Welcome to the North American Subaru Impreza Owners Club Thursday February 11, 2016
Old 04-15-2003, 07:48 PM   #1
donbaru
Member#: 10397
2004 WRX impreza
Default drums to discs
Thinking about converting to rear disc brakes on my 93L, and maybe use cross drilled discs.
Any suggestions on where to buy (cheap parts) for this conversion.
donbaru is offline   Reply With Quote
Old 04-15-2003, 11:37 PM   #2
schnell
Member#: 14362
2002 TS Wagon
Midnight Black Pearl
There is a page out there by a guy who upgraded his OBS - a late 90's model I believe.
Link to drum/disc conversion.
As for cross drilled, search nasioc and you'll find that cross drilled rotors are not that great. Slotted are better, but even then there are arguments. Regardless, upgrade the fronts before the backs, since the front does most braking.
Good luck.
jason
PS most of this info is on this forum already, a few searches will yield many results.
schnell is offline   Reply With Quote
Old 04-16-2003, 04:51 PM   #3
stentorian
Member#: 12959
2008 Scion xB
What setup do you plan to use for your rears? Are you leaving the front stock?
I plan to upgrade my entire brake system, Subaru 4pot front and 2pot rear, but that is when I do the power upgrade as well, heh...Otherwise my EJ18 and its lack of power with that will stop in a blink of your eye, hahaha
-joe
stentorian is offline   Reply With Quote
Old 04-16-2003, 08:43 PM   #4
Aspen
Member#: 145
Banned to
Housework for Summer
I might be selling my rear rotors/calipers since I will be upgrading soon. I also might know a place that has rear spindles too.
Aspen is offline   Reply With Quote
Old 04-17-2003, 04:24 PM   #5
linsavy
Member#: 11620
1997 GF4-STiV3 clone
A couple of guys have done the swap without spindles from the disc car. They just swap the backing plate. Saves taking the axle bolt and axles out and disconnecting the strut and links.
linsavy is offline   Reply With Quote
Old 04-17-2003, 07:58 PM   #6
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
www.4subarusuzukiparts.com
$600 for the entire swap front and rear including rotors, calipers, pads, lines, hubs, and parking brake cable. You can go with either WRX or the Outback H6 brakes.
I actually found the front and rear rotors and calipers for much cheaper but for the record, I'm using the WRX brakes.
-Jon
stimpy is offline   Reply With Quote
Old 04-17-2003, 10:46 PM   #7
geronimo66
Member#: 26929
2000 Impreza
with Gremilins
do they offer all this as a package or did you just request the parts from them?
If so do you have a complete lise of the needed parts?
geronimo66 is offline   Reply With Quote
Old 04-18-2003, 01:04 AM   #8
Greg Sharpe
Member#: 741
04 EVO SSL
Asphalt Black
On a similar note... Those converting a FWD from drums to discs in the rear should swap the entire rear hub/spindle. This will allow you to use the commonly available struts (STi, Tein, etc.), as the FWD rear struts have vastly different mouting holes.
When converting an AWD drum setup to discs, you'll need the parking brake cables from the discs, too.
Greg Sharpe is offline   Reply With Quote
Old 04-18-2003, 01:23 AM   #9
Aspen
Member#: 145
Banned to
If you want a factory fit, then yes but you can also modify the existing drum brake cables to work also. This is what I did.
Old 04-18-2003, 03:04 AM   #10
geronimo66
Member#: 26929
2000 Impreza
with Gremilins
bump for my question
Old 04-18-2003, 09:48 AM   #11
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
If you called them up and asked for the rear disk conversion, they should know what you are talking about.
It should come with calipers, rotors, and pads for front and rear, hubs/bearings and parking brake cables, and brake lines for rear.
You will want to double check this with them of course, since I didn't actually order from them. The guys there are usually very knowledgable though.
I haven't heard of people using the drum cables before, but I have heard of people using the RS/WRX disc parking brake cables or the Legacy cables.
-Jon
Old 04-18-2003, 12:40 PM   #12
Scoobyslack1
Member#: 2780
junk yards rule!
Project FrankenSTien
I'll be doing this on sunday, I hope
Also think about upgrading your lines to SS since you'll have the backs off and the fluid too.
Team ARG!
Scoobyslack1 is offline   Reply With Quote
Old 04-18-2003, 02:25 PM   #13
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
yeah its not too bad
go buy some liquid wrench and spray them down the bolts tonight...
i also put in RS latterlinks at the same time and added a sway bar
i ended up removing the seats (all of the seats) and center consol to get access to the parking brake cable attachemnt
$325; Rear drum to Disc JDM VENTED 10.5" disc brake for WRX or GC8 complete KIT supermoose Private 'For Sale' Classifieds 10 02-25-2006 02:50 PM
Upgrade 02 outback brakes from drum to disc? Marty S Brakes, Steering & Suspension 2 10-21-2001 05:26 PM
brake upgrade: rear drums to discs, or beefier front brakes? DoinkMobb Brakes, Steering & Suspension 8 07-18-2001 12:33 PM
FS: Read drum to disc conversion kit... subaruwrx Southern California Impreza Club Forum -- SCIC 1 02-05-2001 11:28 PM
Brake bias change rear drums to discs larsch13 Technical Forum Archive 11 08-23-2000 01:58 AM
