Go Back   NASIOC > NASIOC Subaru Models > Outback Forum
Old 03-18-2012, 02:55 PM   #226
i5racer
Member#: 308167
1998 Impreza L
Originally Posted by StiDreams View Post
To bad the rear arches aren't centered over the wheels like the fronts. If they were you cold probably get 29" OD tires in there.
you can centre the rear wheel by spacing the trailing arm bracket, same as in the front with the transverse links
i5racer is offline   Reply With Quote
Old 03-18-2012, 06:45 PM   #227
StiDreams
Member#: 26315
07 Outback
Silver/Silver
Anybody got a kit or do I just have to fab some up myself.
StiDreams is offline   Reply With Quote
Old 03-18-2012, 07:03 PM   #228
StiDreams
Member#: 26315
07 Outback
Silver/Silver
I just measured the opening. It's just about 29 and 3/4+". There's 2" in back and 1" in front of the tire. The most would need to do is about 1/2". You probably can't get 29s in there. But you could 225/70R16 (28.5") if you centered it. I'm probably going to leave it and do Yoko Geolander 215/70R16 (28").
Old 03-18-2012, 08:03 PM   #229
StiDreams
Member#: 26315
07 Outback
Silver/Silver
I went back and looked at a pre-lifted picture. Even pre-lifted the rear wheel is a bit forward in the opening.
Old 03-19-2012, 03:37 PM   #230
Samirr76
Member#: 4835
2003 Baja 5MT
Yellow w/ 220,000 miles
Lifting with just spacers on the struts, will there be any additional stress or wear and tear and the cv/axles?
I have spacers at home that are either 1.5" or 2", they came with the Scorpion lift kit for my 2003 Baja.
Samirr76 is offline   Reply With Quote
Old 03-19-2012, 08:55 PM   #231
StiDreams
Member#: 26315
07 Outback
Silver/Silver
I would say yes as you are increasing the angle on the CV joints. It's not much but it is greater than stock.
Old 03-20-2012, 10:29 AM   #232
i5racer
Member#: 308167
1998 Impreza L
I have to replace a cv about once a year but I got lifetime warranty and I beat the shizz out of my car
Old 03-20-2012, 02:32 PM   #233
StiDreams
Member#: 26315
07 Outback
Silver/Silver
Who are you buying them from?
Old 03-20-2012, 07:52 PM   #234
i5racer
Member#: 308167
1998 Impreza L
Autozone remanufactured OEM
Old 03-21-2012, 08:59 PM   #235
mckinnon99879
Member#: 314199
2013 WRX
ISM
there are a couple lifted outbacks over on the outback forum as well, lots of people do it
mckinnon99879 is offline   Reply With Quote
Old 03-22-2012, 12:02 PM   #236
Samirr76
Member#: 4835
2003 Baja 5MT
Once a year? Ouch. How much of a lift do you have? I'm only looking at maybe 1.5" to 2"....
Old 03-22-2012, 09:10 PM   #237
i5racer
Member#: 308167
1998 Impreza L
Lifted king springs on Outback suspension, I don't think the lift is as much a factor as my driving habits but it sure isn't helping matters.
Old 03-22-2012, 09:17 PM   #238
acanadianreject
Member#: 235679
99 Legacy 2.5GT
Tuxedo Black
i5 racer
you should come to some of the suby meets at dicks in crown hill this spring/summer, i will be there rockin my new legacy sedan! would be cool to meet some more local suby guys, they are supposed to be starting up again in april, i think my friend who is running it said first and third wednesdays every month, but check the local forum or i can to make sure of that
would be cool to meet ya, dont worry they arent snobby "off road ready" haters, guys come with all sorts of subies, even a couple brats have been there. i took my stock legacy for a while, they are cool guys
acanadianreject is offline   Reply With Quote
Old 03-24-2012, 11:15 PM   #239
skunkman
Member#: 118141
95 'lifted' legacy
does this have trailing arms?
skunkman is offline   Reply With Quote
Old 03-27-2012, 10:30 AM   #240
StiDreams
Member#: 26315
07 Outback
Silver/Silver
No trailing arms. It has a rear arm that's part of the hub.
I don't think that just spacing the rear arm bracket will center the rear wheel. It might get it back a little. It might even go back to the stock location but that isn't centered either.
I'm going to try to modify the OEM bracket. I'm going to fill the original holes and redrill them about 1/2" back.
Old 03-27-2012, 03:04 PM   #241
outbackwbeer!
Member#: 64060
98 lifted FOZ M/Ts
glacier white
Default kings/subtle 1" spacers
I have kings and subtle solutions spacers and have had zero problems and I probably wheel my outback more than anyone here since '03 when I bought it new..140k later and zero problems..
If you go 3" you will have issues..
with kings and subtle 1" spacer blocks it's more like 2.5" -2 3/4" after spring sag..(once the weight settles down. ).
A body lift of 2" will correct angles. However, now body lifts are available unless you make one. Australia has lift kits..
outbackwbeer! is offline   Reply With Quote
Old 03-27-2012, 03:55 PM   #242
Samirr76
Member#: 4835
2003 Baja 5MT
VERY NICE! Love the rock crawling action! Question will I need camber alignment after a 2" spacer lift?
Old 03-27-2012, 04:27 PM   #243
StiDreams
Member#: 26315
07 Outback
Silver/Silver
On mine ('07 OB) I ended up with no camber issues. The tech was able to get factory spec camber front and rear (no adj for rear). But the toe on the rear ended up slightly toe out.
Old 03-29-2012, 12:01 PM   #244
StiDreams
Member#: 26315
07 Outback
Silver/Silver
Those are nice. I'm trying to source some in silver. Where did you get them from?
I just noticed that the wheel is pretty centered. Did you use spacers for the rear arm or did you modify the bracket?
Old 03-29-2012, 10:28 PM   #245
i5racer
Member#: 308167
1998 Impreza L
I have Outback trailing arm brackets. Actually, the whole Outback conversion is there. Essentially, all you need to do is lower the forward mount as much as the knuckle is lowered and it will be the same position as factory
Old 06-02-2012, 05:28 PM   #246
SubbyQ
Member#: 322031
97 OB, 2.5 manual
hi, I'm new here and I am from New Zealand.
a lot of great ideas to modify my OB, thanks for that.
thanks, steve
SubbyQ is offline   Reply With Quote
Old 06-03-2012, 02:44 AM   #247
acanadianreject
Member#: 235679
99 Legacy 2.5GT
Tuxedo Black
welcome to the family!
i dont currently own an outback anymore but i will be assisting my friend in his rally spec outback eventually so ill still be around
(i didnt stop driving scoobs, i just got a 99 Legacy 2.5GT... no way im moving from subaru's any time soon!)
Old 06-05-2012, 11:14 AM   #248
McLovin MTL
Member#: 322272
2003 Impreza
What a great thread. Thanks for all the ideas everybody!
McLovin MTL is offline   Reply With Quote
Old 06-07-2012, 01:12 AM   #249
acanadianreject
Member#: 235679
99 Legacy 2.5GT
Tuxedo Black
i5racer! i saw you driving down aurora yesterday! wasnt driving my Lego GT though, i was in my mom's hyundai running to get parts for my car. wish i was in it, woulda said hi!
Old 07-01-2012, 12:30 PM   #250
ryan s.
Member#: 276486
'08 lowered Outback
1" subtle plates + king springs.
I did the front also but no pics of the assembled struts.
Pm'd you about the lift.
ryan s. is offline   Reply With Quote
lifted outback sports dmdellicolli Brakes, Steering & Suspension 12 09-03-2008 10:31 PM
Lifted Outback Allied Armament Outback Forum 3 04-15-2006 03:19 AM
Anyone have a lifted Outback Sedan? jsavage Outback Forum 8 03-01-2006 04:44 AM
Suspension/body lift, Lifted outback Legacy "BEEFY" Allied Armament Brakes, Steering & Suspension 0 11-27-2005 10:56 PM
Anyone own a lifted Outback? JC Legacy Forum 22 03-04-2003 03:14 AM
