Now if I only had the funds to do a TFE-731 swap in the bed of the Baja. 3,650 LBS of thrust would almost be enough to go vertical.
Hawk296 is offline   Reply With Quote
Old 05-30-2012, 12:34 AM   #904
schochwave
Member#: 253456
2005 WRX STi/Baja tu
black/gray,silver
This is page 37
casteater is the owners name on here. There's a before and after pics.
schochwave is offline   Reply With Quote
Old 05-30-2012, 12:37 AM   #905
schochwave
Member#: 253456
black/gray,silver
What rims are you running? They look good on the Baja.
Old 05-30-2012, 12:44 AM   #906
Hawk296
Member#: 14555
1995 Impreza L
Baja
Those pictured are 17" BBS RKs
Old 05-31-2012, 08:48 AM   #907
lumpy
Member#: 28410
2012 Impreza Sport
Sorry for the cross-post, but I am selling my winter/offroad wheel setup. I am going a bit lower and these aren't going to work anymore...
Here in Midwest Classifieds
Nevermind...SOLD!
lumpy is offline   Reply With Quote
Old 05-31-2012, 06:45 PM   #908
BajaSTI04
Member#: 121071
2004 Baja STi
Talking BajaSTi Monster build
So it has been a little while since I have posted any mods to my baby, but this might explaiin why...lol
So here goes:
Cosworth Piston 100mm 8.2:1cr 850.00 850.00T
Cosworth Piston Ring Set
Cosworth Connecting Rod Set
ACL Main Bearing
ACL Race Rod Bearings
STI Head Studs ARP
R&R engine, disassemble the block, inspect and blueprint.
Rebuild Heads
Kelford Stage 2 Cams
Standalone Automatic DCCD controller for JDM and USDM 6 speed
GT 30/76 turbo
44mm ewg
1000cc injectors
side feed rails
cobb ap
91 summer tune
91 fun tune
109 race tune
E85 race tune
I will be having all this work done by Joe @ Goodspeed in AZ. I should be taking her in any day now and hope to get her back by the end of July. I eill post updates as I can. I also think Car Street Journal.com might do a small artical on the BajaSTi! Yay!!!!
Old 05-31-2012, 09:33 PM   #909
2.5 turbo hyped
Member#: 158810
2005 STI and Baja
So here goes:
ACL Main Bearing
STI Head Studs ARP
Rebuild Heads
GT 30/76 turbo
44mm ewg
1000cc injectors
side feed rails
cobb ap
91 summer tune
91 fun tune
109 race tune
E85 race tune
Lose the cobb ap and go open source.
Did you get an A/T baja driveshaft for the sti tranny??
Old 05-31-2012, 10:05 PM   #910
BajaSTI04
Member#: 121071
2004 Baja STi
Have open source had ap and want to go ap again but thanks. Yes the a/t drive shaft is the way to go.
Old 06-01-2012, 03:01 PM   #911
machinegreen
Member#: 100818
2005 Baja Sport
Dark Blue Pearl
What about the axles?
machinegreen is offline   Reply With Quote
Old 06-01-2012, 03:41 PM   #912
BajaSTI04
Member#: 121071
2004 Baja STi
I had a shop do the swap and they used an 06 sti trans it it works great.
Old 06-05-2012, 09:56 PM   #913
2.5 turbo hyped
Member#: 158810
2005 STI and Baja
I will be taking the same route as you are except I will never pay anyone to do the work. I will do all of it myself.
The a/t driveshaft out of the baja is not only a good idea but it is a must for the 6 speed STI swap.
Your final drive must match as well.
As for the dccd did you use the coin tray in the center console to install the dccd switches? They make a snap in solution by using the heater switch surround in that spot.
Take pictures, don't keep that knowledge of what has/hasn't been done all bottled up.
Post a time slip in the 1/4 as well. I have always been curious of that in a baja.
Old 06-06-2012, 09:16 AM   #914
slagman
Member#: 214691
2005 Baja Turbo
Originally Posted by honda killer View Post
This has been a life time goal for me!
Please share some more pictures.
Did you install dampers?
Is it water tight?
What metal did you use; aluminum or steel?
How much did it cost?
BTW Good job, looks clean
Hey man, sorry I did not take more pictures during the process.
I used 5x8 diamond plate aluminium I picked up from a warehouse that sells metal in Brooklyn. I already had a template from the marine board I tried to use the first time but it warped. Cut it with a jigsaw. I used aluminium bars I got at home depot for support underneath and just bolted it down since I really don't need it to open vertically.
slagman is offline   Reply With Quote
Old 06-06-2012, 09:19 AM   #915
slagman
Member#: 214691
2005 Baja Turbo
Originally Posted by machinegreen View Post
I've always wanted to replace my finders like that and take off all the side molding. But what I've always wanted to do is this, But I'm rethinking the wide body finders.
This is a sick drawing by the way, I think the Baja would look great like this. Very unique.
Old 06-06-2012, 01:49 PM   #916
BajaSTI04
Member#: 121071
2004 Baja STi
Well doing the work your self makes it cheaper for sure, how ever I don't have the time or the experience. If the fact that I take it to a professional shop seems less legitimate then your build am sorry. I am glad that you then ask for my knowledge. The DCCD is not installed yet and I have not figured out were it is going yet. I am droping the car off this week. Since I also started this thread in 7/06 all the mods I have done are posted. My best pass in the 1/4 is [email protected] Have a nice day and stay positive everyone!
Old 06-06-2012, 02:21 PM   #917
machinegreen
Member#: 100818
2005 Baja Sport
Dark Blue Pearl
Thanks, that's not the only one.
Old 06-07-2012, 04:08 PM   #918
Ti Pit
Member#: 146009
2005 Legacy GT Wagon
Awesome!
Ti Pit is offline   Reply With Quote
Old 06-07-2012, 06:36 PM   #919
2.5 turbo hyped
Member#: 158810
2005 STI and Baja
Laugh if you want, but this was a free mod and it works EXTREMELY well.
Normally I was datalogging 120-150 degree IAT's. Most I can get it up to now at a dead stop is 91 degrees. The temp drops 10+ degrees in 3 blocks @ 30 mph. Holds a steady 12 degrees above ambient while moving.
Best free mod ever!
For those wondering, it is an old optimum nutrition 6 pound whey protein canister. I cut the bottom part of the snorkus off (in the wheel well) and sealed it up with gorilla pvc tape. The lid has a 3 inch airtight hole cut in it and attaches to the snorkus. You can place your hand inside the ram air part that attaches to the radiator mount and feel the air being drawn in.
I am still in disbelief at how well it works.
Old 06-08-2012, 09:39 AM   #920
Samirr76
Member#: 4835
2003 Baja 5MT
Yellow w/ 220,000 miles
I always appreciate the home-grown DIY mods like that. I won't laugh at ya. You should see my jury-rigged engine bay! =)
Samirr76 is offline   Reply With Quote
Old 06-16-2012, 07:24 PM   #921
DerrickRH
Member#: 75078
2000 Legacy GT
Black Granite Pearl
I just did this one today with guidance from a DIY thread on scoobytruck.com
DerrickRH is offline   Reply With Quote
Old 06-26-2012, 07:14 PM   #922
Emsanon
Member#: 152508
2003 Baja
Good ol' Classic Yellow!
Finally got my ~2" lift on my 2003. Hmmmm, it was actually about a month ago I had it done. I like it.
Emsanon is offline   Reply With Quote
Old 06-26-2012, 08:08 PM   #923
BajaSTI04
Member#: 121071
2004 Baja STi
Pics?
Old 06-27-2012, 04:21 PM   #924
Samirr76
Member#: 4835
2003 Baja 5MT
I would love to see pics. I also have a 2003 with a lift kit waiting to be installed. Which lift kit did you get?
Old 06-28-2012, 08:41 PM   #925
Emsanon
Member#: 152508
2003 Baja
I had my local custom shop make me the lift since no one could find a lift that fit our vehicle.
I just took the after lift pictures. It's funny that the pictures don't show much..but then, it is only 2". They didn't want to go any higher because they didn't want to put too much stress on the CV joints. It sure feels higher when driving it.
Before the Lift:
After the Lift:
Up to date pics & mods edoublepo Member's Car Gallery 4 10-09-2006 08:48 PM
Modded PStwo (slim) & Modded Gamecube llhype12ll Private 'For Sale' Classifieds 2 11-15-2005 01:28 PM
couple of pics & mods list WRX Ver.7 Member's Car Gallery 15 08-01-2002 01:40 PM
How to change pics & mods? mav1c Mid Atlantic Impreza Club -- MAIC 6 08-28-2001 12:51 PM
STI 3 Pics & 340HP Mods Hyperex Member's Car Gallery 38 07-06-2001 06:20 PM
