Welcome to the North American Subaru Impreza Owners Club Sunday February 7, 2016
Old 06-01-2012, 02:54 PM   #1
2JZ
Member#: 291949
Default Negative Camber: When is there ever to much?
I have Whitleline COM-C top hats and camber bolts on the bottom and got a whopping negative 3.0 camber in the front of my wagon.
The alignment was free and I didn't want that much but he was busy and had to let me go.
Results? From -0.7 to -3.0 is night and day. The car handles so much better, however it is a little violent now. Before it would do a oversteer slide gradually. Getting the car to break traction and oversteer is a little more snappier and dangerous.
I imagine tire wear is going to be insane... I'm thinking of ordering new OEM bottom bolts, throwing the camber bolts out and going to something like -1.8.
Anyone ever run -3.0 on their daily driver? I'm worried my tires are going to disappear.
2JZ is offline   Reply With Quote
Old 06-01-2012, 03:09 PM   #2
Badler
Member#: 133597
That's too much on a DD IMO. I would do ~2F and ~1.5-1.75R. As long as the toe is good tire wear shouldn't be much of an issue.
Badler is offline   Reply With Quote
Old 06-01-2012, 03:10 PM   #3
Badler
Member#: 133597
^^ What he said.
Old 06-01-2012, 03:18 PM   #4
WRX2EVOX
Member#: 203011
04 WRX
Im running -4 on all 4 corners tucking 18x10 255/35/18's, tire wear is insane. And this is my DD
Putting on fender flares so I can back it off to -2F -1R
WRX2EVOX is offline   Reply With Quote
Old 06-01-2012, 10:02 PM   #5
Web Foot STi
Member#: 39086
2004 STi
How are your top hats oriented?
It is possible to have them positioned for max camber, or max castor, or in between. You may not need a second set of camber bolts and have the benifit of more castor.
Web Foot STi is offline   Reply With Quote
Old 06-01-2012, 10:36 PM   #6
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
It's toe that increase tire wear, not camber.
I run 0* toe all around and -3* up front, my tire wear is perfectly fine.
If you're at 0* toe, you'll be fine.
BeBop86 is offline   Reply With Quote
Old 06-01-2012, 10:50 PM   #7
JDwhiteWRX
Member#: 190502
2005 VF36 WRX
What he said, I've been running -3 on my daily driver for years, with zero toe the wear is very even.
JDwhiteWRX is offline   Reply With Quote
Old 06-01-2012, 11:39 PM   #8
2JZ
Member#: 291949
It is possible to have them positioned for max camber, max castor, or in between. You may not need a second set of camber bolts and have the benifit of more castor.
It is possible to have a minimum negative camber increase and maximum caster. Or Maximum caster and maximum camber.
At max caster, max negative camber, no camber bolts, and OE camber bolts set at MAX positive you get about -0.7
Old 06-02-2012, 12:36 AM   #9
Web Foot STi
Member#: 39086
2004 STi
^ I missed an "or".
Old 06-02-2012, 01:18 AM   #10
2JZ
Member#: 291949
Originally Posted by Badler View Post
^^ What he said.
you mean what "you said". You posted your thoughts and posted again saying that
Old 06-02-2012, 01:20 AM   #11
2JZ
Member#: 291949
^ I missed an "or".
For the top hats the caster is ALWAYS set at maximum. If you do not require any further negative camber, that's what it's for. However, if you need both they offer that as well. I think these top hats are more for caster if anything.
Old 06-02-2012, 01:21 AM   #12
2JZ
Member#: 291949
How is driving in the rain? I found it quite bad. I had significantly less grip, I felt much more comfortable with less camber in the rain. This was a nice warning sign for reducing the camber for the winter...
Or perhaps the tread pattern is not that good and i may need better tires.
Old 06-02-2012, 02:30 AM   #13
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
I'd say it's your tires.
I'm running 255/40/17 Dunlop Direzza Z1's... plenty of grip in Washington weather
Old 06-02-2012, 02:55 AM   #14
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
99 2.5TS (DEAD)
people will disagree with me but running oodles of camber is not necessary. I was running -3.5 for a couple months while my com C's were being warrantied and I was using a different setup. Granted, i was running only -.5 in the rear but I still found it not particularly useful to have such aggressive camber.
If your goal is to fit really wide wheels and tires then maybe it's a good idea but I am using stock size wheels. I have settled on -2.3 and I find that to be great with my com-C's set to max caster.
tire wear will be based on toe and driving style.
Zefy is online now   Reply With Quote
Old 06-02-2012, 03:24 AM   #15
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
It all depends on what your application is.
I autoX a lot, so I benefit from tons of negative camber.
If all you do is street driving, you'll benefit from less camber.
Old 06-02-2012, 06:47 AM   #16
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
when i went to ~ +6* caster, i went from -2.9* camber to ~ -2.4* and it was much better in the wet/rain and the braking wasnt as 'squirrely' at the limit
never missed the camber really
more pos caster rocks
make sure toe is 0
Old 06-02-2012, 09:27 AM   #17
2011WRX
Member#: 251807
I have ~-2.3Frt and it wear quite a bit on the inside even with 4-5 track days a year. I diled back to -1.8 and it is much better now.
2011WRX is offline   Reply With Quote
Old 06-02-2012, 10:30 AM   #18
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
These sorts of comments invariably come up when people talk about running lots of negative camber. There's more to tire wear than just keep toe at 0. If someone does a lot of highway driving and not a whole lot of back roads / surface street driving then lots of negative camber will most definitely lead to uneven tire wear. Been there, done that.
Old 06-02-2012, 12:29 PM   #19
2JZ
Member#: 291949
make sure toe is 0
This sounds great. Any idea what caster these COM-C top hats are offering me at the moment? And what's a cheap way to add more caster? I guess STI lower control arms?
Believe it or not, in the rain ABS was TERRIBLE.
I was driving down an empty street with 3 stop signs. I thresheld braked last second to the stop sign and made it easily everytime. Last stop sign I wanted to try the ABS and I was sliding right through the intersection.
I wonder what mods would have affected this poor performance.
Old 06-02-2012, 04:34 PM   #20
rudymcskoody
Member#: 257618
2006 wrx
aspen white
Look into a whiteline anti lift kit.
rudymcskoody is offline   Reply With Quote
Old 06-02-2012, 11:51 PM   #21
Badler
Member#: 133597
Double post sarcasm>You
Old 06-03-2012, 03:19 AM   #22
Back Road Runner
Member#: 60082
2004 Forester STI
Snap oversteer isn't a byproduct of camber. You will increase grip with camber and can subsequently change the oversteer/understeer behavior, but "snap" type of behavior is largely a byproduct of spring vs damping, more specifically sway bar spring effect during side to side motion which is something you can't really damp. A spring heavy car tends to rubberband a little bit. This is more significant when running cars with big sways but retaining mild spring and damper packages. You get a very high side to side spring effect that can be extremely sensitive to steering inputs. You have to be very smooth and deliberate with chassis inertia in order to drive the car well.
Tire wear won't be like what you think. Wear will come down to use. If you use the car hard, the tires will wear more even. If you're just cruising down the highway 99% of the time, the insides will wear more. If you run an auto-x once in a while AND actually push your car, you will find the high camber with the mixed sport and daily may be more even overall than you think. The amount of camber will depend on the use, and you can determine how you're doing by tracking tire use over time. For example, I have a Forester set at -2.5 front and -1.0 rear running a relatively stiff setup. I still over wear the outsides of the tires at this setting. From average use overall, I find that the car needs another -.5 to -1 more camber in order to produce even tire wear over the sum use of the tire for mixed daily and sport driving.
As for ABS, it's ok or quite good depending on what car you drive. Don't blame ABS for crappy tire traction. The ABS is a pretty functional system despite how much people want to blame it. There are certain forms of it that are crap, like the older cars with rear drum brakes. Beyond that though, it's mostly a tire issue more than anything else. Disabling ABS actually worsens braking distance without addressing brake bias balance. Stock, it's front biased to promote understeer. ABS under heavy braking actually redistributes braking force and evens out the bias, optimizing braking. ABS off, you're stopping about 15% farther out. Neutral out the bias and you're basically equal again. ABS does have certain weaknesses like bumps. It's not great about bumps. It's also not great with some loose surfaces as some surfaces will allow you to brake stronger by locking up the tires some. However, asphalt road in the rain is ALL the tire's issue.
Back Road Runner is offline   Reply With Quote
Is there ever such a thing as too much mammaries? MistaOctamopus Off-Topic 19 03-01-2008 10:16 AM
is there ever such a thing as "too much memory" ?? The Tree Off-Topic 8 03-01-2008 02:53 AM
Is there ever a day when something doesn't go wrong? 03WRX83 Off-Topic 16 12-15-2003 07:53 PM
when is there going to be a meet...? joostin420 New England Impreza Club Forum -- NESIC 21 01-13-2003 03:03 PM
