Old 04-22-2012, 10:40 AM   #26
dorkbert
Member#: 309901
2012 Impreza 2.0i 5D
I think the particular camera used was designed as a replacement of license plate illumination for Forester.
dorkbert is offline   Reply With Quote
Old 04-22-2012, 10:52 AM   #27
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
Correct, i was hoping to do that with my hatch, but the lights are too deeply recessed
BrysImpreza is offline   Reply With Quote
Old 04-22-2012, 10:54 AM   #28
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
Originally Posted by bobdole888
Sounds like the LED light is visable? I was hoping that it would be the IR type light that is not visable to human eyes but provides illumination for the camera.
It has IR as well, the illumination was for replacement of the license plate illum. But i hooked it up anyway
Old 05-01-2012, 02:00 PM   #29
nubsub
Member#: 313575
2012 Impreza 2.0i HB
thanks for the pictures and inspiration, Brys. not sure i'm up to the task of doing this, but something i'll keep in the back of my head if i'm feeling adventurous.
Old 05-01-2012, 02:03 PM   #30
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
If you've ever installed a stereo, it's like Modding 102, intro to electrical mods.
It's really easy.
Old 05-01-2012, 02:25 PM   #31
nubsub
Member#: 313575
It's really easy.
ha: thanks for the encouragement
i've done some basic stereo installs usually using existing factory wiring so i have less experience snaking wires around from the front to rear of a car from scratch.
i'm ok with electrical connections in general (i've done tons of stuff in other sort of adventures unrelated to car stereo --although, i'm a poor solderer in general, but i do a passable job or can get a friend who is better at such things)
anyway, just to clarify a few things:
from what i gather from you posts, there are three wire runs needed to get this to work. the only one i can picture is the set of wires giving power/signal/switch (to turn on from reverse circuit already in HU) connected via the 8pin harness from the HU all the way back to the camera itself. how many physical wires from this harness make their way back to the camera? all 8?
are the additional two bundles? is there extra power needed for the camera's LED light to work? do you some how splice off power from some of the other factory lights in the hatch? i would think that you wouldn't want any power going to the camera unless your were in reverse.
sorry if these questions are unclear or i've missed the obvious...
Old 05-01-2012, 02:35 PM   #32
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
1. Camera is powered through a 12v source, i chose to tap into the reverse light on the drivers side, snaking the wire up the C-pillar to the rubber tunnel at the top of the hatch, and to the camera (orange wire is 12v+ on the harness. Black is - )
2. The camera was meant to replace a license plate illumination, since it will not work like that on my car, i also tied that into the reverse power. The draw is negligible, so i didn't bother with a new circuit.
3. The only wire that goes to the radio is the yellow AV cable, that is easy to run along the floor, and door sills.
4. The 8 pin connector from SVXdc has the AV input and a ground, the spade on the ground should be put under a screw on the side of the stereo.
The reverse signal is being sent to the radio already, the ground just completes the circuit and puts the radio into camera mode automatically when you put the car in reverse.
Old 05-01-2012, 02:40 PM   #33
nubsub
Member#: 313575
thanks for the detailed clarifications.
one more question: so this means that the LED light on the camera is only on when you are in reverse? clever solution!
Old 05-01-2012, 03:29 PM   #34
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
Correct, on my camera they are wired separately due to their intended use, i tied them together to act as additional rearward illumination, helps as i have 20% tints and live in the woods!
Old 05-09-2012, 10:56 PM   #35
ST Eye
Member#: 73068
2008 STI Boost Wagon
2012 Impreza Limited ISM
BrysImpreza, did you mount the camera offset because of the trunk release being in the center?
Old 05-10-2012, 06:32 AM   #36
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
No, i mounted it there because there was a notched cutout there, a rubber grommet behind it and clips for a bundle of wire.
Further research showed that as the factory location on the JDM models, and the 2013 USDM Crosstrek model.
Old 05-11-2012, 10:20 PM   #37
ZURCALED12
Member#: 309754
2012 Impreza Sport L
Ice Silver Metallic
Waterlogged
I opened up the hatch and the wires are not there, nor is the mounting bracket for the factory camera. One could probably be fabricated or purchased from a Forester. I switched to a Pioneer so I now have a spare camera if anybody is interested.
Check your PM I am interested if you still have the OEM camera.
ZURCALED12 is offline   Reply With Quote
Old 05-12-2012, 04:57 AM   #38
mulagain
Member#: 319912
Hi everyone, I just joined after a couple of weeks of lurking for my own selfish gains (particularly the camera and car audio DIY threads). Figured I should contribute at this point instead of just leeching
Here's my experience sofar w/the camera install on the 2012 hatchback. Thanks SVXDc for your help with the harness and troubleshooting!
I started by going the cheapskate route the first time ironically because of the lack of reference material on the 2012 HU, I figured I wouldn't be out much $ if it didnt work. Well, my advice is if you're at this stage, invest that $27 you're thinking of spending on a Fleabay camera elsewhere and buy quality the first time and be done. A cheap camera is cheap for a reason!
Here's the exact camera I started with: http://www.ebay.com/itm/CCD-SONY-CAR...item3a6e47793c. It was appealing because of the Sony CCD, 520 TV lines and 720x512 resolution and relatively little modding to get it to fit flush. Honestly? It had great picture quality when it worked - for 5 minutes.
I was banging my head because it worked perfectly without any issues when I finished the install, then when I went out to start my car in the morning it wouldn't display. Later the same day it magically worked again, and coincidentally the 'start it in reverse' symptom a few others have had seemed to fit... but then it stopped working when I parked to test it again and never turned back on. To be sure I tested it on a seperate battery and monitor today and it failed so I could rule out the harness or other factors being the culprit.
The good news is all the scouring I've done (all the 2012 specific posts here and on nasioc, google, etc.) did yield a good result.
$133: 2011 Subaru Forester Back-up Camera | eBay
It's a Subie dealer so it's definitelky OEM. $133 shipped isn't bad. Found it in Cali for $168 from another dealer as well.
http://parts.subaru.com/subaruparts/...bcat5=0&retval=
They don't list the specs (effective pixels/TV lines/lux) so I have no idea what the image quality will be. Does anyone happen to have these?
I guess the reason the OEM is more appealing is that it might fit the license plate light cutout w/some slight modding vs having to cut, drill or hide wires on the fascia.
Anyhow, I'll let you know how it goes despite what I end up buying. Not going to make the same mistake again though... either getting the Kenwood, the Forester OEM or really --> ideal camera would be the best balance of durability and image quality. Hmm...
Any suggestions? Is the 200 the best camera for ~$150? Id really like to see the specs on the Forester OEM camera. It's still surprising to me that there are no Impreza specific OEM cameras for sale anywhere since they are an OEM option on Imprezas outside of the US.
mulagain is offline   Reply With Quote
Old 05-13-2012, 09:39 AM   #39
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
I've been happy with this one, US seller, etc. It's a little big, but the quality is good.
http://item.mobileweb.ebay.com/viewi...d=280783021008
As for your reverse issue, I'd make sure you have a proper ground from your 8 pin harness.
Old 05-14-2012, 02:33 AM   #40
bobdole888
Member#: 316658
2012 Impreza limited
5dr silver
How does one get access to the reverse light wire?
Do you just cut the wire at the boot at the top of the hatch?
Or do you pickup the wire near the light socket?
I looked at the back up light and couldn't figure out an easy way to access the back up light.
Do you have to remove the clear light cover to get access?
I'm used to getting access from inside the trunk, but this impreza has a large one piece hard plastic behind the backup light. It doesn't seem right to be removing the whole hard plastic to get access to the light bulbs.
Thanks in advance for the help.
Also what's the easiest way to remove the plastic cover on the inside of the hatch? I assume this will be necessary to mount the camera to the hatch, and work from behind the hatch?
Old 05-15-2012, 01:44 PM   #41
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
1. Where ever you feel most comfortable gaining access, i did it at the light and snaked the wires up the C pillar to the hatch.
2. First, pull off the plastic by the 3rd brake light, then the 2 side pieces, under those are 2 small phillips screw plugs, take those out THEN the hatch panel.
Just tug it with gentle pressure
Old 06-14-2012, 09:15 PM   #42
ST Eye
Member#: 73068
So yesterday I was bored and decided to install the backup camera. I am very happy with the results, it looks very OEM. Since my car is a Limited it has the chrome trunk trim. The camera I bought has a slim profile and has a chrome metal casing. Without further ado:
I routed the wires inside the factory wire loom. I had to remove all the electrical tape from the factory and re-taped it back up.
This is how I wired the power to the camera.
Old 06-14-2012, 10:11 PM   #43
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
not trying to be a jerk, but really what is the point of a backup camera any vehicle, let alone the Impreza. you are suppose to turn around when backing up anyway.
Old 06-14-2012, 10:17 PM   #44
dorkbert
Member#: 309901
because there may be obstructions lower than your rear windshield?
Old 06-14-2012, 10:20 PM   #45
ST Eye
Member#: 73068
What if there was a bicycle that was left right behind you rear bumper? It can also help with parallel parking.
Old 06-14-2012, 11:08 PM   #46
eps105
Member#: 205153
2014 Forester 2.5i
Venetian Red
I guess you've never read any of those many stories over the years showing how rear visibility in cars and trucks has gotten worse and worse due to high sills and styling, to the point where in most cars have like 20-30' blind spot directly behind.
I have the rear camera in my Outback and will NEVER, EVER buy another car without a rear camera. It doesn't replace using your mirrors and turning around, it supplements it in many useful ways.
It is indispensable for parallel parking, backing into a tight parking space, watching for toys or small children directly behind you, and -- my favorite -- when making a tight 3 point turn, you can back up to within an inch or two of the object behind you when it appears in your rearview mirror that you would have hit something several feet sooner.
Try it, you'll understand.
eps105 is offline   Reply With Quote
Old 06-15-2012, 04:51 PM   #47
TObject
Member#: 320185
2012 Impreza 2.0i
Originally Posted by bobdole888 View Post
Genuine camera from Subaru is $169.
http://parts.subaru.com/subaruparts/...cat5=0&retval=
This is camera only. No display. You use the stereo's display.
Have you seen the following?
http://subaruonlineparts.com/pdf/H001SSC700.pdf
It appears, Forester has a special bracket pre-installed for aiming the camera. Do we have the same bracket on Impreza, or what is the go?
TObject is offline   Reply With Quote
Old 06-15-2012, 05:54 PM   #48
TObject
Member#: 320185
2012 Impreza 2.0i
Quick question: is the head unit capable of powering the camera through the video wires?
Old 06-15-2012, 06:05 PM   #49
TObject
Member#: 320185
2012 Impreza 2.0i
One more question:
Is Clarion CC4001U the correct plug-and-play model for our head units?
Old 06-15-2012, 06:12 PM   #50
nubsub
Member#: 313575
i definitely like this for parallel parking. i still don't have a very good idea of the "extent" of my HB yet.
i think this job is a bit beyond what i want to do myself, and wonder aloud if this will be an option in 2013 and whether or not dealers will be offering the option to install it on 2012s.
Finally got the chance to retrofit my 2012 Impreza Sports Premium JDMSTA Electrical & Lighting 258 Today 01:07 AM
95 legacy rear crossmember into 95 impreza? greg donovan Subaru Conversions 1 10-02-2010 01:07 AM
2000 2.5 rs rear lsd into 97 impreza abs?s oooo Transmission (AT/MT) & Driveline 7 07-01-2009 10:15 PM
anyone retrofit hid's into their impreza? scooter4483 Mid West Subaru Owners Club Forum -- MWSOC 15 09-29-2008 04:35 PM
Message Board Statistics All times are GMT -4. The time now is 08:08 PM.
