Old 06-11-2012, 07:53 PM   #1
MtnXfreeride
Member#: 228010
2012 WRX Prem Hatch
Dark Gray Metalic
Default Stock Blow Off Valve Chirp?
I dont have my WRX yet, its at port getting all purty with some accessories.
But... what I have always wanted is the sound of a blow off valve (BOV). I have also read some bad stories about their use voiding warranty..
So my question is... is there a whistle trumpet that can be attached to the stock BOV to get that chirping sound?
Example: http://www.rallysportdirect.com/Go-F...ment-Low-Boost
But this product is only for the GFB BOVs.
Also looking for opinions on which aftermarket BOV would least likely cause warranty issues.
MtnXfreeride is offline   Reply With Quote
Old 06-11-2012, 08:02 PM   #2
dirtslayer
Member#: 242550
2002 impreza wrx wag
olive drab
Shhhh troll
dirtslayer is offline   Reply With Quote
Old 06-11-2012, 08:07 PM   #3
MtnXfreeride
Member#: 228010
2012 WRX Prem Hatch
Dark Gray Metalic
Originally Posted by dirtslayer View Post
Shhhh troll
I really did use the search feature first lol... I know it sounds dumb.. but I just want the sound for now till the car is older.
Asking for this would be trolling:
Old 06-11-2012, 08:19 PM   #4
Omega_2nr
Member#: 298119
First off this is int eh wrong section. This section deals with body mods, and interior trimmings.
Secondly, OP, lets think about this - S L O W L Y.
The stock BPV (bypass valve) doesn't make much of a sound, because it doesn't vent the air to atmosphere - it routes it back to the intake like a sealed unit.
So where exactly are you going to mount a trumpet on this "sealed unit"?
The only way would be to disconnect the return line, and make the stock BPV vent to the atmosphere, thru this trumpet you speak of.
If you do that, doesn't that make the stock valve act like an aftermarket one? So won't it create the same "issues" you're worried about?
Use logic here bub.
Secondly, I actually tried using the stock BPV on my old '02 WRX in a vent-to-atmosphere (VTA) mode for all of 2 hours, just out of curiosity. If the new GH/GR WRX's are anything like the older models, then the stock BPV will NOT work well in this manner, and your car will stall and will hesitate - ALOT.
You want the sound? Get an aftermarket BOV and adjust it PROPERLY. Do a search for the "Real Dirt on BOV's" or something like that. The creator of that thread had some useful advice...this was waaay before he had an attack of the USc/Unbr arrogance syndrome.
If you are worried about your warranty, then leave the stock valve ALONE, and get your jollies by putting an exhaust on.
Now run, run quickly dear OP, for the brotato crew is coming to bash.
Omega_2nr is offline   Reply With Quote
Old 06-11-2012, 08:27 PM   #5
MtnXfreeride
Member#: 228010
2012 WRX Prem Hatch
Dark Gray Metalic
Well thanks for explaining.. if I knew enough about BOVs or had my WRX and could look myself, I wouldnt have to ask.
Old 06-11-2012, 08:36 PM   #6
Omega_2nr
Member#: 298119
^^Agreed. I'm well aware of that, which is why I took the time to explain.
Oh, and this thread will be of much help to thee:
http://forums.nasioc.com/forums/show...l+dirt+on+bovs
Old 06-11-2012, 11:50 PM   #7
xSUNSHINEx
Member#: 232107
2005 Sti
I wasnt aware it voided the warranty...but I have a ssqv2 and love it..no need to adjust anything...plug and play. however...your car will run like crap when you first put it on..and many people will tell you it will forever run like crap. I either got used to it..or it doesnt run like crap. The ssqv has the high pitched chirp you are probably looking for
xSUNSHINEx is offline   Reply With Quote
Old 06-12-2012, 12:28 AM   #8
rob1n1
Member#: 276425
2013 335is
Alpine White
Old 06-12-2012, 12:38 AM   #9
BlackJavaPearl04
Member#: 198522
98 LGT Limited
00 LGT -WRX swap
a 50 /50 after market valve would be your safest bet. Theres a popular one that alot of the tuners and engine builders like to use its called forge race bpv.
BlackJavaPearl04 is offline   Reply With Quote
Old 06-12-2012, 12:41 AM   #10
timeXlost
Member#: 113924
2005 STI....SOLD!
93 RX7...Not Broken
Well...there is a way for the stocker to make noise.....
timeXlost is offline   Reply With Quote
Old 06-12-2012, 01:28 AM   #11
STI-Bryan
Member#: 322955
The only real way to do it is to attach a duck-call to the BOV
STI-Bryan is offline   Reply With Quote
Old 06-12-2012, 06:50 AM   #12
Omega_2nr
Member#: 298119
It runs like crap because it was not adjusted prperly.
I never had any issues with my SSQV.
Old 06-12-2012, 09:50 AM   #13
Tsujen
Member#: 269643
15 WRX Limited
Just buy a spt intake and you'll get some BOV sound and turbo spool
Tsujen is offline   Reply With Quote
Old 06-12-2012, 10:35 AM   #14
EvoXtoWRX
Member#: 304819
2016 WRX STi
Crystal Black Silica
^^This would be a better use of money. BOV "sound" isn't plus it doesn't improve the performance of the car.
EvoXtoWRX is offline   Reply With Quote
Old 06-12-2012, 11:16 AM   #15
Trudd84
Member#: 250706
2004 Impreza WRX
I have a Turbosmart Dual Port BOV, I run it 50/50, had to adjust a little to get back to target boost, because it is 50 and does recirculate a fair amount of air it isnt extremely loud but it has the blow off, idles perfect and I enjoy it a lot.
Trudd84 is offline   Reply With Quote
Old 06-12-2012, 12:02 PM   #16
tobylazur
Member#: 150289
2006 05 CTSV, SV650
1972 Travelall
Use logic here bub.
I'm glad I'm not the only one.
tobylazur is offline   Reply With Quote
Old 06-12-2012, 02:44 PM   #17
TEK112
Member#: 218140
2009 WRX Prm Sed DGM
Know my friend Hiram?
TEK112 is offline   Reply With Quote
Old 06-12-2012, 09:31 PM   #18
jimbosv650
Member#: 261307
04 wrx wagon
I've done this, and yes it does give you some noise.
http://forums.nasioc.com/forums/show...ht=16+cent+mod
jimbosv650 is offline   Reply With Quote
Old 06-12-2012, 09:35 PM   #19
ClassicPurcell
Member#: 299709
1999 Toyota Camry
Shhhh troll
Only dreams now...
ClassicPurcell is offline   Reply With Quote
Has anybody modified the stock blow off valve to be louder? kenshiro Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 06-13-2012 12:28 AM
2007 Wrx Sti Stock Blow Off Valve And Stock Intake Box mr2fastn2fine Engine/Power/Exhaust 0 03-11-2008 02:35 AM
WTB sti stock blow off valve/ bypass valve foresterxtguy Private 'Wanted' Classifieds 1 08-04-2006 09:10 AM
Stock Blow Off Valve NJSILVERSTREAK Private 'For Sale' Classifieds 2 04-16-2004 06:31 PM
stock blow off valve....... jetsiphon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-23-2003 12:27 PM
