Old 06-08-2009, 10:47 PM   #201
charliew
Member#: 125304
fuji how come this is in the conversion thread? I like your head story but I thought it was in the built motor thread?
charliew is offline   Reply With Quote
Old 06-09-2009, 12:46 AM   #202
Chi_San
Member#: 53558
2002 WRX Wagon
Requesting a pic comparison: V8 Spec C compared to a USDM EJ205. If it's even possible. If not, no worries.
Chi_San is offline   Reply With Quote
Old 06-10-2009, 12:03 AM   #203
subieguy87
Member#: 153412
1998 Impreza wrxRS
Just for laughs, i've got a good "Head port comparison" for you guys...
Its some EJ25 N/A heads vs. EA61 heads (from a 1971 Subaru FF-1, the first boxer motor sold in the U.S... 1.1l displacement )
VW used boxers before that in the bug.
subieguy87 is offline   Reply With Quote
Old 06-10-2009, 12:42 AM   #204
Chi_San
Member#: 53558
2002 WRX Wagon
Were they available in the US?
Old 06-10-2009, 09:01 AM   #205
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
^^yes they were. However I think he meant first subaru boxer.
Old 06-11-2009, 01:46 AM   #206
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Originally Posted by charliew View Post
fuji how cum this is in the conversion thread? I like your head story but I thought it was in the built motor thread?
this was started here. i wished it'd be moved over and possibly stickied.
the STi heads I'm porting are done and thats the Double-D thread. Very interesting finds because I have all these heads on hand or accessible.
Old 06-16-2009, 10:29 AM   #207
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
The V8 Spec C are not any bigger than the Big Ports them selves. Have the Spec C heads measured via CNC machine and you can port the USDM EJ205 heads just like them.
Old 06-16-2009, 03:22 PM   #208
Chi_San
Member#: 53558
2002 WRX Wagon
I'm debating between EJ205 heads ported, or EJ207 V8 Spec C heads. This would be on an EJ207 shortblock. If I can find an EJ207 V8 Spec C longblock, then I'm going to jump on that. AVCS > EJ205. Depends on if the I&M ODBII machines in the Southern Oregon area can read the JDM ECU, and if they can't if I can do sniffer test instead. If that's a no-no, then I'll be limited to running EJ207 bottom with EJ205 ported heads on top anyway.
Having the EJ207 longblock would be nice, since i'm going to be getting an 2.5RS for a daily while my WRX is down. Once the WRX has a new engine, transmission, driveshafts, hubs, brakes, suspension, etc., everything leftover from the WRX will be going onto the 2.5RS.
Old 08-30-2009, 08:36 PM   #209
Solar
Member#: 79825
2000 Impreza 2.5 RS
White body + carbon hood
stock eg33 heads for visual reference/ comparison
Solar is offline   Reply With Quote
Old 08-31-2009, 01:28 AM   #210
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
now that's interesting. Sharing the phase1 EJ22E intake port inlet shape with EJ20 runner route and combustion chamber
Old 02-17-2010, 06:34 PM   #211
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
have you guys seen enough?????
GRB Dual AVCS. Runs the newer casting. I can see a similarity on my '06 WRX heads as well.
Old 06-10-2010, 12:52 PM   #212
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
B25 exhaust
S20/S20V/W20/D25/V25B/W25
Updated exhaust port listing^^^^^
Old 05-14-2011, 10:20 AM   #213
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Old 05-15-2011, 06:49 PM   #214
raggedoutsti
Member#: 255714
2005 STi
psm 20g 11.5 or bust!
Sticky this!
raggedoutsti is offline   Reply With Quote
Old 05-29-2011, 01:49 PM   #215
retsej
Member#: 135850
JDM 2006 Legacy GT heads, EJ20Y 2L motor, Quad AVCS
retsej is offline   Reply With Quote
Old 05-30-2011, 11:17 AM   #216
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
ah hA! I've seen that intake port before. Subaru still uses that on the '06 Leggy in Japan eh.. the arch from the inlet to the valve follows the big ports on that style port. Thanks for the pics!
Old 05-30-2011, 12:09 PM   #217
retsej
Member#: 135850
No probs, any suggestions on improving them would be appreciated. I'll be pulling it apart in the coming weeks, trying to measure the combustion chamber, going oversize valves and a stroker blah blah. May as well clean the heads up if I can while I'm there
Old 05-31-2011, 01:22 AM   #218
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
you can shape them to look very close to the big ports.
Old 06-13-2011, 11:39 AM   #219
retsej
Member#: 135850
Any more pics / info on the W25 head? I might have found a set, curious to see what the ports are like.
Old 10-04-2011, 11:43 PM   #220
sbrwrx
Member#: 296804
do you have any pictures about ej204 legacy jdm heads?
sbrwrx is offline   Reply With Quote
Old 10-05-2011, 10:25 AM   #221
Homemade WRX
Member#: 33782
96 bastard child
I have a set of 2.0L dual AVCS heads sititng in my living room (don't ask )
I however am wondering if the combustion chamber is the same. Mine cam with ports already plugged for what looks like direct injection.
I also have one of your pistons So did you want to get a forged set made or...?
Old 10-11-2011, 11:13 AM   #222
gmbart
Member#: 297130
1997 impreza L
custom gold/copper
heres some eg33 shots i have
this is the exhaust ports ported vrs ported the green circle on the right port is the size of the stock exhaust gasket
heres stock intake port
here s a partially ported intake port
gmbart is offline   Reply With Quote
Old 04-09-2012, 12:31 PM   #223
rek888v2
Member#: 71287
2002 WRX + 2004 STi
+ 2009 STi/WRBx2 and OBP
...and subscribed!!!
rek888v2 is offline   Reply With Quote
Old 06-18-2012, 08:53 AM   #224
Samurai Jack
Member#: 21145
2002 Enemy of Aku
.... also subscribing
Old 03-16-2013, 10:54 PM   #225
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
I thought this was interesting. So we got a Forester engine. We as in U.S.A.
JDM SG9 EJ255 with B25 heads
head porting and arp head studs..... ejsportcom Built Motor Discussion 6 03-24-2006 12:05 PM
IL: Gruppe-s header, TXS TBE, APS UP, Axis Stg 4, Ported heads, Ported TB, Manifold BLUETURBOWRX Private 'For Sale' Classifieds 20 03-06-2005 06:19 PM
IL:Gruppe-s Header,TXS TB,APS UP,Axis Stg 4, Ported heads,Ported TB,Manifolds & more. BLUETURBOWRX Mid West Subaru Owners Club Forum -- MWSOC 14 02-23-2005 09:47 PM
throttle body & head porting? JST Normally Aspirated with bolt-on Forced Induction Powertrain 5 07-23-2002 08:24 AM
Message Board Statistics All times are GMT -4. The time now is 12:31 PM.
