Old 06-16-2012, 01:13 AM   #1
Subawuu20
Member#: 317744
Default replacing power steering hose
Removing my ps pump this weekend i noticed my high pressure hose coming from the pump is hard as hell. I was initially going to replace the old clamps with new screw type clamps. It seems like the OEM ps hose are expensive from the dealership so can't i just go to autozone and buy power steering hose? I have searched and it seems like most people just replace the hose with OEM ones...
Subawuu20 is offline   Reply With Quote
Old 06-16-2012, 07:57 AM   #2
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
Old 06-16-2012, 05:18 PM   #3
Subawuu20
Member#: 317744
so its okay to buy power steering hose and make my own hose from the reservoir to the pump?
I just want to know if thats okay because I dont really want to buy something expensive
Old 06-17-2012, 12:59 AM   #4
dangerousatom
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
Yes, but you cant just make a high pressure hose with a length of hose and 2 hose clamps. The steering rack takes special fittings and the pump takes a banjo fitting. A braided stainless steel line will be around $100 with the correct ends.
dangerousatom is offline   Reply With Quote
Old 06-17-2012, 01:33 AM   #5
Subawuu20
Member#: 317744
Well can I or not? Your saying I can but I can't. And i would only need it the section from the resevoir to the pump inlet
Old 06-17-2012, 06:58 AM   #6
Legend2
Member#: 250595
04 wrx wagon
your high pressure one should be carefully made with hydraulic fittings,
your suction one from reservoir to the pump should be fine to be replaced with a similar grade hose.
you had mentioned to different hoses and they require two very different hoses/types
Legend2 is offline   Reply With Quote
inlet hose & power steering hose??? warui111 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 09-26-2006 02:36 AM
Changing WRX clutch and power steering hose question Ken-gv Service & Maintenance 1 07-29-2003 03:04 AM
Anyone KNow the specs on braided power steering hose? cpu77 Normally Aspirated with bolt-on Forced Induction Powertrain 3 04-02-2003 11:03 PM
"Aftermarket power steering hose swelling not proper hose for fluid" SEXY GC8 Service & Maintenance 2 08-30-2002 04:26 PM
Alert! power steering hose fitings are loose on some WRX's - - fluid leaks all over alfriedesq Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 12-30-2001 02:24 PM
