06-19-2012, 10:50 PM | #1 |
Member#: 319157
MAIC
Vehicle:2012 Impreza 4DR 5MT |
This is an analysis of the factory fill at 2800 miles after a hard break-in. The oil was never topped off.
Element Actual PPM / Typical PPM Aluminum 1/2 Chromium 1/1 Iron 29/7 Copper 154/5 Lead 1/5 Tin 2/1 Molybdenum 828/53 Nickel 1/0 Manganese 20/4 Silver 0/0 Titanium 0/0 Potassium 4/1 Boron 138/44 Silicon 330/10 Sodium 8/15 Calcium 1929/2187 Magnesium 12/266 Phosphorus 850/771 Zinc 792/937 Barium 6/0 Flashpoint 410F Fuel <0.5% Antifreeze 0 Water 0 Insolubles 0.2% SUS Viscosity @ 210F: 48.8 cSt Viscosity @ 100C: 6.89 Comments: High wear and silicon are common finds in new engines such as yours. The excess wear is due to new parts wearing in, while silicon is from sand-casted parts and sealers used when assembling your engine. With a few more oil changes, everything should read around if not better than, universal average levels. Those averages are based on an oil run of around 4200 miles. The viscosity was in the 5W20 range with no fuel or coolant present. No abnormal finds.
06-19-2012, 10:55 PM | #2 |
Member#: 315643
South East
Thankyou Commander Keen, I guess waiting till 7500 isnt a good idea
Im currently running Break in additive at around 3500 Interesting the Zinc levels are a little lower than average and Moly is way high This is a Zinc additive website stating a few facts about engine breakin with modern oils. #5 Redline oil and others are suggesting a 3,000-mile break-in for new engines! Proper seating of rings, with today's lubricants is taking that long to properly seal. Shifting to synthetics before that time will just burn a lot of oil and not run as well as hoped. For you science buffs: ZDDP is a single polar molecule that is attracted to Iron based metals. The one polar end tends to "Stand" the molecule up on the metal surface that it is bonded to by heat and friction. This forms a sacrificial layer to protect the base metal of the cam and tappet from contacting each other. Only at very high pressures on a flat tappet cam is this necessary because the oil is squeezed/wiped from the surface. This high pressure is also present on the gudgeon pin (wrist pin) in diesel engines, therefore the need for ZDDP in diesel engines. Second part of the equation is Molybdenum disulfide (Moly). The moly bonds to the zinc adding an additional, very slippery, sacrificial layer to the metal. I found out that too much of the moly will create problems; lack of this material reduces the effectiveness of the ZDDP. The percentage, by weight is from .01 to .02%, not much, but necessary. Last edited by auskip07; 06-19-2012 at 11:06 PM. |
06-19-2012, 11:15 PM | #3 |
Member#: 315353
NESIC
Vehicle:2012 Impreza Sp Prem 5MT OBP/DGM |
Interesting. Thanks for posting your oil analysis. I plan to have mine analyzed after my third of fourth oil change and the engine is fully broken in.
06-20-2012, 10:37 AM | #4 |
Member#: 302570
Vehicle:2013 XV DGM! |
I definitely need one of these tests.
06-20-2012, 06:01 PM | #5 |
Member#: 321966
Vehicle:2012 Impreza + XV 14 Black Pearl + White XV |
A mate went though a high oil usage issue with his BMW K1300S motorbike where he was using 600ml per 600miles of the specified Full Synthetic, after trying to resolve many times with the dealer for not being " fit for purpose " as a Sports Tourer he was quietly advised by the dealers mechanic to try it with Semi Synth but if he did it would void warranty.
06-20-2012, 07:00 PM | #6 |
Member#: 320185
Vehicle:2012 Impreza 2.0i |
Zink can lower the efficiency of the catalytic converter; higher levels of Moly can make the remaining Zink more beneficial. From what I understand, Moly is relatively harmless for catalytic converters; so seeing more of it is not surprising.
Thank you for sharing the analysis. |
06-20-2012, 08:20 PM | #7 |
Member#: 318622
Vehicle:2012 Impreza |
Thanks for the UOA. Can you post the viscosity. That's a nice shot of moly. Honda also uses high moly in their factory fill.
06-20-2012, 08:27 PM | #8 |
Member#: 319157
MAIC
Updated with viscosity.
06-21-2012, 08:05 AM | #9 | |
Member#: 322264
Tri-State
Vehicle:2012 Impreza Sp 5sp Obs Blk Prl/Drk Gray Mtl |
Does that sound about right? |
06-21-2012, 08:18 AM | #10 |
Member#: 302570
The car COMES with synthetic.
06-21-2012, 08:59 AM | #11 |
Member#: 322264
Tri-State
06-21-2012, 09:02 AM | #12 | |
Member#: 318753
South East
Vehicle:2012 Impreza Dark Grey |
06-21-2012, 09:09 AM | #13 |
Member#: 322264
Tri-State
I think it's dealer recommended (and I agree with this recommendation). I believe the owner's manual says you can wait until 7500 miles.
06-21-2012, 09:15 AM | #14 | |
Member#: 319157
MAIC
06-21-2012, 09:28 AM | #15 | |
Member#: 319378
MWSOC
Vehicle:2012 2.0i Sport Ltd. Satin White Pearl |
According to the manual, oil change at 3k miles is not required for the 2.0 engine, it is required at 7.5k miles, and synthetic oil is required. 0w20 is not even necessarily required, but advised for maximum efficiency. |
06-21-2012, 09:33 AM | #16 |
Member#: 89967
NESIC
Vehicle:2020 Volvo S60 Gray |
I think the majority of people suggest changing the oil at 3000 miles just because it could have a positive impact on the life of the engine. If you spend $20k+ on a car, quibbling over a $60 oil change isn't really worth it. Better to be safe than sorry I guess
06-21-2012, 09:35 AM | #17 |
Member#: 322264
Tri-State
06-21-2012, 09:45 AM | #18 | |
Member#: 322264
Tri-State
I assume that as long as I don't decide on Amsoil products, I can get everything at Autozone, right? |
06-21-2012, 10:02 AM | #19 | |
Member#: 319378
MWSOC
Edit: Actually the manual says 5w30 or 5w40 is OK for "replenishment" and 0W20 is "required for optimum engine performance and protection" A lot of people have been getting the 5qt Mobil1 oil at Walmart cause it is the cheapest. I got some Peak oil at shopthedude.com, and an OEM filter 3 pack and crush washers on ebay (Somerset Subaru). Comes to about $43 per change for me. Would be even cheaper with the Walmart oil. Last edited by Haunty; 07-21-2012 at 12:42 AM. |
06-21-2012, 10:07 AM | #20 |
Member#: 322264
Tri-State
I'm sure the Mobil1 would be fine. I'm a big fan of Castrol oils too.
06-21-2012, 10:18 AM | #21 |
Member#: 322264
Tri-State
OK, and just to confirm, the part number of the correct filter is 15208AA160, right?
06-21-2012, 10:33 AM | #22 |
Member#: 322264
Tri-State
Yup, Walmart is selling the 5-qt jug of Mobil1 0-20 full synthetic for $26.50. On eBay, it looks like I can get the Subaru-branded filters for approximately $7.50 each, if I buy a 3-pack (and $6.67 if I buy a 6-pack). So it looks to me like I can do my own oil change for under $40, and know that I put in the right quantity of the right product.
It looks like the non-Subaru oil filters sold at Autozone are similar in price to real Subaru filters from eBay, so I'd just stick with the Subaru filters. I don't know who OEMs the filters to Subaru. Still deciding between a Fumoto valve and top-side oil extraction. Would only go with the valve if I could reach it without jacking the car or driving up on ramps. Last edited by sgoldste01; 06-21-2012 at 10:39 AM. |
06-21-2012, 10:34 AM | #23 |
Member#: 315643
South East
Im a Castrol guy so thats what i have used in all my vehicles. Also adding a break in additive to the engine during the first 10k wouldnt be a bad idea. Beef up the zinc and possibly help the engine seat the rings sooner.
06-21-2012, 10:40 AM | #24 |
Member#: 319157
MAIC
Is it possible that the zinc drops out of the oil as it is deposited on to the engine?
06-21-2012, 10:48 AM | #25 |
Member#: 315643
South East
The metal is porus (to a certain extent) im sure the zinc plays a part in smoothing everything out. Even the cylinder walls. it might take a few oil changes to get the correct amount of zinc deposited in the engine.
Similar Threads | ||||
The oil analysis thread (blackstone, etc). | Nimbus09 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 1 | 01-22-2010 07:52 PM |
0W-30 Oil Analysis | richeich | Newbies & FAQs | 9 | 10-29-2000 07:36 PM |
