Old 06-09-2012, 04:33 PM   #1
CSwrx22
Member#: 216675
07 Impreza WRX
UGM
Default 98 forester motor help
What's going on everyone? I have a quick question about a motor for a 98 forester that I picked up. It had a blown motor where the connecting rod on a piston failed and shot it through the top of the block. Now I'm just trying to figure out what my best options are for replacing the motor. What years will bolt right in and work with my existing ecu and such. Also will a motor from an automatic car work with my 5spd trans and bolt right up? Also what other routes can I go that will work with minor modifications? I'm not looking into doing a crazy build just something to get it back on the road an drive for a while without problems such as head gaskets and such. Thanks alot in advance. Hope to get some advice.
CSwrx22 is offline   Reply With Quote
Old 06-09-2012, 04:38 PM   #2
CSwrx22
Member#: 216675
07 Impreza WRX
UGM
Few pictures for those interested.
Old 06-09-2012, 10:56 PM   #3
CSwrx22
Member#: 216675
07 Impreza WRX
UGM
Bump it up for some help.
Old 06-10-2012, 11:24 PM   #4
CSwrx22
Member#: 216675
07 Impreza WRX
UGM
bump thinking of swapping in a 2.2
Old 06-11-2012, 01:13 PM   #5
CSwrx22
Member#: 216675
07 Impreza WRX
UGM
No one at all has any input on this?
Old 06-11-2012, 01:56 PM   #6
Gr3en
Member#: 160991
05 Corn Burner
Dirt Silver?
Your best options are getting a replacement EJ25D to throw in. I believe an EJ22 would work but would be a step back in power.
Check out rs25.com for lots of info on this kind of swap.
Gr3en is offline   Reply With Quote
Old 06-11-2012, 04:15 PM   #7
69subaru360
Member#: 159682
1995 WRX
2015 F150
95-98 EJ22. It bolts right in and all the wiring plugs in. You won't even notice any difference in power.
Engine needs to be from a car with an automatic so it has an EGR valve or you will have a constant CEL.
If it's a 96-98 you need to get the single port header from the car it came out of.
Old 06-11-2012, 04:39 PM   #8
CSwrx22
Member#: 216675
07 Impreza WRX
UGM
Awesome. Thanks
Old 06-14-2012, 08:07 PM   #9
CSwrx22
Member#: 216675
07 Impreza WRX
UGM
found myself a motor but now the question is will either clutch work? between 97-98 impreza and 98 forester?
Old 06-14-2012, 08:22 PM   #10
69subaru360
Member#: 159682
1995 WRX
2015 F150
Yep, just use your existing flywheel and clutch. It bolts right on.
Old 06-14-2012, 08:29 PM   #11
CSwrx22
Member#: 216675
07 Impreza WRX
UGM
So either clutch will work. I figure I will be replacing the clutch while I had the motor out. Just been reading that the 2.2 motor will feel very slow in the car. Is this true?
Old 06-14-2012, 08:32 PM   #12
69subaru360
Member#: 159682
1995 WRX
2015 F150
No, you won't even notice the difference.
Old 06-14-2012, 08:35 PM   #13
jamesfacts
Member#: 51282
98 RS
black & blue from parking
I would recommend JB weld on the old motor. Doesn't look bad.
jamesfacts is offline   Reply With Quote
Old 06-14-2012, 08:38 PM   #14
CSwrx22
Member#: 216675
07 Impreza WRX
UGM
Alright awesome. Thanks alot. Anywhere you know of to get aftermarket single port headers?
Old 06-14-2012, 08:39 PM   #15
69subaru360
Member#: 159682
1995 WRX
2015 F150
Maybe ebay?
A used stock one should be cheap though, say $20 maybe.
Old 06-14-2012, 08:48 PM   #16
CSwrx22
Member#: 216675
07 Impreza WRX
UGM
I'm getting a set with the new motor but if they are bad and rotted or somethin just want to have an idea of where to get replacements. Any other pointers on this swap?
Old 06-14-2012, 08:55 PM   #17
69subaru360
Member#: 159682
1995 WRX
2015 F150
Nope just put it in and go. It's a direct replacement.
Old 06-14-2012, 08:58 PM   #18
CSwrx22
Member#: 216675
07 Impreza WRX
UGM
Alright thanks again. You were very helpful if anything comes up or I have more questions I will be posting here
Old 06-15-2012, 12:36 PM   #19
sexyyrex
Member#: 128022
2015 Mustang GT
what were you doing for the c-rod to let go that bad? how many miles on the motor?
sexyyrex is offline   Reply With Quote
Old 06-15-2012, 01:04 PM   #20
CSwrx22
Member#: 216675
07 Impreza WRX
UGM
I bought the car like that. The previous owner said she was just driving to work on the highway, the car clunked. Then steam followed then the car died and coolant all over.
Old 06-15-2012, 06:33 PM   #21
CSwrx22
Member#: 216675
07 Impreza WRX
UGM
another quick question, will the alternator, ac compressor and power steering pump from the original forester motor fit the new ej22?
Old 06-15-2012, 07:11 PM   #22
69subaru360
Member#: 159682
1995 WRX
2015 F150
Yes45
WTB : EJ25 98 Forester motor kevdog2 Private 'Wanted' Classifieds 7 03-24-2011 09:59 PM
Motor for 98 Forester mazdamitch333 Private 'Wanted' Classifieds 3 06-08-2009 01:50 PM
98 Forester Problem?? Help??? stiscooby99 Transmission (AT/MT) & Driveline 13 09-11-2008 05:45 PM
how hard to swap in a 99+ sohc motor into a 98 forester? macantley Normally Aspirated Powertrain 3 06-06-2007 12:15 AM
New motor for 98 Forester the-one1 Subaru Conversions 2 02-21-2007 09:06 PM
