Old 06-13-2012, 01:24 PM   #1
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Default Gauging interest - another rod player in the market
Hey Guys,
Looking to get your feedback on something. I'm wondering if there's room in the market for yet another stock replacement rod.
What we're looking at is a Subaru chromo forged unit in stock dimensions.
Specs would be for just over 1,000 HP for the set with a weight of under 600 grams with a price point of just slightly more than the heavy mid-range rods.
If we get enough positive feedback on this one I'm willing to commit the money today to get the project started.
Old 06-13-2012, 01:37 PM   #2
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
I think there is room in the market for a quality rod. If it has a cost about the same as Manley turbo tuff I beams, if they can hold similar hp and weight around 550 grams we have a winer.
Old 06-13-2012, 02:42 PM   #3
berdugo
Member#: 163108
07 EuroDM STi 2.5L
600 grams is a bit too heavy for a rod. What is the material used and what is the design? Is it H or A beam or something else?
600 grams for a rod is around pauter territory already.
berdugo is offline   Reply With Quote
Old 06-13-2012, 04:48 PM   #4
3MI Racing
Member#: 200987
Rod weight should be down around 540 grams. Still finalizing a few things.
Old 06-13-2012, 04:58 PM   #5
Bamofo
Member#: 159743
07 STI Limited
TurboMike Tuned 2.35
Having another vendor selling good rods is always nice, but having the 1000hp only rod will limit you to a smaller portion of the market. I'm sure it will be a great design and with the right marketing from you, and what looks like 3MI Racing you should have some success as your opinions are highly influential on this site. However, the run of the mill Subaru Enthusiast that doesn't follow this forum and just want a fix, light build, or even moderate build would be getting most of their advice from their local vendor which will vary depending on where in the country they are located. Either way good luck with your design and deployment for future High HP builds!
Bamofo is offline   Reply With Quote
Old 06-13-2012, 05:23 PM   #6
3MI Racing
Member#: 200987
You can think of it as a rod that will last over 500 whp (unlike the cheap H-beams) and won't cost an arm and a leg (Carillo and Cosworth) or weigh an arm and a leg (Pauter and Manley).
Trying to fit into the happy medium for the community.
I can't come close to touching the price of the cheap H-beam market as I can get them from the same Chinese foundry at $250-300 a set pending options (when purchased in 10 sets). These are billet 4340 rod and come standard with L19 rod bolts and oiling notches. They utilize my hybrid I-beam design as well.
So they resemble the rod below but have several dimensional differences, as this is a pic of a 300M long rod. This one weighs in at 537 grams, rated for 1200 hp and are 134.5mm in length. Spec'ed for 10,500 RPM with a 530 gram piston package.
or a couple sets of them and one old 4" bore 'full round' piston
Everyone likes pictures
Old 06-13-2012, 05:35 PM   #7
juanmedina
Member#: 133146
Sign me up for a set
Old 06-13-2012, 05:51 PM   #8
B.R.E.D
Member#: 289606
06 WRX
white
If you guys make it a production part and its reasonably priced I would consider using them in our engines that use a standard length rod.
The Chinese H-Beams are fine for 400-450hp but I no longer trust that at over 500whp that they are strong enough.
The Pauters and the Manley I-Beams are to heavy. Ill shoot you a email about what we are currently using later and what we are looking for.
Matt
B.R.E.D is offline   Reply With Quote
Old 06-13-2012, 05:54 PM   #9
3MI Racing
Member#: 200987
^^^Matt, these were the same rods I'd discussed with you several weeks back.
Old 06-13-2012, 05:58 PM   #10
B.R.E.D
Member#: 289606
06 WRX
white
I figured that was the case
Old 06-13-2012, 07:55 PM   #11
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
id pay big money for a rod that you can rate at a true healthy 1000 whp.
Old 06-13-2012, 08:10 PM   #12
albersondh
Member#: 196882
08 WRX
Do it, they will sell. Give me a reason to return these tt rods.....
albersondh is offline   Reply With Quote
Old 06-13-2012, 08:13 PM   #13
jdpsearcher
Member#: 291214
2011 STI Sedan
PBP
That looks like a great rod....
jdpsearcher is offline   Reply With Quote
Old 06-13-2012, 10:11 PM   #14
gotsugg
Member#: 204014
02 02 WRB Bugeye
GTX3582 front mount turbo
This is exactly what I emailed you about. I'll need a set before the end of summer.
gotsugg is offline   Reply With Quote
Old 06-13-2012, 10:37 PM   #15
Juks
Member#: 108163
2015 WRX, 2005 STI
I'm just one person, but I'd be interested in a set for my next turbo.
Juks is offline   Reply With Quote
Old 06-14-2012, 03:34 AM   #16
nappingcub
Member#: 222725
2006 WRX
Sort of off topic but not... Why are the components of the engine rated for horsepower but the driveline supposed to be rated in how much torque they can handle?
nappingcub is offline   Reply With Quote
Old 06-14-2012, 08:55 AM   #17
moose00015
Member#: 180924
2007 Impreza WRX STi
2004 Forester XS Premium
I just blew a ringland on my motor and need to rebuild it. I'm debating between stock STi rods or possibly upgrading mine while I'm in there. I'm running an OG FP green on e85. Trying to get as much out of the turbo as possible. If there would work and are priced reasonably I'd be in.
I <3 TiC products and hear great things about 3MI.
moose00015 is offline   Reply With Quote
Old 06-14-2012, 11:40 AM   #18
bswilmington
Member#: 217563
2006 Sti 12.68 @ 108
321WHP 422WTQ dynojet SAE
Im in same boat. I have a set of sti rods, but if price is right and ETA is somewhat soon Im interested.
bswilmington is offline   Reply With Quote
Old 06-14-2012, 03:23 PM   #19
3MI Racing
Member#: 200987
Put simply, from an engineering point of view, I wouldn't rate a component in power or torque figures but it is what the general public can relate to.
Old 06-14-2012, 03:45 PM   #20
nappingcub
Member#: 222725
2006 WRX
I can understand using non-engineering speak so the general public can relate to it, but why not rate both of them in terms of torque or both in terms of horsepower? That's the part that has me a bit confused.
Not trying to start ish, just trying to wrap my head around how things are measured or related to when dealing with this stuff
Old 06-14-2012, 04:10 PM   #21
3MI Racing
Member#: 200987
The easiest unit to relate driveline to is torque.
I don't know why the industry chose horsepower for internals and this decision far out-dates me. I blame old school hot rodders or that fact that 'horsepower sells cars' (or parts).
I'd prefer to keep it as BMEP and then forces (mass and acceleration).
A quick read on BMEP
http://www.xplorer.co.za/articles/bmep.htm
Old 06-14-2012, 04:59 PM   #22
sense of nature
Member#: 112759
2002 STi Mikey Tuned
SexyRP
Soooo
When will they be avail in stock ?
Old 06-14-2012, 06:15 PM   #23
nappingcub
Member#: 222725
2006 WRX
Thanks for the explanation and link. Guess it is still going to be mysterious since people in general can't get to a consensus on how to rate stuff. Now wouldn't it be interesting if there were some standards on how drivetrain companies rate how much ft/lbs of torque their gears could withstand?
Back to topic - The approx specs would be:
HP : ~1000 CHP holding ability
RPM : ?????
Weight : ~540g
Length : OEM standard
Material : ????
Bolts : ????
I know you guys can't give more accurate info until you get your hands on some prototypes, but maybe update the first post with some better specs? Knowing TiC and 3MI, these things should be pretty cool. But as you've said pretty pictures and numbers are awesome.
Hopefully soon I will be ordering some more stuff from TiC and can talk to you guys about getting a cow sticker to throw onto my skidplate.
Old 06-14-2012, 07:04 PM   #24
Turn in Concepts
Member#: 93646
Many Track Records
RPM : ?????
Weight : ~540g
Material : ????
Bolts : ????
I'll answer what I can approximately, and Micah will fill in with more details.
RPM : Given weight paired with a decent 2618 piston offering 8K SHOULD be realistic PROVIDED you have the valvetrain to support it. In the end I would be more worried about the valvetrain than the bottom end even though it spins at half the speed.
Weight : ~540g
Material : 4340
Bolts : ARP L19
Now as this thread takes shape, and word starts to spread someone will ask the question of price. I know you guys haven't up until now because you all know how this works on this board as you've all been around for a while.
For those of you coming in who don't know how it's done -
A general range of price has been given. You WILL NOT see an exact or even tighter given rance on price in a tech thread. NO NO NO NO!!! It is very much against the rules of pricing things outside of the for sale areas. Even if mods let it slide from time to time there are vendors out there who will report us if we do (yes, things do get that petty), and frankly the forums are about our only form of advertising so do piss them off and cut off from being able to post threads like this would be very bad for business.
Old 06-14-2012, 07:18 PM   #25
moose00015
Member#: 180924
I know you can't do pricing but any ETA on timeline?
Gauging Interest - Install Day/Swap Meet in October - Orlando Area TJCrenshaw South East Region Forum 5 09-18-2010 12:30 PM
In the market for another Suby: Dealer/salesmen suggestions? Slack South East Region Forum 3 02-24-2010 03:55 PM
Gauging Interest on ZEN MP3 player tommy2hotty Private 'For Sale' Classifieds 0 12-11-2003 05:51 PM
2 upcoming meets in Connecticut + gauging interest for another Six Flags meet in MA! Zapix New England Impreza Club Forum -- NESIC 10 07-03-2003 04:46 PM
New AWD player on the market. ILP Performance.com Tri-State Area Forum 0 09-02-2002 09:49 PM
