Mid Atlantic Impreza Club
Closed Thread
Old 06-16-2012, 02:25 PM   #1651
supranite90
Member#: 240847
2011 STi
Put my JNA intake on and got it retuned....almost gained 30-40 HP from the previous tune which my tuner said was blocky as hell
supranite90 is offline
Old 06-16-2012, 04:00 PM   #1652
ImNOrobo
Member#: 255716
Itsa bugeye 04, V9
RHD and it makes me smile
Did another log today and went through the steps provided but the uego still wasn't working. I tired calling ppayer38 but no answer.
Once I figure out how to load the log on here I will post it up. Here is a hint, 18.55 lbs at 2352!!!!!! It holds 18.55 until 5800 then drops very slowly. Twinscroll with avcs.
ImNOrobo is offline
Old 06-16-2012, 04:40 PM   #1653
Hayes25
Member#: 319380
Added a chinese takeout box for ****s and giggles
Hayes25 is offline
Old 06-16-2012, 08:50 PM   #1654
lilblue619
Member#: 288292
2004 sti
wrb. the blue one.
Where did you get that
lilblue619 is offline
Old 06-16-2012, 09:17 PM   #1655
silver007
Member#: 196756
2007 WRX TR
weathertech floormats...great fitment
silver007 is offline
Old 06-16-2012, 09:34 PM   #1656
Ntrpriz
Member#: 294989
2011 WRX STI
Dark Gray Metallic
Install new perrin rear shifter bushing! It Actually lowered some gear noise and made a huge difference!
Ntrpriz is offline
Old 06-16-2012, 10:31 PM   #1657
Highflyr
Member#: 289162
PBP
washed, clayed, washed again, then waxed.
picture doesn't do it justice
Highflyr is offline
Old 06-16-2012, 10:40 PM   #1658
RossLH
Member#: 147839
SRP
Likely from a Chinese restaurant.
RossLH is offline
Old 06-16-2012, 11:33 PM   #1659
EvileyeZ88
Member#: 233501
07AD 337/335SAXWAGON
99 outback sport
I've got a little tiny bucket in that same place
EvileyeZ88 is offline
Old 06-16-2012, 11:37 PM   #1660
AJ711
Member#: 6178
98 GM67 + 03 SG6
2 whls > 4 whls
Installed new (to me) 02 WRX limited slip differential with my MY98 pinion gear into the MY98 rear differential case, installed bearing caps, checked lash, put rear cover on, filled with fluid, installed axles, lifted back into place, bolted all together, installed lateral links and other suspension bits removed earlier and torqued the axle nuts down. All I have left is to install the cat-back exhaust and fire the car up to test things out. Everything turns nicely, no weird noises or grinding, lash checks out perfectly and I'm excited to have finally put a LSD in the car.
AJ711 is offline
Old 06-16-2012, 11:43 PM   #1661
NCWreX
Member#: 166088
2007 WRX
340hp/340tq
Installed a P&L straight pipe to go with my P&L rotated 30r. Lovely exhaust notes with a hint of turbo.
NCWreX is offline
Old 06-17-2012, 08:42 AM   #1662
lilblue619
Member#: 288292
2004 sti
wrb. the blue one.
No way jose
Old 06-17-2012, 09:43 AM   #1663
EvileyeZ88
Member#: 233501
99 outback sport
Installed a GS MCB and replaced a missing center cap.
Braking feels a lot more confident, and not seeing my axle nut is
Old 06-17-2012, 08:27 PM   #1664
zeroburnWRX
Member#: 209118
2006 STI
Impreza WRX STi
Installed some JDM V7 Sti Seats in my 2002 WRB WRX. Some comfy a$$ seats and very tight around the body.
Also installed some motegi mr118 wrapped in Kuhmo 225/45/17's.
zeroburnWRX is offline
Old 06-17-2012, 08:57 PM   #1665
foothill
Member#: 292246
2010 Badge Snob +
Orange Line & SCape Mask
Like the seats!
foothill is offline
Old 06-17-2012, 09:25 PM   #1666
yuephoria
Member#: 64624
2008 FS XT
WR Blue Pearl
Vacuumed the interior, washed the Weathertech floor mats, and sprayed some 303 Aerospace Protectant on the dash.
yuephoria is offline
Old 06-18-2012, 08:59 AM   #1667
Grinder34
Member#: 252410
07 STI
Mine dont stay in place, and the hole for the hook is in the wrong place. Do you have similar issues?
Grinder34 is offline
Old 06-18-2012, 11:07 AM   #1668
VXSS
Member#: 115345
'15 STi LTD
ISM
Busy weekend.
Sti - got a bath and wax.
Forester - Installed sport grille and window visors.
VX - Replaced PCV, new boost gauge, new supercharger belt, replaced headlamp bulbs, and replaced sub amp.
Twas a perfect weekend for shadetree wrench turners!
VXSS is offline
Old 06-18-2012, 11:45 AM   #1669
2.5_IMP
Member#: 163604
Add some chopsticks sticking out of it!
2.5_IMP is offline
Old 06-18-2012, 11:51 AM   #1670
08WRXNUBE
Member#: 166524
2008 Spec C
SSM
Glue them in there and glue some rice together on to said chopsticks.
08WRXNUBE is offline
Old 06-18-2012, 12:18 PM   #1671
God&Sme
Member#: 256567
2002 PSM WRX - SOLD
97 GSXR = FAST
ordered a window regulator from subaru
put plastic over my driver side window AFTER it started pouring down raining
God&Sme is offline
Old 06-18-2012, 01:32 PM   #1672
mhoerath
Member#: 131379
2003 354 [email protected] rpm
justablue hatch
began my anti heat sink project using reflecta-gold:
http://www.designengineering.com/cat...r/reflect-gold
applied to inside of turbo heat shield and applied to fmic...but ran out and now more on order.
mhoerath is offline
Old 06-18-2012, 06:34 PM   #1673
ppayer38
Member#: 234407
04 Self-tooned
STi
Wrapped my exhaust finally!
Also prepped the Rota's for paint just gotta decide on a color now haha
ppayer38 is offline
Old 06-18-2012, 08:29 PM   #1674
XxNitr0xX
Member#: 288380
2006 STI
Here's your sign.
but I have seen fake carry-out boxes, for some reason so.. http://www.ebay.com/itm/FAKE-FOOD-MI...-/200581431319
Normal ones, in fancy designs..hmm..next new fad?? http://www.fancyfortunecookies.com/C...iners_s/46.htm
XxNitr0xX is offline
Old 06-18-2012, 08:48 PM   #1675
07VTRex
Member#: 179023
07 CGM WRX TR
Dom 1.5xtr + PPG's
fixed the clunking sound i had coming from my front end. i originally thought maybe it was the strut top nut coming loose but i could not have been further from the truth. also without a lift i would never have been able to diagnose it.
check it out
http://www.youtube.com/watch?v=3Z-2_...ature=youtu.be
07VTRex is online now
Closed Thread
What did you do to your car today? Jester808 Texas Impreza Club Forum -- TXIC 3235 08-05-2013 12:55 AM
what did you do to your car today? Schrecken Bay Area Impreza Club Forum -- BAIC 11 09-25-2012 03:08 AM
What did you do to your Scoob today? Sheehan North West Impreza Club Forum -- NWIC 27 11-23-2007 12:02 PM
