Old 06-19-2012, 08:19 AM   #1
darkbug
Member#: 317711
2012 Impreza 5-spd
Cherry
Default adding lumbar support to driver's seat
Has anyone pulled apart the seats in the 2012 Impreza? I am planning on adding a lumbar pad or bladder to the seat back.
Possibly looking at this: http://www.sportsimportsltd.com/univ...r-support.html
darkbug is offline   Reply With Quote
Old 06-19-2012, 03:37 PM   #2
tornado542
Member#: 280370
2012 Sport Premium
Ice Silver Metallic
Ive done it to fix the seat squeak. Easy way to do it is to put a small pillow, or foam padding under neath the spring that is in the seat. Takes about 5 minutes to do. Opening the seat is just 2 zippers on the side of the seat back.
tornado542 is offline   Reply With Quote
Old 06-19-2012, 03:42 PM   #3
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
Are you describing how to fix the squeak, to add lumbar support, or both?
Old 06-19-2012, 03:54 PM   #4
tornado542
Member#: 280370
2012 Sport Premium
Ice Silver Metallic
I pulled the seats apart to fix squeak, and at the same time found out a good way to install lumbar support (underneath the seat spring)
...so yes...
refer to my other thread for squeak fix
Old 06-19-2012, 09:12 PM   #5
darkbug
Member#: 317711
2012 Impreza 5-spd
Cherry
Ill give that a shot! Didn't realize it would be that easy.
Old 06-21-2012, 12:21 AM   #6
gfxguy
Member#: 316583
2012 Impreza SP 5MT
MBP
I did this tonight since I found the lumbar support lacking. I used a little removable pillow that comes with obus forme back rests that I had lying around and slid it up between the springs and the foam in the seat back. It definitely helped, and I was able to adjust it while sitting in the seat by reaching back (before zipping up the seat, obviously). I'll know for sure how much it helped on my commute tomorrow, but if it's not enough I'll just find something beefier to put under there. Super easy, thanks tornado!
gfxguy is offline   Reply With Quote
Adding lumbar adjustment to stock '07 STI seats vetteboi88 Interior & Exterior Modification 0 01-04-2011 03:30 PM
Stop whining about your seats with a inflatable lumbar support. BryanH Interior & Exterior Modification 13 03-02-2006 02:36 PM
Add lumber support to STi seats? STi300 Interior & Exterior Modification 5 06-09-2005 01:27 PM
Inflatable lumbar support for stock seats? where? yakker General Forum Archive 6 01-12-2001 12:23 AM
Message Board Statistics All times are GMT -4. The time now is 11:02 PM.
