Old 06-19-2012, 04:58 PM   #5476
scoobymatt93
Member#: 254115
2009 Impreza 2.5i
Dark Grey Metallic
Just a sneak peak of what's happening soon
scoobymatt93 is offline   Reply With Quote
Old 06-19-2012, 07:04 PM   #5477
krzywhtboi82
Member#: 280582
2009 2.5i premium
ssm
I pit in a 34 series lol battery in mine. 1000 cranking 800 cold cranking and haven't had problems. Next will be optima just couldn't afford that at the time
krzywhtboi82 is offline   Reply With Quote
Old 06-20-2012, 08:24 AM   #5478
BSP671
Member#: 288190
2009 Impreza 2.5i
Spark Silver
anyone happen to know the center bore size for our imprezas? trying to order rims that are hub centric
BSP671 is offline   Reply With Quote
Old 06-20-2012, 09:07 AM   #5479
premier00000
Member#: 251060
2008 Impreza Outback
It's 56.1 (google is helpful)
Some companies that sell wheels include hub rings for specific cars with the wheels
Old 06-20-2012, 05:26 PM   #5480
Navysesal
Member#: 305008
2008 outback sport
Newport Blue Pearl
Does anyone feel a sense of power loss when they turn on their A/C? I know it's normal to lose some power but it seems to lose enough power to where the rpm drops and the car feels a lot more sluggish
Anyone else feel this and is it fixable?
Navysesal is offline   Reply With Quote
Old 06-20-2012, 06:00 PM   #5481
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
Roll your windows down
Haha, yeah I feel a power loss also. My rpms don't drop though but it definitely has lag.
Old 06-20-2012, 06:19 PM   #5482
BSP671
Member#: 288190
2009 Impreza 2.5i
Spark Silver
Same here and the rpm's don't drop as well. When I press the compressor kill switch going uphill it gets more peppy lol. Only really use the AC when my daughter is in the car
Old 06-20-2012, 06:28 PM   #5483
Cmac13
Member#: 312011
2009 impreza 2.5i
white
alright so today i noticed my car is making a squeak noise. it seems to happen right when a press the gas and when i let go, it also happens when i hit humps in the road sounds like its coming from the front end its not a consistent squeal just more of a one high pitched squeak. Anyone know what it could be?
thanks
Cmac13 is offline   Reply With Quote
Old 06-20-2012, 06:29 PM   #5484
premier00000
Member#: 251060
My car feels like its got half the power when the AC is on...
And who puts their windows down when the heat index is over 105? I know I don't.
Old 06-20-2012, 06:53 PM   #5485
TravisM
Member#: 295506
2011 Impreza 2.5i Pr
Dark Gray Metallic
I out right hate how slow my car feels with the a/c on I'll turn it off and drive till I feel woozy then turn it on.
TravisM is offline   Reply With Quote
Old 06-20-2012, 07:19 PM   #5486
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
Uh, Joke? I hear ya though.
All cars have a loss of power when the air is turned on. You're asking the alternator to work harder to charge the battery which in turn gives a power loss..
Old 06-20-2012, 08:25 PM   #5487
Navysesal
Member#: 305008
2008 outback sport
Newport Blue Pearl
I see, what if we change it to a better battery like a more efficient one. would it lessen the power loss? Or would it not with like that?
Old 06-20-2012, 08:53 PM   #5488
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
It may have more to do with the alternator and battery size but I do not know for sure. Just my assumption.
Old 06-20-2012, 09:44 PM   #5489
DirknJirkn13
Member#: 249696
2010 Outback Sport
DirknJirkn13 is offline   Reply With Quote
Old 06-20-2012, 10:00 PM   #5490
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
Umm... no it's mostly the AC compressor.. at least when the AC is on.. that's what's taking the power from the engine.
One thing I like about our cars though, if you floor it to pass, the AC automatically turns off temporarily to give you full power. I thought that was a neat feature. It actually works and I've noticed it happens even without totally flooring the accelerator.
Also, I just run my car at a slightly higher RPM to compensate. I have a 5 speed manual though.. Maybe it's harder to do that with a slushbox. It is a little harder to start out in first with AC on.. you have to be careful or sometimes it bogs down. Feels to me like a problem with the drive-by-wire tuning.. like it's trying to do something different with throttle than I want, and makes me press even harder on gas pedal to pull away smoothly.
That's one thing I wish our cars had- a real throttle cable.
BWX is offline   Reply With Quote
Old 06-20-2012, 10:16 PM   #5491
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
How do you run your car at a higher rpm? Drive faster or stay in 4th instead of going to 5th?
I've never had my A/C turn off when flooring it. Maybe new for the 09 models? Could also be when the fan is set higher then 1. I generally almost always have it set at 1, very rarely 2 or higher.
Old 06-20-2012, 10:45 PM   #5492
Claybay
Member#: 301059
2008 Impreza
What lip is that?
Claybay is offline   Reply With Quote
Old 06-20-2012, 11:08 PM   #5493
BSP671
Member#: 288190
2009 Impreza 2.5i
Spark Silver
Just install a window type AC unit and call it a day lol
Anyways, think I need to get an alignment done. The toe seems way off. Steering wheel wiggles significantly when I go up to around 60mph. But I'm just gna wait till I get my coilovers on
Old 06-20-2012, 11:23 PM   #5494
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
I do! It's super annoying, I usually just roll down the windows and drive a little faster
Perfect solution, now just find me one that works the same/better than oem and weighs half as much as the oem a/c unit
Also around that speed your alignment could be off or more likely your wheels/tires are not balanced. Or who knows maybe steering rack bushing is worn out?
Old 06-20-2012, 11:27 PM   #5495
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
Yeah, like today it was 95F here and I had AC blasting with fan on 3 all day.. Felt great!
What I mean is - say I usually am just putting around, I shift from 2nd to 3rd at around 2600 RPM... when AC is blasting, and AC compressor is sucking power (as well as alternator I'm sure), to go the same speed, I'll just rev it out to 3000 RPM, then shift.
It's exactly like driving up a small incline, to go the same speed, just use more of the engine's power by revving it out more. I don't even consciously look at tachometer.. and don't press gas pedal much further.. but I don't get that ''bogged down'' slow feeling you guys are talking about. I know exactly what you mean.. the AC does suck a lot of power out of a 2.5i..
Check the owner's manual.. that AC cut-off may have started in '09, not sure. I know there were a lot of changes in the base 2.5i from '08 to '09.
........edit......That only happens when you really get on it.. like passing or on-ramps. The AC light doesn't go off either, you can feel the cold air get a little warmer though. It feels like 'V-Tech just kicked in YO!' Seriously though I can feel the increase back to regular power level when it happens.. it does kinda feel like V-Tech.. a little bump in power.. same as if you reached over and clicked off AC.. Definitely noticable.
Old 06-20-2012, 11:43 PM   #5496
BSP671
Member#: 288190
2009 Impreza 2.5i
Spark Silver
couldn't be that cuz I just rotated and balanced the tires a few weeks ago....had the same problem on my old car, aligned it and it went away. Think what caused it was when I was driving and the edge of the asphalt caved in and almost took me down a ditch. When that happened i had to pull to the left real hard, and its been doing that ever since.
Old 06-21-2012, 12:15 AM   #5497
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
Could be balance still though..
They VERY OFTEN get it wrong. It also could be a wheel and/or tire imperfection where even if it is perfectly balanced, the bump on the tire will wobble your steering wheel or vibrate the car.
I sent one tire back to Tire Rack when I bought my wheel/tire combo because it had a bump on it. On the balance machine you could see it.. it was balanced but had a high spot that vibrated my car. The new tire fixed it..
Most of the time a bad alignment won't cause a wobble anyway, just bad tire wear and/or pulling left or right. Think about it..
Old 06-21-2012, 12:42 AM   #5498
BSP671
Member#: 288190
2009 Impreza 2.5i
Spark Silver
Oh well we'll see what happens when I slap my coilovers on and get it aligned. Just waiting till I have a free weekend to do it cuz been pooped out from work and have sideline gigs on the weekend.
Edit: Forgot that I still have to roll the fenders
Old 06-21-2012, 02:43 AM   #5499
Navysesal
Member#: 305008
2008 outback sport
Newport Blue Pearl
Yah I haven't really notice the a/c turning off automatically. Today was pretty hot but I only had the fan on 2 cause i had tints
Gosh it has made such a big difference in temperature
Old 06-21-2012, 09:50 AM   #5500
Cmac13
Member#: 312011
2009 impreza 2.5i
white
If you have nice tires don't wait lol I installed my coilovers and lowered my car and the toe was waaaaay off when I whet over those rubber pads on the train tracks it would squeak, so when I finally got an alignment the inside of my front wheels were almost bald
08 2.5i and 08 Sti Suspension WRXbrother Brakes, Steering & Suspension 7 03-24-2012 02:14 PM
Will an 08 WRX intake fit an 08 2.5i? Racing101 Normally Aspirated Powertrain 26 01-19-2012 11:57 AM
08 STI Wing on 08 2.5i impreza juny102004 Interior & Exterior Modification 13 01-18-2012 09:46 AM
Will 08+ WRX gauges swap into 08+ 2.5i? Simeon Priest Interior & Exterior Modification 10 03-26-2010 02:17 PM
08 2.5i mod question deunique1 Impreza Forum 1 10-03-2007 02:35 PM
