Old 05-31-2012, 10:22 AM   #51
masterforce
Member#: 221580
2011 WRX STI
awesome thread! keep them pics coming!
masterforce is offline   Reply With Quote
Old 05-31-2012, 10:25 AM   #52
Buck 05STi
Member#: 300281
05 STi PSM Stg 2
Finally here is a headlight restoration I personally did
[/quote]
What did you use to do the headlight restoration?
great pics btw! keep 'em coming!
Buck 05STi is offline   Reply With Quote
Old 05-31-2012, 10:38 AM   #53
KC
Member#: 442
13 Crosstrek XV
00 S2000
I'm going to assume bought and replaced the assembly, which almost any monkey with a wrench should be able to do in their driveway. (That's what I would have done...)
--kC
KC is online now   Reply With Quote
Old 05-31-2012, 10:39 AM   #54
KC
Member#: 442
13 Crosstrek XV
00 S2000
Yay! double post forum hiccup!
Old 05-31-2012, 10:40 AM   #55
Jdub.csu
Member#: 283784
2013 EVO X GSR
Originally Posted by KC
I have a random misfire in my S2000 with 185k miles on it, only at idle, cyl 2. CE Light is on.
What's wrong with it?
--kC
What's the code? Might be able to give you the most common failures but that's about it.
Jdub.csu is offline   Reply With Quote
Old 05-31-2012, 10:49 AM   #56
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Can you help with this?
Old 05-31-2012, 10:55 AM   #57
WhiteKnightSTi
Member#: 169250
2001 Schweizer 300CB
(wirlybird)
I run a small service department, seen a few gems over the years. There is no way anyone can work in this industry and still have faith in humanity.
Some highlights:
-Remember those "tornado" air filter inserts? Found a homemade one (as in a bit of sheet-metal cut with tin-snips and bent into shape) stuck in someones MAF
-Had a kid that drove his car off the road, over some rocks, bashed a hole in the oil pan... then drove it home... One less VR6 Jetta on the road now.
-Just yesterday we had someone drop off a Dodge Caravan who wanted the A/C lines to the rear A/C unit replaced (big job). Do you want us to diagnose it? Nope, just do it. Guess what buddy, the lines weren't your problem.
I also do Emissions testing, on 1996 and newer cars it's just a simple OBD test, so we know that if the MIL is on they're going to fail. I try to be nice and tell people before we do the test, you wouldn't believe the grief I get. "No that's not because of an emissions problem, I just need an oil change" or "my mechanic told me it was just a sensor and I shouldn't worry about it" or "The kid at autozone told me is was a o2 sensor so I replaced it but the light is still on" Ect...
Yet somehow it's my fault when they fail
I can't wait to get out of this industry...
WhiteKnightSTi is online now   Reply With Quote
Old 05-31-2012, 11:01 AM   #58
Jdub.csu
Member#: 283784
2013 EVO X GSR
a long lasting solution:
Before sanding tape off around headlight:
wet sand the old stuff off the head light. use 600 grit and slowly work your way to 1000 grit. If there is bad pitting work up to 3,000 grit.
Best practice is to use an air powered disk because it speeds things up
This is what it will look like after sanding you want nothing to look shinny (this is a different headlight by the way)
Then clean the headlight with a good cleaner that doesn't leave residue (denatured alcohol). Allow the alcohol to evaporate, use a hair dryer or heat gun to make sure its all gone
Then spray with renulight. You spray this on thick, not like painting at all you want it to run to the bottom of the headlight. Basically follow the instructions on the can. After spraying and letting it to set for about 10 mins, make sure there are no more runs and put car under the sun. So it needs to be a sunny non windy day, or you can put UV lights on the lights to cure inside (takes much longer). They will look brand new if you take your time. We do this at the shop and get payed 100 to do it, with a 3yr/36k warranty. Works great.
Here is a link to the product we use
Old 05-31-2012, 11:03 AM   #59
Jdub.csu
Member#: 283784
2013 EVO X GSR
Bahaha holy ****
Old 05-31-2012, 11:05 AM   #60
Jdub.csu
Member#: 283784
2013 EVO X GSR
Originally Posted by WhiteKnightSTi View Post
I also do Emissions testing...
I HATE EMISSIONS. Run by the state and the ones that usually fail are huge POS and the owners have no money and want it fixed for nothing.
Old 05-31-2012, 12:09 PM   #61
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
And the customer said... "It just started making noise this morning".
Old 05-31-2012, 12:12 PM   #62
NitroTrike
Member#: 62408
2002 wrx w/ STi guts
174k miles on Mobil 1
'What do you mean "replace it"? My buddy says rotors can be resurfaced..'
NitroTrike is offline   Reply With Quote
Old 05-31-2012, 02:54 PM   #63
WhiteKnightSTi
Member#: 169250
(wirlybird)
Isn't it sad that this is exactly the same joke I was going to make?
People suck.
Old 05-31-2012, 03:14 PM   #64
Jdub.csu
Member#: 283784
2013 EVO X GSR
People suck.
I hear that all the time for metal on metal brakes.
Old 05-31-2012, 03:53 PM   #65
WhiteKnightSTi
Member#: 169250
(wirlybird)
The worst one I ever saw was a rear rotor (not vented) that was literally paper thin and had actually separated from the hat, leaving just a flat ring of metal.
Of course me and the tech spent the next ten minutes throwing it at an old cardboard box doing our best Xena impression
The brake pads had long since fallen out and the pistons were following close behind. But according to the customer it had only been making noise since yesterday
Old 05-31-2012, 08:37 PM   #66
AWDailyDriver
Member#: 286205
2004 WRX
Awesome thread. Stupid title. MOARRR plz!!!
AWDailyDriver is offline   Reply With Quote
Old 05-31-2012, 08:48 PM   #67
MY EJ20TTTTTT
Member#: 275239
2002 Rallying WRX
Rock chipped MBP
I didnt know tire patches were for the outside of the tire!!
MY EJ20TTTTTT is offline   Reply With Quote
Old 05-31-2012, 09:09 PM   #68
markesc
Member#: 164875
2007 WRXTR blouch20G
They're lucky to be alive...then again... natural selection? ?..
markesc is offline   Reply With Quote
Old 05-31-2012, 10:08 PM   #69
Jdub.csu
Member#: 283784
2013 EVO X GSR
Who would of thought that finding parts for an evo would be such a pain.
From our usual suppliers, not online.
But he is fixing some things so that's good
Old 06-01-2012, 07:45 AM   #70
Rodeoflipper1818
Member#: 193977
2007 2.5i Wagon
2004 Honda RC51
And to think I had lost all faith in the threads that come up in General.
This though, this is quite something. Keep them coming.
Rodeoflipper1818 is offline   Reply With Quote
Old 06-01-2012, 09:20 AM   #71
Tony JDM
Member#: 207532
1999 Impreza 2.5RS
Rusty Black Diamond Pearl
+1 I forgot I was in General for a few minutes, good thread.
Tony JDM is offline   Reply With Quote
Old 06-01-2012, 09:39 AM   #72
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
I pulled apart one of those.
His brakes howled for about a year before I finally convinced him to just let me fix it. Pistons and sliders were seized on that corner.
Old 06-01-2012, 09:55 AM   #73
meanjoaquin
Member#: 309723
^ They're just slotted rotors, what's the big deal?
Yes I'm joking
meanjoaquin is offline   Reply With Quote
Old 06-01-2012, 10:36 AM   #74
moose00015
Member#: 180924
2007 Impreza WRX STi
2004 Forester XS Premium
I've seen someone driving on a rotor like that in Philadelphia before. It made the worst sound imaginable...
moose00015 is online now   Reply With Quote
Old 06-01-2012, 10:49 AM   #75
Traffic Baron
Member#: 316645
2012 WRX Base Hatch
I don't see the problem They still have one good brake pad, so they're fine. I think you guys are just trying to rip off the customer
Traffic Baron is offline   Reply With Quote
NASIOC, sometimes I hate you so much! Jard Off-Topic 50 08-25-2010 10:55 PM
sometimes i hate my job koolaideprived Off-Topic 17 07-01-2004 11:06 AM
Sometimes I hate suspense... LinuxGuy New England Impreza Club Forum -- NESIC 21 03-07-2003 10:03 AM
Sometimes I Hate Living Where I Do... S-K South East Region Forum 1 09-24-2002 11:51 PM
