Old 06-11-2012, 09:59 PM   #1
ur2punk
Member#: 30368
2003 WRX Sedan
Obnoxious Yellow
Default A/C problem on MY03 ...
Greetings!
My A/C started to blow warm air so I took it to my trusted mechanic. He was able to find a major leak and also refilled the freon. I thought it was fixed.
But it's back to square one. The interesting(?) thing is that it blows *cold* air for the first 5 to 10 seconds after I turn on the A/C switch.
Because it blows blast of cold air for the initial 5 to 10 seconds when I turn the switch on, is there any electrical part, like a thermostat (if there's such a thing on the A/C system), that can be potentially be the root cause?
Thank you for your help!
Rob
ur2punk is offline   Reply With Quote
Old 06-11-2012, 10:10 PM   #2
2002Bugseye
Member#: 294245
2002 Impreza WRX
Platinum Silver
Did he evacuate the system (Hook it up to a vacuum pump or recovery machine and pull a vacuum) before adding the refrigerant?
If no, then there could be excess moisture in the system which will freeze right after the metering device, I believe we have a thermal expansion valve, and it will stop all flow of refrigerant which doesn't allow the A/C to operate properly.
To check for excess moisture, activate your A/C until it stops blowing cold air, then turn it off for 2-5 minutes, and try it again. If it blows cold air and repeats the process, it may need to be evacuated and refilled.
2002Bugseye is offline   Reply With Quote
Old 06-18-2012, 09:20 AM   #3
ur2punk
Member#: 30368
2003 WRX Sedan
Obnoxious Yellow
Hi 2002Bugseye,
Thank you. I will ask him this morning as I have oil change. And yes - your last sentence seems to be what's happening. Just turning it off & on immediately will not blow the cold air subsequently. But if I wait before turning it on it blows cold for another 5 - 10 secs. Actually, I'm going to print out this thread so I don't mistakenly relay something different (I love my bugeye but I'm not mechanically inclined)
Rob
Old 06-18-2012, 09:33 AM   #4
2002Bugseye
Member#: 294245
2002 Impreza WRX
Platinum Silver
Not a problem Rob, it's A/C season anyways, I hope you get everything sorted out.
2002Bugseye
Old 06-18-2012, 12:40 PM   #5
ur2punk
Member#: 30368
2003 WRX Sedan
Obnoxious Yellow
Hi 2002Bugseye,
I checked with him this morning and yes, they did evacuate the system. He said he'll put his tools on again later in the week to check the static pressure, etc. ...
Since the symptoms are almost exactly what you wrote earlier, is there a part in the A/C system, like the "thermal expansion valve" you wrote about, that can go bad and is replaceable?
Thank you for your input!
Rob
Old 06-19-2012, 03:37 PM   #6
scoobydude 92
Member#: 259881
03 wrx
sonic yellow
there is a tsb on the valve inside the evaporator that it needs to be replaced... it is reading improperley and casuing evaporator to freeze and blow warm/hot air ... then if you wait for it to unfreeze it will blow cold again
scoobydude 92 is offline   Reply With Quote
Old 06-19-2012, 07:43 PM   #7
ur2punk
Member#: 30368
2003 WRX Sedan
Obnoxious Yellow
scoobydude92,
thanks! is the "tsb" another word for "expansion valve"? I just found this thread that seems to be close to what I'm experiencing and was wondering: http://www.clubwrx.net/forums/genera...ed-c-help.html
Thank you.
Rob
Old 06-19-2012, 09:36 PM   #8
TwoFifty
Member#: 261764
2003 Impreza WRX
Originally Posted by ur2punk View Post
scoobydude92,
Thank you.
Rob
A tsb is a 'Technical Service Bulletin'
It's basically information of a very common problem with a vehicle, it contains the issue, why it happens and the repair. It basically allows the technician to diagnose a problem a lot faster and easier. However the tsb may not always be the route cause of the problem, but as a technician you are taught to start with the tsb providing the symptoms match.
That thread shows you how to remove and replace the expansion valve which is the part the above poster was talking about, IF that is your issue then that would be a great thread to follow.
TwoFifty is offline   Reply With Quote
Old 06-20-2012, 11:32 AM   #9
ur2punk
Member#: 30368
2003 WRX Sedan
Obnoxious Yellow
Thank you TwoFifty - I misunderstood. So if the root cause is what is in the TSB, is it still covered under an long-expired warranty or am I still responsible for the labor and/or part including diagnosis of the root cause?
Thank you.
Rob
Old 06-20-2012, 04:40 PM   #10
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
If you have proper freon levels it could be one of two things. There's a sensor by the grill that is "easily" swapped. There's the expansion valve thingy that is behind your glove compartment that is a bit of a whore to replace and requires evac/fill of system. Either could cause the problem, so I bought both but my system is now working fine this year *knock on wood* but I'm out a good chunk of change for the parts. Oh well.....
Old 06-20-2012, 04:58 PM   #11
ur2punk
Member#: 30368
2003 WRX Sedan
Obnoxious Yellow
Hi Unabomber,
Thanks for the tip on the sensor by the grill. The expansion valve seems like something I'll definitely need my trusted mechanic to handle but if the sensor by the grill is "easy" maybe I can go that route first ... is there a name for that sensor I can search the part for?
DUH - I just found out that the thread with detailed pics on changing the expansion valve had more than one page so I need to read more anyways!
Thank you!
Rob
Common Problems for MY03 WRX Wagon??? mr_yellow General Community 12 04-05-2005 05:54 AM
What is normal oil consumption on MY03 wrx? vadim Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 03-07-2004 11:58 AM
Help Me Please .... Air Filter Problem with MY03 alfcanada Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 12-15-2003 06:18 AM
MY04 Gauges on MY03 NezorF Interior & Exterior Modification 3 05-17-2003 12:46 PM
Where to get alarm diagrams on MY03 factory system? evil's girl Electrical & Lighting 3 04-10-2003 08:41 AM
