Old 06-07-2012, 04:46 AM   #1
djkns
Member#: 147340
2005 WRX
Sliver
Unhappy 05 wrx/06 sti engine swap
hello... looking for some help with the swap that i am doing. its an 05 wrx to an 06 sti engine swap. Here's a list of the parts i have.
06 STi engine (full engine w/engine harness)
Complete bulkhead harness for the interior
Engine bay fuse box harness
DBW Pedal
06 ECU/immobilizer/key (no remote)
06 STi gauge cluster
Now everything is done the harness, engine, ecu, key all installed and connected, the problem i have is that i dont know where to connect the immobilizer to. it came with the connector attached to it already w/cut wires. The only wires that werent cut is the two that lead to the key ring, the anntena i think its called. my mechanic did most of the work installing everything and he's leaving the middle of next week and im hoping to get the fix before he leaves
i know that the 04 sti ecu doesnt need the immobilizer but i dont want to spend another 250+ on another ecu
any input would be great.. Thnks
djkns is offline   Reply With Quote
Old 06-07-2012, 11:05 AM   #2
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
What MAF? -Speed Density!
you sir need a wiring diagram, might be here http://techinfo.subaru.com/index.html
Old 06-07-2012, 08:22 PM   #3
djkns
Member#: 147340
2005 WRX
Sliver
I checked out the diagram for the interior bulk harness and it does show a connector for the immmobilizer. I'll try and find it tomorrow. Thanks for the info luke
Oh I read in the fsm somewhere that the sti gauge clusters has to match the immobilized as well (be from the same car) if that is the case I'm SOL
FS : CT: 2002 wrx w/sti engine swap WRXman1015 Private Vehicle 'For Sale' Classifieds 10 10-26-2010 05:50 PM
Full 04 to 06 sti Engine swap?? AbrownSTIo6 Subaru Conversions 5 05-11-2009 10:42 PM
WRX or STI engine swap to a BE slapnuts Legacy Forum 2 09-05-2008 03:19 PM
Rake change with WRX and STi engine swap? chimchimm5 Brakes, Steering & Suspension 1 07-30-2007 08:20 PM
wrx to sti engine swap Smoke Show Subaru Conversions 9 09-24-2005 12:29 AM
