Welcome to the North American Subaru Impreza Owners Club Sunday August 30, 2015
Old 06-08-2012, 03:46 AM   #876
burkart
Member#: 305000
2005 Legacy GT 5MT
Bright Silver Metallic
hm im curious too.
does it make it easier to drive around town?
burkart is offline   Reply With Quote
Old 06-08-2012, 03:56 AM   #877
MOBBiN
Member#: 128441
2006 STi WRB
01 BRP RS, 01 Silver XJ
Originally Posted by kpluiten View Post
Very nice. Another, more factory solution is to get the front door switch plates from a 2007 STi Limited. They have the heater controls in the door switch area. PN: 94266FE260OE for the passenger side and it costs $6.50. On the driver's side you simple place it in the dash. I know of nothing else that goes in that spot...
Awesome! Thank you. I'll probably go the OEM route
MOBBiN is offline   Reply With Quote
Old 06-08-2012, 03:54 PM   #878
Uruchima
Member#: 322246
2013 WRX Sedan
Default Thats pretty neat
Thats pretty neat switch. I wonder what other unusual actions we can make switches for. Make it look like a cockpit!
Uruchima is offline   Reply With Quote
Old 06-08-2012, 04:41 PM   #879
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Very cool Ben! way to get creative.
Mike
Peek-a-boo
I've found it takes about 4 full turns to go from wastegate pressure (just over 20psi) to my desired peak of ~27psi. It is nice to be able to jump between those two whenever I want (although I never have turned it down in the past, so I don't know if I really will do that now...). I just figured it would be nice for the track in case I want to tone things down a bit on the fly.
Here's another lower shot:
I ran the vacuum lines across the engine bay and through the large grommet in the fender (along with all the other wiring I have done). Plenty of room in there. The MBC was mounted into a hole that was already existing under the dash. I don't know why it was there, but it was a perfect fit for the bolt.
I was a bit worried that the extra vacuum lines would cause problems, but I haven't noticed any issues so far. Spool and boost control seem to work just fine, but I would still like to pull a log to confirm. The only oddity is that you can hear the MBC venting air once the ball/spring opens up (as it should). It's just a slight hiss and by that time the EWG is open so it doesn't matter anyways!
GrimmSpeed is offline   Reply With Quote
Old 06-08-2012, 09:13 PM   #880
Pixmap
Member#: 322628
2011 Wrx
Red
Default Thanks
Thanks for sharin.
Pixmap is offline   Reply With Quote
Old 06-09-2012, 11:44 AM   #881
Highlander395
Member#: 284327
2003 STi Prodrive
Custom dash pod
To:
Installed:
Highlander395 is offline   Reply With Quote
Old 06-09-2012, 12:40 PM   #882
luisv
Member#: 266098
2011 Outback Sport
Steel / Spark Silver
Very nice... very nice...
luisv is offline   Reply With Quote
Old 06-09-2012, 12:54 PM   #883
scoobyd00d
Member#: 277301
2010 Impreza
Satin Pearl White
Originally Posted by Highlander395
Custom dash pod
To:
Installed:
That's a sick custom pod man. Very nice
scoobyd00d is offline   Reply With Quote
Old 06-09-2012, 02:10 PM   #884
Pidgeon
Member#: 284247
2002 Wrx
MBP!
Very cool for sure. What is that on the pillar?
Pidgeon is offline   Reply With Quote
Old 06-09-2012, 05:15 PM   #885
klarowe
Member#: 284753
2004 WRX STI
World Rally Blue
My new and improved gauge pod in progress. Sits no higher than a standard clock pod, but with the ability to hold up to 6 gauges.
The new pod:
Factory clock bezel next to the new pod
Highlander: Is that real CF or is it coated / covered. I have the factory carbon look dash setup in my STi and I would like to make this new pod look as close to it as possible once finished.
klarowe is offline   Reply With Quote
Old 06-10-2012, 06:25 AM   #886
Highlander395
Member#: 284327
2003 STi Prodrive
Thx!!
It's part of the alarm system => interior sensor In UK they were obligated to install an alarm due to high amount of auto theft
I covered it with real CF It was my first time trying to work with CF, so I'm not yet up to fabricating stuff in CF.. Covering will do the trick for now
Old 06-10-2012, 10:58 PM   #887
unparent
Member#: 124821
2006 wrx wagon
silvery
May have posted a couple of these before, but didn't see any posts under my name in this thread, so figured I post. Here is the interior with some minor touches and stereo work. Not shown is the 'big 3' setup with upgraded battery, terminals, and rewired with 0 and 4ga. Cleared/painted headlights. Also, all interior/external door skins, floor, and roof have 2-3 layers of Rammatt, and typically 2 layers of ensolite. Unbelievably quiet..
Painted dash panels with a voltage meter in the vent. Vent is still functional, although flow is reduced. Amplifiers are under each front seat, so I blocked off the floor vents under the dashboard, so all the floor airflow is routed under the amplifiers for cooling.
Painted dash, Pioneer DVD player, auxiliary input in a center console knock out panel, and a distribution block in the ashtray. It takes 4ga wiring in, and two 8ga wirings coming out to power the amps under the front seats.
Padded armrest with an iPod beltclip installed on the underside of the armrest so it is easily removable. A single red LED was added to the front panel in the armrest so it is easy to see in the console at night. Auxiliarly input is also visible.
Better view of the iPod and cable. A small hole with a grommet was made in the armrest so the wiring could be routed under the center console to the stereo. There are quite a few other little touches throughout the car, but these are the most useful ones for a daily driver... All modifications were done by myself...
unparent is offline   Reply With Quote
Old 06-10-2012, 11:18 PM   #888
nickboucher96
Member#: 246692
I recently put my iPad into the dash of my 2006 subaru sti! Thought it turned out pretty cool! Check it out.
http://www.teamhifi.com/?page_id=87#
I work at the hifi shop that is why it's on the website ha ha
nickboucher96 is offline   Reply With Quote
Old 06-10-2012, 11:19 PM   #889
Darthalie
Member#: 275718
2007 Impreza 2.5i
Default sun visors
Certainly not the biggest mod on this forum!...
After changing the seats, and then the door cards, I thought a touch of blue somewhere higher would balance everything. So I took apart the visors, reupholstered them and added my little personal touch...
Sun glasses holder on passenger side:
Note the snap on the leather strip...
the holder can be clipped flat as to not bother the passenger's view or for a more even look.
Darthalie is offline   Reply With Quote
Old 06-11-2012, 12:28 AM   #890
Pidgeon
Member#: 284247
2002 Wrx
MBP!
i thought it was a shift light :-(
Old 06-11-2012, 12:30 AM   #891
easterbran
Member#: 307359
'05 STi Stage II
I was thinking bait car-esque video camera.
easterbran is offline   Reply With Quote
Old 06-11-2012, 12:49 PM   #892
adstock
Member#: 322865
Originally Posted by unparent View Post
Where did you get that iPod holder?
adstock is offline   Reply With Quote
Old 06-11-2012, 04:47 PM   #893
unparent
Member#: 124821
2006 wrx wagon
silvery
I got it years ago (back when that iPod was new). It came with a belt clip, which is what I used to mount it in the car, and little clip so it could be proped up. No idea if the new ones come with that or not, but I got it through amazon. A little pricey if I remember correctly, but it's lasted forever, and I love having it mounted there in the car.
http://www.agent18.com/shop-by-category
Old 06-11-2012, 06:48 PM   #894
Tony JDM
Member#: 207532
1999 Impreza 2.5RS
Rusty Black Diamond Pearl
Isn't that an odd spot to be looking for changing what music you have playing?
I have my iPod sitting in front of the shifter with both cables going in through the ashtray hole. The charging cable then comes back out of the same hole and into my USB cigarette lighter thing, and the aux cable goes up to my stereo. I have enough extra cable to pull the iPod about 18" from the hole (have the rest tied up under the stereo so it doesn't look messy) so I can change music while still keeping an eye on the road.
I'd like to route my wires half way through the center and have them pop out from one of the coin holders next to the parking brake or something, but going all the way to the cupholder/armrest just appears to make it more difficult to use it unless you're not moving.
Tony JDM is offline   Reply With Quote
Old 06-11-2012, 06:57 PM   #895
Andrew025
Member#: 303408
04 STi
You use the deck to select songs
Andrew025 is online now   Reply With Quote
Old 06-13-2012, 01:53 AM   #896
Tony JDM
Member#: 207532
1999 Impreza 2.5RS
Ahh, didn't think of that. I wish my deck was smart enough to do that.
Old 06-15-2012, 01:40 AM   #897
Chasewrx
Member#: 290616
2004 WRX Wagon
JBP @LOLFUNCTION
I've always hated the stock incandesant (or however you spell it) bulb that was the high mount 3rd brakelight for wingless. So I put in the led strip from a wrx wing. Much brighter and looks way cooler at night
Chasewrx is offline   Reply With Quote
Old 06-15-2012, 05:52 AM   #898
scubynoob
Member#: 276157
2006 WRX sedan
How exactly did you mount the LED strip there?
scubynoob is offline   Reply With Quote
Old 06-15-2012, 11:32 AM   #899
Chasewrx
Member#: 290616
2004 WRX Wagon
JBP @LOLFUNCTION
Zip ties :P I'll find something better eventually but I was just tired of it sitting in my desk so I threw it on last night. If works great
Old 06-15-2012, 03:07 PM   #900
ea126405
Member#: 317032
Looks good, too.
ea126405 is offline   Reply With Quote
Show us your unique modifications lancewr1 Interior & Exterior Modification 7214 01-10-2012 12:09 PM
Calling all 2011 owners WRX's/STI's - Guys and Gals - Show us your pics and your mods bluerex79 Member's Car Gallery 6 05-02-2011 09:02 PM
Calling all Graphix......Show Us Your Stuff... grnlantern1 Member's Car Gallery 37 07-16-2002 01:25 AM
show us your wrx gauge installs. lstepnio Member's Car Gallery 51 05-22-2002 03:43 AM
Show us your T's (OZ Super T's that is) Who flung dung General Forum Archive 11 02-12-2001 07:46 PM
