Old 06-13-2012, 03:19 PM   #276
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
Originally Posted by BeBop86 View Post
Which coilovers did you go with? H&R Streets? Did you stick with the 'stock' spring rates?
They are the H&R coilovers purchased through Perrin Performance, I believe they are the streets. They use a bilstein damper though, and are quite good for what they are, a street entry level coilover system. They are lacking in a multitude of areas, non adjustable strut body in relation to spring perch, non dampening adjustable, etc. They use relatively soft spring rates (I will have to check my notes but I believe it is 450 lb/in in front and 287 lb/in in the rear). I know the rears are ludicriously soft, the only reason I can think of is due to the extremely long stroke of the rear suspension. They are a good entry level street coilover, but as my earlier posts have said, they are the weak link to my current suspension setup as they were never designed to handle this type of grip. I have put a band aid on the situation through the use of large sway bars (27mm rear and 24mm front), but in the near future I will be upgrading to a quality set of dampers when I do my 05+ sti tranny swap. I didn't want to purchase coilovers now, as I knew the swap was in the future and wanted to take advantage of the 05+ beefier wheel bearings.
So ... they will be replaced in the near future...
soccer05 is offline   Reply With Quote
Old 06-14-2012, 02:45 PM   #277
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
Rebuilding the Stoptech caliper and making sure all seals are new. While my brakes looked to be in excellent condition, I don't trust such a critical component without taking it apart and refreshening it. I disconnected the brake line and stuck a piece of wood between the pistons. I then put my compressed air hose into where the brake line attaches to the caliper and shot a burst of compressed air in the caliper, which popped out all 4 of the pistons. After calling Stoptech I found out their WRX brake kit does not have any internal seals because of the crossover pipe, so you could split the caliper without needing a seperate set of seals. This greatly simplified working on the caliper. Then it is just a matter of removing the dust boots and the internal seal for each piston.
Uploaded with ImageShack.us
Old 06-16-2012, 02:55 PM   #278
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
Originally Posted by scby rex View Post
Have you tied in your power wire to the engine bay yet? Im currious how you did it.
Yes the wiring for the batery is 95% complete, I just need to purchase and determine how I am going to mount the battery cutoff switch and it will be completed. I just can't find which camera has the pictures of my install process. Let me dig around and find them.
Old 06-16-2012, 10:00 PM   #279
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
When you do the hub and tranny swap are you keeping the r160? Also are you going to use 5x100 redrill hubs on the 05 hubs, like what LIC offers?
scby rex is offline   Reply With Quote
Old 06-17-2012, 02:33 AM   #280
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
After splitting the caliper and removing the piston, the next step is replacing the seal inside the cylinder. When you buy the caliper rebuild kit, they come with dust boots and the inner seal. Costs about $25 for each size piston, so about $50 per caliper. Using a set of precision screwdrivers, you remove the inner seal from the culinder, about 3/4 of the way down the cylinder. You then lube up the new seal with brake fluid, and fit in the cylinder. Here is a picture of the groove, its hard to get a clear picture, as my camera kept focusing on either the caliper or the background, but here is my best shot.
Old 06-17-2012, 02:32 PM   #281
steffy27
Member#: 323447
looking good!
steffy27 is offline   Reply With Quote
Old 06-18-2012, 03:09 PM   #282
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
Picture of Stoptech piston ready to be installed in the caliper. I removed the pistons to make sure their was no surface rust or seizing issues, as I got this brake setup used. In retrospect, I wish I had saved for a new setup, as the brake setup was still expensive, plus with all the extra parts to refurbish them, I am probably in the ballpark of a new setup, especially since I do not have the slotted 355mm rotors. Oh well, this will do fine for my current setup though. Pistons seemed in good shape, so I just lubed them lightly with my brake fluid (motul rbf600) and slid them into place. I placed the dustboots on prior to installing the pistons, so I could just press fit them into place and the caliper would be complete for reassembly. You must be extremely carefull with the stoptech dust boots, as they are an extremely supple/thin leather, and tear on the inner metal ring quite easily. At 25 dollars for a pair of two dustboots and seals, they aren't ridiculously expensive, but can definitely add up if you tear a few.
Old 06-18-2012, 03:09 PM   #283
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
Another view of the piston ready for assembly.
Old 06-19-2012, 02:17 PM   #284
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
One of the last major products to complete before I can finish reinstalling my interior and getting this car on the road is flocking the dash and a pillars. Here is the dash completely removed but intact except for the passenger air bag and center dash clock. Both of these have been removed to be flocked seperately, as this will help get those crisp lines and give a professional appearance. For those that are building all out track cars, deleting the air bags is a very wise and substantial weight reduction, my passenger air bag alone must weigh 25 pounds. Here is the last time we will see the dash looking this oem. First step is disassembly, I need to remove all the vents and trims that I do not want covered in the flocking fibers.
Old 06-20-2012, 02:46 PM   #285
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
First step to flocking the dash is removing everything that you do not wish to have covered in glue and flocking fibers. This will help ensure crisp lines and a professional finished result. First I removed all the dash ducting from the backside of the dash.
Old 06-21-2012, 11:22 AM   #286
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
Air vent trim is removed. These are just popped in by hand and can be removed with a small flat bladed screwdriver. Just take your time as you don't want to break them.
Old 06-21-2012, 12:25 PM   #287
CobbWRX
Member#: 310040
2004 WRX and 15 sti
Are you doing the flocking yourself?
And what is the benefit from the flocking no glare?
CobbWRX is offline   Reply With Quote
Old 06-21-2012, 12:36 PM   #288
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
Probably looks / anti-glare
BeBop86 is offline   Reply With Quote
Old 06-21-2012, 01:58 PM   #289
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
Yes, that is all complete, fuses installed in cabin, distribution block mounted to engine. All that is requires is for me to remove the oem grounding straps and replace with larger gauge cable to ensure adequate grounding. I just have to find the pictures, I can't seem to find them anywhere. If I can't find them I will snap some more and get them posted. Really a simple setup though, 0 gauge wire to the oem battery tray, distribution block mounted on battery tray, with 4 gauge wire from distribution block to starter. Had to use the distribution block to branch power off to go to the oem fuse box location by the washer fluid container. Very simple to install and allows easy access to wiring for jump starting and timing light connections.
Old 06-22-2012, 09:53 AM   #290
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
That is exactly it, the flocking is a cheap and effective way to eliminate the glare off the dashboard. As a side benefit, when done properly I think it looks great, hardcore and functional. I will also be flocking my a pillars to eliminate annoying glare and make a clean integration of my aem wideband gauge without doing excessive work. Clean looking, easy, cheap, and functional, that's win win in my book.
Old 06-23-2012, 12:24 PM   #291
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
Next step is to sand the dash with 80 grit sandpaper. This is just a light sanding, and is to break the smooth surface of the dash to promote better glue adhesion for the flocking process. I was worried about the ability for the glue to bond to the dash, as when I went to mask off certain areas the tape kept sliding right off. Technically, this alone would do quite a bit at reducing glare off the dash, but if you have come this far then you might as well do a little more work for a nicer finished result.
Old 06-25-2012, 03:15 PM   #292
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
Minor update, Stoptech front brakes completely rebuilt, refreshed, and flushed of old brake fluid. Completely installed with Stoptech street/track pads front and rear. Should provide a significant increase in all areas of braking performance, pedal feel, fade resistance, etc. Very impressed with the overall fitment and build quality of Stoptechs product. Can not wait to finish up the couple little remaining projects and take this car for a spin and find out where the cars new limits are at now. I will be updating this thread with pictures of how to completely rebuild stop tech calipers. Additionally, dash is in a little homemade booth and will be flocked my next day off work. Progress has been slow lately with lots of loose, little projects, but a lot is starting to come together.
Pics to come soon...
Old 06-26-2012, 11:14 AM   #293
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
Dash completely stripped, all vents and trim pieces removed, ready to have glue spread on and flocked. Slowly getting all the prep work done to ensure a quality finished product. Entire dash was lightly sanded with 80 grit sandpaper to promote proper adhesion of the flocking fibers to the dash.
Old 06-26-2012, 04:47 PM   #294
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
Dash has been completely flocked and I must say I am very pleased with the end product. Dash looks amazing exactly how I wanted it to look. I took a pic off my iPhone but can figure out how to upload it, so I will post pics from the digital camera up tonight. Definitely impressed with the end result. I was a little nervous about doing this because if I messed it up it was going to be a costly fix, but the product I used was excellent. Dash is currently drying and can be installed for 72 hours, but so far very happy, hopefully the end result looks as good as it does right now ... Pics to come later.
Glad to be well on the way to finishing off my interior and getting one big step closer to getting this thing out of the garage and back on the road where she belongs.
Old 06-26-2012, 09:22 PM   #295
CobbWRX
Member#: 310040
2004 WRX and 15 sti
is the flocking a soft feel or how does it feel? i am thinking about doing all of the plastic thats not black in my wrx now!
Old 06-28-2012, 08:50 AM   #296
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
Stoptech dust boots successfully pressed into the caliper. This part was an absolute bear, as I had to purchase an extra set of both size seals because I kept on tearing my dustboots. The dustboots are made out of a rather supple rubber, and have a large wire around the circumference to retain the boot once installed. You must have the exact size press of the outer circumference of the caliper to press in the dust boots, anything else will end up tearing the boots. I can't tell you how frustrating this part was, as it is really not that hard to rebuild calipers, and if it is time consuming you expect to be spending time removing a seized piston, not struggling with the dust boots. I ended up using a small amount of cut pvc pipe to successfully install the dust boots.
Old 06-28-2012, 08:55 AM   #297
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
reassembly of the caliper after pressing in the dustboots proceeded rapidly. I reconnected the two halves of the caliper by bolting on the 4 bolts that go through the two caliper halves. After consulting with Stoptech these were torqued to 40 ft/lbs. You don't want to overtorque any of these through caliper bolts as it would be tragic if you stripped the caliper body. Then you reinstall the crosspipe that allows fluid transfer between the two caliper halves. I was really impressed with the overall design of the Stoptech calipers, they do not use any internal seals for fluid transfer to the two halves, all the equalization of pressure is done with the cross tube. This greatly simplifies rebuilding as well as reducing the chances of little leaks.
Old 06-28-2012, 08:56 AM   #298
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
Stoptech caliper completely rebuilt and ready to install on the car.
Old 06-28-2012, 08:58 AM   #299
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
Stoptech caliper installed on car and torqued to proper spec. Glad to finally get this task checked off the to do list, I can not believe how long a simple task like rebuilding the calipers took. I hate those dust boots....
Old 06-28-2012, 09:06 AM   #300
soccer05
Member#: 202554
2003 Impreza Wrx
Wrb
Stoptech street/light track brake pads installed. Everything slid together perfectly, have to love it when install is a breeze. Now it is just time to instlal the stoptech braided brake lines and bleed the system with Motul RBF600 brake fluid and my upgraded brake system will be complete. I love how easy the design of the Stoptech caliper makes swapping brake pads, remove two hex bolts and the bridge pulls away, then simply remove and reinstall your brake pads. This makes it extremely easy to swap pads at the track. It takes longer to remove your wheels than it takes to swap out your pads.
It's about damn time: Smurftastic's Bugeye Build Thread Smurftastic Member's Car Gallery 262 05-30-2016 09:08 AM
My GT3076R Bugeye Build... CKxx Member's Car Gallery 166 08-24-2010 02:24 AM
WI Bugeye build thread/my first 'motor build' CrashTest Mid West Subaru Owners Club Forum -- MWSOC 1 05-11-2010 11:00 PM
MY20G Bugeye Build Thread white02_WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 02-04-2010 08:02 PM
bugeye build.. Pike Alaskan Impreza Club Forum -- AKIC 55 04-03-2009 06:07 PM
