Old 06-20-2012, 01:20 AM   #1
timeXlost
Member#: 113924
2005 STI....His
2010 EVO....Hers
Default 9.5 rpf1's, chargespeed, wingless and scoopless...full feature up now.
http://beastcoast.us/2012/08/24/not-your-standard-sti/
ill update this as i find more pics, they are everywhere...
WRX STi by DumePhotos, on Flickr
Yellow Brembo by Max Youmans, on Flickr
clean by timexlost, on Flickr
timeXlost is offline   Reply With Quote
Old 06-20-2012, 01:33 AM   #2
domestic_abuser
Member#: 126696
2002 Fatbody bugeye
03 R1 09 Raptor 700R
Super clean, the Brembos are massive!
domestic_abuser is offline   Reply With Quote
Old 06-20-2012, 01:37 AM   #3
GutterShark
Member#: 282835
2006 WRX
Awesome.
GutterShark is offline   Reply With Quote
Old 06-20-2012, 03:13 AM   #4
fgtyper
Member#: 236959
05 LGT
RAINBOW
Mod list time now
fgtyper is offline   Reply With Quote
Old 06-20-2012, 03:49 AM   #5
wadud
Member#: 258048
06 wrx
E.S.A.C
Looks Great Bro!!!!!!!!!!! Godspeed
wadud is offline   Reply With Quote
Old 06-20-2012, 03:50 AM   #6
JohnnyWas
Member#: 91010
2002 Subaru WRX
OG Blueberry
Absolutely Stellar!!
JohnnyWas is offline   Reply With Quote
Old 06-20-2012, 03:07 PM   #7
timeXlost
Member#: 113924
2005 STI....His
2010 EVO....Hers
Impreza WRX
Originally Posted by fgtyper View Post
Mod list time now
Engine:
Stock bottom end
Stock heads
Tgv deletes
Blouch td05 20g 8cm
Cattless turbo back
Greddy evo 2 axle back
Grimmspeed ewg uppipe
Tial 44 ewg
Grimmspeed iwg bracket
CSS fmic
DW 740cc injectors
Walboro 255
Perrin side feed fuel rails
Gimmick inlet
Ks tech 73mm Maf
Grimmspeed 8mm spacers
Grimmspeed EBCS
Grimmspeed AOS
1 step colder plugs
Lots of heat wrap
Tuned by m@ at wicked innovation 360/360 @ 23 psi last year (now at 24 with ewg, tgv deletes, big Maf, and fuel rails)
Trans and driveline:
Act sprung 6 puck and hd pressure plate
Stock flywheel
Kartboy short shifter
Kartboy front shift stay bushings
Kartboy rear stay bushing
Tic front clicky kit
Tic rear clicky kit
Tic pivot bushing
Kartboy subframe outrigger bushings
Tic rear diff mount bushings
Tic trans crossmember bushings
Torque solutions driveshaft bushings
Torque solutions pitch stop
Group n trans and motor mounts
Suspension:
Endura-tech coilovers
Cusco rear camber plates
Ingalls camber bolts
Rce front and rear sway bars
Spherical rodend swaybar links
Tic lateral link bushings
Tic trailing arm bushings
Whiteline steering rack bushings
Kartboy rear lockdown bolts
2.5 degrees negative camber all around
0 toe
4.7 (i think) caster
Interior:
04 wrx front and rear seats
04 wrx carpet
05 wrx door cards
07 sti knob
Exterior:
Chargespeed v2 carbonfiber side skirts
Chargespeed v2 carbonfiber rear spats
Ravspec replica hks carbon diffuser
Sti limited front lip
Jdm version 8 front fenders
05 rs hood
05 rs trunk
Cleared headlights
Painted sti brembos
Rolled front and rear fenders
Wheel and tires:
18x9.5 +38 rpf1
245/35/18 federal 595 rsr
8mm spacers up front to clear brembos.
I know I've forgot something. Big power, built motor, new interior, and likely a color change will come over the winter.
Old 06-20-2012, 03:12 PM   #8
WRXSTI32
Member#: 314807
damn it looks good with the yellow brembos and Rpf1's
WRXSTI32 is offline   Reply With Quote
Old 06-20-2012, 03:12 PM   #9
JON-E25WRX
Member#: 225389
03 wrx, MBP 08V
rotated 35r bugeye
looks amazing!
JON-E25WRX is offline   Reply With Quote
Old 06-20-2012, 03:59 PM   #10
Shipman
Member#: 312847
06 STi/03 Forester
AW/PBP
That looks great, I love it
Shipman is offline   Reply With Quote
Old 06-20-2012, 06:10 PM   #11
timeXlost
Member#: 113924
2005 STI....His
2010 EVO....Hers
Old 06-20-2012, 06:12 PM   #12
Hate
Member#: 304868
2013 Impreza 5 Door
Lol i have 20 percent in cyl #4... suckssss but im building my motor and i would assume with your taste you are doing the same.
Hate is online now   Reply With Quote
Old 06-20-2012, 06:16 PM   #13
timeXlost
Member#: 113924
2005 STI....His
2010 EVO....Hers
Yeah, I'm a master tech... Everything on this car with the exception of the tune was done by myself. However, when it comes to the motor...I think I'm going to buy one from someone that builds them for a living. Wayyy too many quirks and variables when it comes to Subaru motors. If it was a dohc mustang engine... It would be done by now....but it's not lol.
That said....any motor builders out there want to hook a brother up? I can promise lots of attention haha.
Old 06-20-2012, 06:36 PM   #14
Slow_2.5
Member#: 292104
2006 Jawny jawn
Burple
Looks awesome. Scoopless looks so much cleaner. How do you like that turbo setup? I'm currently piecing together a similar setup.
Slow_2.5 is offline   Reply With Quote
Old 06-20-2012, 06:38 PM   #15
PlasticFoamMan
Member#: 197764
02 WRX Stage DD
PRND 01G
Looks great as always! I've gotta start going to NESIC meets, so many great cars out here.
PlasticFoamMan is online now   Reply With Quote
Old 06-20-2012, 06:43 PM   #16
Slow_2.5
Member#: 292104
2006 Jawny jawn
Burple
Old 06-20-2012, 06:46 PM   #17
low-n-slow
Member#: 313818
2002 wrx hybrid
love it..well done
low-n-slow is offline   Reply With Quote
Old 06-20-2012, 07:26 PM   #18
timeXlost
Member#: 113924
2005 STI....His
2010 EVO....Hers
Are you in Boston? We meet weekly on Wednesday's at various locations around the city. Tonight is the fours in Quincy, you should come
Out!!
I enjoy this turbo setup. It makes grew power for the size turbo. It builds boost crazy fast I see full booat by like 3500 rpm. Made 362 ft lbs at 3900 rpm. The car has not gone on the dyno since the latest round of motor mods and tune..
On thing I will say is that the turbo does not hold the power up top. Its a great dd turbo...I'd even go as far as saying its what the sti should have come with from the factory. I'll be going bigger when I replace the motor, I'd like to see 450 wheel on meth. I'm thinking a Dom 3 with cams will get me there.
Look for many of these current engine parts to go up in the for sale section in late fall.
Old 06-20-2012, 08:11 PM   #19
blessthekellen
Member#: 273859
MY98
WRX
This is terrific. I love this car. It is the sole reason I am going to be doing a peanut conversion on my bug eye.
Kudos my man.
blessthekellen is offline   Reply With Quote
Old 06-20-2012, 08:24 PM   #20
invaderzim
Member#: 201991
2011 impreza wrx ltd
satin white pearl
looks great dude. I really love the wheel and brake setup
invaderzim is offline   Reply With Quote
Old 06-20-2012, 08:29 PM   #21
04wrexsti
Member#: 225937
'10 Sti SE AW
'04 JBP FXT
god this makes me miss my JBP 04 sti... looks great man!
04wrexsti is offline   Reply With Quote
Old 06-21-2012, 10:40 AM   #22
timeXlost
Member#: 113924
2005 STI....His
2010 EVO....Hers
voltex by timexlost, on Flickr
Old 06-22-2012, 08:20 AM   #23
remotehuman
Member#: 201995
2005 bugeye
Flat White & whatnot
Wow Jared, I think you may have pleased everyone on NASIOC.... I thought it was impossible
STi 2 by Max Youmans, on Flickr
STi by tanks by Max Youmans, on Flickr
Also, dat diffuser
Black by Max Youmans, on Flickr
remotehuman is offline   Reply With Quote
Old 06-22-2012, 09:08 AM   #24
southstar01118
Member#: 294514
02 WRX
Love your car...I like the hood scoop delete I need one in my life lol
southstar01118 is offline   Reply With Quote
Old 06-22-2012, 09:44 AM   #25
Silver VR4
Member#: 240625
2006 STi
Excellent job, that car looks amazing.
Silver VR4 is offline   Reply With Quote
Finally some better pics of my car! westy2005 Member's Car Gallery 36 02-20-2008 10:23 AM
Finally got some good pics of my car, what do you think? Fitz12444 Member's Car Gallery 25 09-22-2004 05:23 PM
Finally took some OK pics of my car. Eric SS Member's Car Gallery 10 12-04-2002 11:44 AM
Finally, some killer pics of my car DanMan Member's Car Gallery 36 08-14-2002 04:11 PM
Finally got some good pix of my car... beingmarc Southern California Impreza Club Forum -- SCIC 10 03-14-2002 06:45 PM
Message Board Statistics All times are GMT -4. The time now is 11:44 AM.
