Old 06-12-2012, 03:29 PM   #1
Rockclimber399
Member#: 309680
Default 96/97 ej20g in 99 legacy OB questions
Hey guys, I don't have many posts but I've been lurking for quite a while now. I believe I have most of what I need to know in order but I just wanna confirm a few things.
Firstly I've done several swaps in the past but never attempted wiring. I've checked out some great guides for merging harnesses and am pretty confident it won't be a problem. Now onto the questions.
Is my ecu Pinout going to be identical to the 2.5 rs of the same year? (I was 2.5 stock) meaning can I just use those diagrams for my harness merging?
I just got a whole front clip with the rear LSD and axles included from a local importer for 2k. Does the rear diff drop right in? Do i need the rear axles, and if so do they need to be modified? Should I utilize the 5mt that is included? And to confirm i believe i need to swap the crossmember because im going to a turbo motor? Simply from a mileage standpoint it seems like a decent idea.
I plan on pulling the manifold and painting it, while I have it on the stand are there any seals I should be replacing? Should I do the hg's/timing belt/water pump? I rebuilt my ej25 three times and got tired of its weak points, and I'm curious what preventative stuff I should do before dropping it in, as I don't know this motor very well.
I guess I had a few more questions than I realized. Thanks guys in advance for any help/pointers you have.
I'll be posting pictures of the progress.
Rockclimber399 is offline   Reply With Quote
Old 06-14-2012, 08:14 PM   #2
Rockclimber399
Member#: 309680
*crickets*
Anybody?
I know there is tons of knowledge on here, was kinda hoping more for a "welcome to the community, check out xx or yy"
99 Legacy GT questions The G.O.A.T. Legacy Forum 3 03-08-2012 05:45 PM
JDM Momo Airbag in 99 Legacy gt help needed snowjob Subaru Conversions 10 12-09-2011 06:01 PM
96 tt motor into 99 legacy gt help Met202 Newbies & FAQs 0 08-26-2008 08:40 PM
99 Legacy Outback questions nsnguyen Legacy Forum 6 04-29-2004 12:32 AM
Doing a ver 6 ra swap in 97, 98 or 99 impreza L questions mrtrex Normally Aspirated with bolt-on Forced Induction Powertrain 24 07-12-2002 07:18 PM
