![]() Tire & Wheel Forum sponsored by The Tire Rack |
#751 |
Member#: 234357
Vehicle:2009 WRX Sportwagen zum einbauen! |
Finally!!
![]() TSW Nurburgring 18x8 +45mm Continental ExtremeContact DW, 235/40ZR18 No fender mods, no where near rubbing anywhere RCE/GTworx Bilstein setup with RCE Yellow springs Front camber -1.2, Rear -1.8 (factory) ![]() ![]() Slighty inside front fenders ![]() Wheels themselves, Just down from the lift, not settled yet. ![]()
#752 |
Member#: 57593
SCIC
Vehicle:2008 WRX Hatch WRB |
Nice looking WRX Brezio! I have the same tires and suspension.
#753 | |
Member#: 320510
W. Canada
Vehicle:2010 WRX Sedan DGM |
This guy said he was rubbing with 18x8 +45 with 235/40/18s on stock suspension. Does His 09 WRX Hatch has very similar or exacty same fenders as my 2010 WRX Sedan? His are poking out a little. If I put 8.5" at the same offset wide rims on, they'll poke out more... Now this is a different story. Rubbing i can solve with a fender finisher roll tool for 50 bucks from Eastwood and a heatgun, but now Im concerned about Pokage! Poking out to me means more chance of rock chipping the side of my car on gravel roads. Im going to call it a night and search for 18x 8.5 side view pics on 3G Wrxs tomorrow, Please post if you have some examples handy. |
#754 |
Member#: 234357
Unless your camber is out of wack, you shouldn't poke with 8.5 width and +44.
About that WRB hatch with the same wheels as me.... his 'poke' way more then mine do. So I'm betting either his front camber isn't good, AND/OR he actually has the +35mm offset version of the 18x8 nurburgring. Plus they also have the 'run wider' star specs. |
#755 |
Member#: 234357
And if you look at his front picture
http://forums.nasioc.com/forums/show...&postcount=147 And compare it to mine posted above, his is a fair amount farther out. Would be nice to figure out exactly why. |
#756 |
Member#: 237756
Vehicle:2011 2.5i Sedan DGM |
Breezio - once again, I love your car! I'm planing on the 17x8+45 TSW's because 2.slow haha
#757 | |
Member#: 234357
So I don't know how they ship out from Subaru, HOWEVER, front camber on a 3g WRX is considered 'in spec' by Subaru if it's anywhere from -.8 to .6 positive! holy smokes... who would have thought.. ![]() |
#758 |
Member#: 243234
Vehicle:2009 Hatch OBP |
Might as well post up my new setup
18x7.5+44(or 40 lol) Maxxim maze w/ 235/45/18 hankooks ![]() ![]() ![]() Last edited by WinterSubie; 07-13-2012 at 03:25 PM. |
#759 | |
Member#: 235475
PRSIC
Vehicle:2008 WRX Silver |
#760 |
Member#: 223799
South East
Vehicle:2009 WRX Silver |
Anyone running the Mach V Awesomes on their car? I am contemplating getting these but I am not sure if they will fit on my car. My suspension mods are Tein Springs, Whiteline F/R Sways and I forget the name of my rear camber kit some European brand I found on one of threads here. I am worried they will rub on my front struts. not so worried about having to roll my fenders.
#761 | |
Member#: 235475
PRSIC
#762 |
Member#: 223799
South East
I guess I should have been more specific they only come in one size 17x9 +42 it was just me being wishful that someone on here would have them and what they had to do to make them fit i.e. rolling fenders and or coilovers required.
#763 |
Member#: 236952
Vehicle:2010 WRX Spark Silver |
youd probably need a little roll. not much else. will depend on the tires.
i run a 17x9 +44 with 245/40/17 with no fender mods |
#764 | |
Member#: 235475
PRSIC
#765 | |
Member#: 223799
South East
#766 |
Member#: 234357
+44 shouldn't have any strut clearance issues unless you are putting some pretty wide tires on there.
#767 |
Member#: 236952
Yup. I clear just fine.
#768 |
Member#: 237756
#769 | |
Member#: 208073
Vehicle:2009 wrx |
#770 |
Member#: 236952
#771 |
Member#: 236952
eh ill post it again, just because i DID just change some things in the suspension from what i previously posted. I used to have Epic Engineering springs, but the drop is about the same, the RCEs are just a little stiffer.
RCE black springs Koni Sport/Yellow dampers 22mm whiteline rear sway bar (doesnt really matter for wheel fitment) 17x9 +44 Work Emotion CR Kai 245/40/17 Continental ExtremeContact DW no fender work at all. |
#772 |
Member#: 234357
Looks great, most everything I read said that fitment would work without fender mods.
I had at one time contemplated doing a 255/35r18 on a +44 or +45 wheel, though It seemed that would need some roll in the rear. |
#773 | |
Member#: 223799
South East
#774 |
Member#: 320510
W. Canada
Got 18x8.5 +44 Rota Grids in Hyper Black on PreOrder from WheelDude! Stoked, getting Bridgestone Potenza RE11s in a 235/40/18. I expect no rubbing with stock suspension. Should be here by Canada Day!
#775 |
Member#: 235475
PRSIC
Offset 40? Is that right? There are offset 44's that stick out a bit more than that, and seeing no fenders rolled makes me wonder if it's really offset 40.
