Welcome to the North American Subaru Impreza Owners Club Tuesday September 16, 2014
Old 03-21-2012, 02:44 PM   #26
thom52
Member#: 309257
2012 Imp 5D Prem CVT
Marine Blue
I am hoping something was lost in translation via my wife, from the mechanic.
Good point!
The local dealer is living up to its poor Service rep. My wife is dragging her feet on making the longer drive to the better Service dealer.
Its her car so I figure its her choice.
thom52 is offline   Reply With Quote
Old 03-21-2012, 03:03 PM   #27
79letour
Member#: 302570
2013 XV
DGM!
The dealership makes all the difference. Mine, Bill Bryan Subaru are as bad as they come. Sleazy, rude, lying idiots. Id rather drive a Fiesta from a friendly Ford dealer than a Subaru from a crappy dealer. Sucks when you buy local and have to drive over an hour for factory service or warranty work. Soa wont answer my questions, they give me what are, effectively, non-answers.
Old 03-26-2012, 06:43 AM   #28
pkL
Member#: 313093
2012 Impreza 2.0i
5-door Sport. Dark Grey
Did your dealership follow up with you after you got the car?
Old 03-26-2012, 11:00 AM   #29
79letour
Member#: 302570
2013 XV
DGM!
No not really. They have had three managers come and go since dec 24 when I bought the car. The salesman is no longer there. The only one whos a constant presence is the despicable service manager. He is aweful. Just pitiful. They poured oil all over my car at the first oil change, etc. Aweful people. I have a meeting with the executive manager of the Bill Bryan line of dealerships tonight. I'll poat what happens in a new thread, possibly.
Old 03-27-2012, 12:55 AM   #30
pkL
Member#: 313093
2012 Impreza 2.0i
Sounds like a $hitty dealership with such a high turnover rate, sadly my dealership hasn't followed up with me since I got the car. I was expecting/hoping they would call not that it really matters anyways though.
Old 03-27-2012, 05:18 PM   #31
79letour
Member#: 302570
2013 XV
DGM!
What really orks me is that SOA wants me to drive an hour and a half to the next dealer through Orlando traffic and go to another dealer. But SOA is very adept at dodging questions and giving non-answers. I asked if my free maintenance would be honored at another dealer. Still awaiting response. Never did get anything from them about oil capacity. It really just took calling the bbb, but I still have to wait n see what the results are from this stay at the dealer. In the meantime, I've got a mbp sedan base model as a loaner.
Old 04-04-2012, 08:53 AM   #32
debbadoo1
Member#: 305301
Any more issues/updates on the slow crank problem?
debbadoo1 is offline   Reply With Quote
Old 04-13-2012, 06:56 PM   #33
Jmzda
Member#: 313812
2012 Impreza 2.0i Pr
Dark Gray Metallic
I only have 500 miles on the car now & this has happened to me 3 times already. The first time it will not turn over after an elongated time of turning the key. The 2nd time it finally turns over after turning the key longer than normal. If this keeps happening I'll bring it to the dealer, I won't be putting any fuel cleaners in a brand new car.
Old 04-13-2012, 09:07 PM   #34
79letour
Member#: 302570
2013 XV
DGM!
Like I've said- a look at the Ford Pinto battery and terminal wiring isn't very confidence-inspiring. As soon as its out of warranty (not that the Subaru has much of one) I'm putting a good, sealed type of battery and rewiring.
Old 04-14-2012, 12:02 AM   #35
somebody else
Member#: 21618
Having owned a WRX for the better part of a decade, I was prepared for the fuel pump priming issue. Out of habit, I turn the key to ON (past ACC), wait for the needles to settle down, then wait a second longer, then crank.
It has been starting every time within two seconds. Entirely within the range of the WRX for 9 years.
All tanks standard 87 octane Union 76 or Chevron.
Temperature ranges have been between 20 degrees at the low end to 90 degrees at the high end.
Elevations have ranged from below sea-level to 10,000 feet / 3,000 meters.
Premium hatch, CVT.
____________
What this means is open for debate, but at the least it means that the problem doesn't effect ALL 2012 Imprezas.
somebody else is offline   Reply With Quote
Old 06-06-2012, 03:00 PM   #36
BigVoxjammer
Member#: 319171
2012 Impreza Spt Ltd
Sky-Blue/Gray
It's weird there are a variety of seeming causes for this problem, and very few (though still enough) people experiencing it. At the risk of reviving a potentially old but interesting thread, or mentioning what is already common knowledge, I'll add what I read on page 3-4 of the manual, namely that in some situations the key won't start the car if another transponder key is near it, or if a normal metal key is munked up on your key-chain, thereby touching your ignition key, and presumedly grounding it. I jump in just to suggest to those having an intermittent issue that it could even just be this simple thing.
BigVoxjammer is offline   Reply With Quote
Old 06-06-2012, 03:03 PM   #37
ocellaris
Member#: 302559
I carry around my Impreza key solo, so unfortunately its not that
ocellaris is offline   Reply With Quote
Old 06-06-2012, 04:35 PM   #38
BigVoxjammer
Member#: 319171
Sky-Blue/Gray
Unhappy
Bummer.
Old 06-09-2012, 09:23 AM   #39
leeden
Member#: 41654
2005 Impreza WRX STi
2012 Sport Limited
I have a similar problem with my 2005 STi. I've gotten into the habit of waiting for the gauge sweep to finish before starting the car. My 2012 Impreza will always start if I wait for the gauge sweep to finish. However the remote starter pretty much fails on the first try. I have to click the remote a 2nd time to succeed.
leeden is offline   Reply With Quote
Old 06-09-2012, 07:10 PM   #40
BigVoxjammer
Member#: 319171
Sky-Blue/Gray
That's been mentioned as a fix for a lot of folks: to "prime" the system by letting it, well, boot-up?
Old 06-21-2012, 01:40 PM   #41
riccnick
Member#: 311152
2012 Impreza
Ice Silver Metallic
I noticed earlier this week, (because it did it again) that it was very humid and about 75F. Only took two times to start, both times waiting for the gauge sweep / prime. I also noticed the next day, that when I started it, it made a funny groaning noise when it fired up, almost like the a/c compressor clutch was slipping. (A/C off and defrost off, btw)
riccnick is offline   Reply With Quote
Old 06-21-2012, 04:50 PM   #42
ALafya
Member#: 293105
On an Accord I owned a sound like you described used to mean that the battery is close to it's end of life or is seriously under-charged.
ALafya is offline   Reply With Quote
Old 12-06-2012, 08:48 PM   #43
wullymc
Member#: 339897
Hi guys,
I just have gotten a new 2013 base impreza and have had this problem. It has been 2 weeks with the car and I have had it not start about 10 times. At most it would try 2 times and then start.
It doesn't matter if it is hot, cold, if it was just driven, etc.
I have tried the wait on ON before starting the motor and it doesn't work sometimes.
Has anyone received a solution? I took it to my dealer and they checked the computer...no codes, checked the charge of the battery....everything ok, and couldn't reproduce the problem.
Can anyone help?
wullymc is offline   Reply With Quote
Old 12-07-2012, 09:35 AM   #44
ICE_NY
Member#: 324263
2013 Impreza Sport
Hello there,
I have had the starting issue twice. Once after taking it to a "do it yourself car wash". It took me like 6 tries to get her going. I took her to the same car wash a month later and there were no issues on the second time. The other one was one cold morning (30 F) it took me two tries. Very annoying considering I never had any of those issues with my previous 1995 Jetta.
Sport Limited / CVT
ICE_NY is offline   Reply With Quote
Old 12-07-2012, 10:37 AM   #45
BajaGuy68
Member#: 127720
2015 WRX
Lightning Red
Had the same problem happen to me; the second time was this morning. It cranked over fine, but wouldn't start. I waited about a minute and tried again, but it wasn't going to start.... so I floored the gas pedal and held it down and it fired up finally. I wonder if it has anything to do with the security system not recognising the key as your trying to start her?
BajaGuy68 is offline   Reply With Quote
Old 12-07-2012, 01:17 PM   #46
M45
Member#: 333446
2013 Impreza SL CVT
This has happened to me once. I think it was due to me not letting the fuel pump finish doing it's thing before I turned the key forward.
Old 12-07-2012, 02:29 PM   #47
myrt1987
Member#: 323103
2012 Limited 2.0i
Dreamy Gray Mistress
Default Not weather related
Its happened to me as well awhile ago. Took 2 attempts. Was 6pm and not freezing out or anything.
A couple times it will start but the rpms are super low and it sounds like it wants to go back into slumber. Then all of a sudden it will shoot to 2000rpm without me touching anything. I think this has only happened on cold mornings, 6am.
I just caress the steering wheel and say "i know baby, i know..."
Old 12-07-2012, 03:31 PM   #48
riccnick
Member#: 311152
2012 Impreza
Ice Silver Metallic
Just an update. My car is now doing this thing where it will crank, sound like its going to fire, so I let off the key, and then sputter and die. I've had this happen three times this week now. It also is very slow to crank in the mornings, as if there is no oil in the engine causing a ton of drag. there is of course oil, and it was changed last Saturday at the dealer. I'm waiting for this car to blow up, and then I'm driving to my nearest Toyota dealer to get back into a Tundra, lol.
Old 12-07-2012, 03:41 PM   #49
cole70
Member#: 334033
2013 Impreza SP
I have had this issue a few times now. Then I remembered I had the exact same issue with my Honda when I first got it. It has to do with how I put the key in the ignition I think. I have a tendency to jam it in and turn immediately. Now that I am more aware of it, I havent had it happen.
cole70 is offline   Reply With Quote
Old 12-07-2012, 09:01 PM   #50
gt601
Member#: 308387
2012 Impreza Sport
white
I have noticed that my Sport will crank like the battery is low at times. It just seems sluggish. It has never not started. I wonder if low voltage is causing this issue. On some of the older Bosch injected cars if the voltage dropped a little below 12 volts the car would NOT start. It would crank all day without firing. My Alfa Romeo 164S had a (no kidding) truck and bus battery to keep this from happening. If you cheaped out and put a crappy small battery in you would be hit and miss on starting success.
Our batteries don't look as though they are the best of quality. I have been thinking about just going ahead and replacing the OE batt with an optima one.
Just some thoughts.
Paul
gt601 is online now   Reply With Quote
going to be like driving for the first time! ThaPuertoRican15 General Community 35 12-27-2010 01:42 PM
going to autox this weekend for the first time... CiViCKiDD General Community 12 03-21-2006 06:15 PM
I'm about to ride a Harley for the first time. Sharkbait Off-Topic 48 12-01-2005 10:23 AM
im going to watch american idol for the first time Protege Menace Off-Topic 5 05-19-2005 10:35 PM
Finally got to drive my WRX for the first time in a while! MGAMAN Alaskan Impreza Club Forum -- AKIC 3 07-24-2003 08:31 PM
