Old 05-31-2012, 02:05 AM   #3551
shaman
Member#: 164259
DSMtoWRX, I have had the same problem, but when I used the remote start, and mine ended up with an empty 4L tank and a stumbling engine. The starter would do funky things to the Devil's Own controller causing it to run 100%. I moved the positive to the 3rd power setting (key in run position, and moved it to the fuse box), as well as a dedicated ground, and didn't have any problems. I wired up a switch to the power and solenoid just in case, but never had a problem. Just move the power and ground and see if that fixes things.
shaman is offline   Reply With Quote
Old 05-31-2012, 06:36 AM   #3552
klarowe
Member#: 284753
2004 WRX STI
World Rally Blue
Depending on where you had the wiring tied into the ignition source, they may have had to disconnect it for the remote start installation and then reconnected it incorrectly. I would def. check the wiring and take the power off an unused fuse (or if there are no unused fuses, use one thats not necessary for driving... ie cig. lighter, etc).
klarowe is offline   Reply With Quote
Old 05-31-2012, 11:10 AM   #3553
dsmtowrx
Member#: 48879
2010 STi 2.5xtr hsf6
Grey Stocker
Thanks guys. Still not sure how the controller is turning on the pump even if there is power there but makes was thinking something must be up with the power. I'll get under her this weekend and see if I can figure the wriring out myself. Install the meth myself but not the remote start so should be fun...
dsmtowrx is offline   Reply With Quote
Old 05-31-2012, 11:10 AM   #3554
dsmtowrx
Member#: 48879
Grey Stocker
Thanks guys. Still not sure how the controller is turning on the pump even if there is power there but was thinking something must be up with the power. I'll get under her this weekend and see if I can figure the wriring out myself. Install the meth myself but not the remote start so should be fun...
Old 05-31-2012, 01:13 PM   #3555
Aquamist
NASIOC Manufacturer
Member#: 110029
2004 Citroen Picasso
[quote=dsmtowrx;37265785]Thanks guys. Still not sure how the controller is turning on the pump even if there is power there but was thinking something must be up with the power. [quote]
You are the best person to find this out.
1) Where is the red wire of the molex wired to?
Aquamist is offline   Reply With Quote
Old 06-01-2012, 10:25 AM   #3556
dsmtowrx
Member#: 48879
Grey Stocker
molex? I assume that means the power supply for the board/controller?
Old 06-02-2012, 01:59 AM   #3557
Aquamist
NASIOC Manufacturer
Member#: 110029
molex is the 4-pin power in connector.
This is for the HFS-6...
Ideally, relocate the red wire of the yellow harness directly to the fuel injector (+). This way, the system can only come on when the fuel injectors are powered up.
Old 06-09-2012, 03:20 PM   #3558
dsmtowrx
Member#: 48879
Grey Stocker
Sticking relay... who knew! Got her going and finally a meth tune. Good times. Took me a while but glad it finally paid off. Brits must be doing something right with the addition of the ECUTEK map switching on the SI drive i have a meth map and no meth map at my figure tips. Again, good times
Old 06-09-2012, 06:14 PM   #3559
Aquamist
NASIOC Manufacturer
Member#: 110029
Never guess that in a million year.
ECUTEK has incorporated a switchable meth map?
Old 06-10-2012, 11:28 AM   #3560
dsmtowrx
Member#: 48879
Grey Stocker
Not neesacarily a meth map, but switchable maps on the fly regardless
Just handy for a meth map.
Old 06-10-2012, 04:09 PM   #3561
Aquamist
NASIOC Manufacturer
Member#: 110029
Amazed, I have asked them to do this since 2004. Better be late than never.
Old 06-11-2012, 12:54 AM   #3562
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Aspen White / Silver
Is there an upgrade path from DDS3/HFS6 to DDS4?
Token-Negro is offline   Reply With Quote
Old 06-11-2012, 01:44 PM   #3563
Aquamist
NASIOC Manufacturer
Member#: 110029
The HFS-6 is a more advanced syste on conventional engines. The HFS-4 is designed for DI engines.
Old 06-12-2012, 01:16 AM   #3564
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
What would be better on a DI engine, HFS6 or HFS4 in the end?
Old 06-12-2012, 03:32 AM   #3565
Aquamist
NASIOC Manufacturer
Member#: 110029
For DI engines, the HFS-4 is always better.
Old 06-17-2012, 01:47 PM   #3566
leonbmx
Member#: 82864
2005 MPS Wagon HTA35
Domtuned Stage $$$$$
Hi Richard,
I recently purchased a HFS-4 twin tank setup from Howerton Engineering, and I am about to hook it up. I just have a few questions:
I have a 2005 STi with a quad nozzle setup, 4 x 0.8mm, nozzles, one on top of each manifold runner.
Is there anything special I need to do to the board or any adjustments I need to make, like jumpers to solder or anything? Or is it really as simple as green wire to injectors (Pin B136 3/4/5/6), Red wire to Ignition (Pin B137 14) and Blue wire to MAP sensor (Pin B136 22)?
I am running 50/50.
Thanks!
leonbmx is offline   Reply With Quote
Old 06-17-2012, 02:45 PM   #3567
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Originally Posted by leonbmx View Post
Hi Richard,
I am running 50/50.
Thanks!
http://howertonengineering.com/wp-co...4/HFS4w-v1.pdf
Old 06-17-2012, 05:33 PM   #3568
Aquamist
NASIOC Manufacturer
Member#: 110029
Hi Richard,
I am running 50/50.
Thanks!
yes, just wire up as the diagram from Jeff Howerton.
You are injecting quite a bit of 50:50, what is your planned power output? Don't forget to configure the MAP sensor type (underside of the controller).
Old 06-17-2012, 08:56 PM   #3569
leonbmx
Member#: 82864
I have a twinscroll GT35R with 1000cc injectors. Thinking of around 550 AWHP.
If I look at the pressure vs flow graph (page 8), it seems that for 20% (50:50) of 1000cc injectors, so 200cc, and 135 PSi (25 PSi of boost), I should have used 4 x 0.6mm jets, rather than the 0.8mm's. Would you recommend switching them, or will the 0.8's be overkill, but fine?
Also, since I have 4 jets, I opted to not install any restrictor in the flow sensor, do you agree?
I have a 3.5 Bar MAP sensor, so I need to change the board, thanks for the heads up!
Old 06-18-2012, 06:54 AM   #3570
Mike Costin
Member#: 131787
06 STI,OB,OME XJs
Merkur Junkyard
Richard,
I was about to upgrade from a HFS-5 to a HFS-6 because so I can adjust the IDC gain and boost comp.
Now I read that the HFS-6 is discontinued.
What is my best option now?
Better to buy a HFS-4 or find a used HFS-6?
Thanks in advance
Mike Costin is offline   Reply With Quote
Old 06-18-2012, 02:57 PM   #3571
Aquamist
NASIOC Manufacturer
Member#: 110029
If you want IDC and boost pressure scaling, you need to get the HFS4. There is no direct upgrade path.
The HFS4 can do all the HFS-6 function. It is a good investment for the future when Subaru goes Direct injection.
Old 06-18-2012, 02:59 PM   #3572
Aquamist
NASIOC Manufacturer
Member#: 110029
Your calculation is correct, I didn't realize you have 1000cc injectors. No need to install a restrictor.
Old 06-18-2012, 03:57 PM   #3573
leonbmx
Member#: 82864
Just spoke to Jeff at Howerton and ordered 4 x 0.6mm and 4 in line check valves, so now I am good to go!
Thanks for the feedback!
Old 06-18-2012, 04:01 PM   #3574
Aquamist
NASIOC Manufacturer
Member#: 110029
Good. Post some updates.
Old 06-19-2012, 06:48 AM   #3575
Mike Costin
Member#: 131787
06 STI,OB,OME XJs
Merkur Junkyard
Alright Richard, HFS-5 to HFS-4 it is
Two questions about minimizing conversion time / chiropractor bills:
- Is the old style 100 micron inline puck filter functionally equivalent to the new in-tank filter (besides its propensity to leak with aging hose)?
- Is the old Shurflo pump 4-bolt footprint / mounting pattern the same as the new Aquatec pump 4-boot footprint?
Thanks Richard!
Passing the NEW required OBDII Emissions test in PA Questions and Answers!! mrtrex Mid Atlantic Impreza Club -- MAIC 29 03-10-2013 07:23 PM
Snow Performance questions and answers... Ultimate Collision Center Water/Methanol Injection, Nitrous & Intercooler Cooling 374 09-23-2008 04:36 PM
Motörhead Guidlines, questions and answers here: GO LEMMY!! El Camino Off-Topic 9 01-20-2006 02:39 PM
Roll Center, questions and answers Arnie Brakes, Steering & Suspension 5 12-21-2004 03:26 PM
