Old 03-03-2012, 12:33 AM   #1
cbr_rhino
Member#: 237834
Default JDM ej207 swap in my 04 STI
So i've been doing alot of searching/reading and i'm still confused. I want to swap an ej207 into my 04 sti. I see alot of people swapping into wrx's but didn't find much on my car. The wrx needs avcs harness, do I? is a version 8 ej207 a direct swap? can i use the jdm pcm? what additional parts will i need? If anyone has info it would be greatly appeciated.
Thanks,
Ryan
cbr_rhino is offline   Reply With Quote
Old 03-03-2012, 01:46 AM   #2
DHRDAN
Member#: 204358
01 2.5RS W/ EJ257
There is no v8 ej207.
If you want to swap a older Ej207 in a GD USDM chasssic, you will need the ECU, and wiring harness.
Also you will need a full tune since the Ej207 is built for jap gas, and not our crappy USDM stuff.
It's a fantastic engine, but it will take more than 1 thread to learn how much work that will be required to make it work in the good ol u.s. of a.
DHRDAN is offline   Reply With Quote
Old 03-03-2012, 02:09 AM   #3
cbr_rhino
Member#: 237834
Ok what is the proper swap for me 04? Version 8? That isn't an ej207?? My main question is will it bolt up/use existing wiring. My stock PCM has ecutek race rom with my current set up so I would assume my tuner could use that if the PCM is compatible
Old 03-03-2012, 06:29 AM   #4
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
The JDM is drive by cable all the way to GRB.
You either convert to drive by cable, with the pedal, cable, pulley, etc. The wiring will not be 100% straightforward and the AVCS may have to be re-pinned. The sensors are of a different type, this may not affect you.
When doing the swap, you will have to use the JDM ECU.
Or, you buy a later GRB swap, then you convert to can bus, get dual AVCS and then don't have to convert to drive by cable. I'm reading that converting to can bus means replacing most of your wiring. Everything has immobilizers by then, so include new keys, cylinder and module.
You have to start by thinking about state inspection.
Your state may flunk your inspection if the ECU reports a different year-make that what they have on record.
Old 03-03-2012, 09:43 AM   #5
ArronStump
Member#: 182620
07 sti
The Jdm and uk v8 is a 207.
You can use your stock Ecu with a 2.0 and your stock manifold.
Use the heads from your stock motor cause of the Avcs.
ArronStump is offline   Reply With Quote
Old 03-03-2012, 10:06 AM   #6
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
the compression will be all off , if he does a reverse hybrid. The combustion area is too big on the 2.5 heads for the 2.0 pistons.
Old 03-03-2012, 10:22 AM   #7
nhat
Member#: 140163
03 STi
hellaflunctional
nhat is offline   Reply With Quote
Old 03-03-2012, 10:55 AM   #8
cbr_rhino
Member#: 237834
So what would it take to use my factory throttlebody and PCM. I keep reading about wiring adapters for avcs. I'm looking for the most simple route. And what sensors are different?
Old 03-03-2012, 11:27 PM   #9
DHRDAN
Member#: 204358
01 2.5RS W/ EJ257
Originally Posted by nhat View Post
I take that back.. there is.
I forgot it took a while for JDM to switch to the 2.5L. I'm wrong.
Old 03-04-2012, 08:13 AM   #10
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
The whole point of the EJ207 is achieved by keeping it in one piece, meaning shortblock+ heads.
Once this is agreed, the sensors for the throttle by wire cars (such as your current engine has), are of a different nature and positioned different (I think) with the EJ207. This concerns the cam and possibly crank position sensors. One kind is inductive, the other is hall effect, I believe.
This is why, it's not easy to take the throttle from an EJ257, together with the ECU and intake manifold and sensors and transfer them over to the EJ207 and have now a 207 throttle by wire, that is run by an EJ257 ECU.
This has been done once though on the forum though, by a shop in Cali, I believe, due to state inspection problems. They may have made adaptors or machined mounts.
There was one other guy looking to complete the same setup.
The problem is also that Each ECU has a different set of capabillities and you cannot reflash no matter which ECU to become something different.
When you look into the tables that the USDm ECU has and then look at the tables of the JDM ECU, you are left with an opinion that the 257 has more "worries" about knock, about fueling in misc situations, about emissions, etc, while the JDM ECU has more rows, extending it's operation into the 8000 rpm, into higher loads, more aggressive AVCS, etc.
Now, the colums and rows can be edited, but not the number of them (to my knowledge).
Also, the JDM does boost by gear and includes an intercooler spray control, etc.
In other words, by keeping your ECU and throttle, you are only getting 90% there with the JDM EJ207. And you still have to do some wiring, I think.
Old 03-04-2012, 02:42 PM   #11
cbr_rhino
Member#: 237834
Thanks for all the help guys. So is my best bet switching to cable throttle and the Jdm ecu? Do I need any special harnesses for my car or is it as simple is repinning some of the wiring? I guess I would then have my tuner re-map the Jdm ecu for 93octane?
Old 03-04-2012, 04:52 PM   #12
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
You still are doing something new and may encounter therefore new issues.
I would ask around if the connectors for an Sti ECU are the same shape and number with an 04 wrx (cause those are plug and play with the jdm) and then for the main engine harness.
If those are the same, you most likely will only deal with re pinning.
Old 03-08-2012, 01:30 PM   #13
dolosolow
Member#: 279605
04' WRX swap STi
v8 TwinScroll 6MT
Post
^^^^ +1
dolosolow is offline   Reply With Quote
Old 03-08-2012, 04:45 PM   #14
dangerousatom
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
IMO the simplest...least thinking way to go about it is to take your entire harness out and swap it for a 02-04 WRX. Then its all plug and play including the JDM ECU. To run the AVCS with this scenario its a fairly simple wiring addition of a IA Performance's AVCS wiring harness. After that its a real Dyno tune on 93-94 oct.
This is the rout Im going on my 03 WRX
You can swap the whole harness in a long day, if you know what your doing and sell the 04 STi harness for far more then a JDM ECU and 02-04 WRX harness will cost
dangerousatom is offline   Reply With Quote
Old 03-09-2012, 06:43 AM   #15
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
Yep, I'll add that the '04 USDM Sti ECU is probably very sought after, as it's the only 32bit ECU that does not have immobilizer. I would not be surprised if you get good money for that.
Then there are many people with WRX that convert to EJ257 and you would be selling the exact swap components, probably the whole kit including pedal and harness would just sell, as soon as you post it.
Old 03-09-2012, 10:13 AM   #16
cbr_rhino
Member#: 237834
Thanks guys. Everything is on hold right now. I'm trying to sell my rotated gt30 setup off the car so I can fund this new project.
Old 05-28-2012, 03:37 AM   #17
amroof
Member#: 211224
2005 Saabaru
Who knows
this swap is amazing by the way! i love mine ;-) especially cause those who said it couldnt be done, made me want to do it more. So i did. good luck
amroof is offline   Reply With Quote
Old 06-01-2012, 06:11 PM   #18
Stretchvelcroy
Member#: 299169
2002 Wrx/JDM STi v.7
Dirrrty
My EJ 207 v. 7 is on its way to me as I type...
I am so fricking excited!
I am getting mine from swap shop racing in quebec.
They are also sending the directions and extra wires n such....
I have heard it is pretty much plug n play....
I have been looking for the right engine for 7 weeks, the day I found it was the day I bought it.
The engine needs 94 octane....unless re-mapped.
Hammer time!
Stretchvelcroy is offline   Reply With Quote
Old 06-06-2012, 10:13 PM   #19
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
What MAF? -Speed Density!
Tuning Amroofs stock 32 bit Forrester ECU for the JDM V8 motor was no problem there is just as much resolution as the JDM tables on the 16 bit ecu. AVCS hits a targeted 40 deg and the motor LOVES timing on E85. Next project is a v8 spec-c motor into a 06 running the prototype 32 bit Speed Density rom. We will see if matches up with my Spec-C 16 bit speed density map I run on my daily driver track machine.
lukeskywrx is offline   Reply With Quote
Swapping in a 04 sti ABS pump and lines SupaSizeFries Subaru Conversions 1 06-06-2012 08:21 PM
name this part of my vacuum system in my 04 sti drumminguy81 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 09-10-2011 01:44 PM
Red Struts in my 04 STI Darium Brakes, Steering & Suspension 3 07-20-2010 01:12 AM
in my 04 sti rally cross miami go pro hero camera davidsti1 General Community 7 07-29-2009 02:46 AM
Thinking of trading in my 04 STI for 04 Z06 roybfr Off-Topic 75 07-12-2007 12:22 AM
