#12851 | |
Member#: 305664
#12852 |
Member#: 322264
Tri-State
Vehicle:2012 Impreza Sp 5sp Obs Blk Prl/Drk Gray Mtl |
General is not a big name except that it's now owned by Continental. I left my Altimax Arctics unstudded and thought they were awesome.
#12853 |
Member#: 305664
They have a summer tire Exclaim UHP I like as well.
#12854 |
Member#: 300420
Vehicle:2012 Impreza Sprt LT ISM |
Hey ST, thanks, its good to be back. How's ur scubie doing? Finally hit the 3k marker lol
Any customizations? Gonna get my tints done and hopefully get the retrofit headlamps done like jdm's |
#12855 |
Member#: 312955
I have 9000 miles in 4 months on the 2012 impreza. Used to drink oil during break in but no longer does. No problems so far. Only thing is that the windshield is weak and thin. I have a crack and chips already. Paint is ok so far. I'm in Alberta so they put a lot of rocks on roads in the winter and lots of SUV and truck drivers here too.
#12856 |
Member#: 313575
Vehicle:2012 Impreza 2.0i HB |
(cross posted with oil light thread)
hi everyone, i just completed my first oil change on my Impreza at 2689miles on the odometer, and as promised am reporting back on my experiences. 1. Jack or no jack or ramps after realizing that this car has the same problem as my wife's prius with minimal clearance that allows a complete loosening of the drain plug with a pan underneath, i decided to drive up onto a couple of 2x4's. the extra 1 5/8" made a big difference and the change was really easy. (i don't own ramps, and if this didn't work, i would have used my jack and jackstands) 2. oil color after nearly 2700mi, the oil was very dark. i can't say it was dirty, but it had enough carbon to have a very dark appearance. 3. dipstick prior to change: read right near the full mark or maybe 1/16" under the full mark. contrary to what others have experienced, there wasn't an appreciable difference in reading either side of the dipstick. 4. 5 qts of oil reading: after adding a full 5 quart container of Mobil 1 Fuel economy full synthetic 0w20, and letting the car run to fill thew new filter, the dipstick came up to the midpoint between the two marks. 5. 5.3 qt reading: i then added ~0.3qts (11 ounces out of a 32 oz quart container), and the dipstick came up to the full dot on both sides. my car's build date is Feb 2012, by the way, so i wonder if the dipstick and tube are different on my car vs others? i checked the dipstick multiple times for both pre change and post change and it was consistent on both sides of the dipstick. other notes: - i can't believe how thin this oil is. it drained out of the pan really fast. much faster than i'm used to with 5w30 oil on my old honda or my wife's prius. i was suprised that a slight shift in grade would have a perceptible difference. - the new oil seems even thinner than what i drained as evidenced by the way it coated the dipstick. i'll be curious if that will change as i put miles on this batch of oil. this is definitely something i'll be keeping an eye on. |
#12857 | |
Member#: 295513
Vehicle:2012 Imp Prem Hatch Camellia Red Pearl |
#12858 |
Member#: 300420
I can tell you from experience about the black ice. The day i got the car was late January, where it rained. The car did slip very so slight in the cold rain on my way to the tireshop. After the tire change, i immediate saw the difference.
The next day i went to the poconos where the following night it anowed heavily. I saw cars slip and slid down the hill while i maintained a good 30 mph, having a crowd witness my boldness. So im very glad i switch my avids to dws. Albeit, if i had stayed in the city and not drive up to snowboard and such, I'd keep the stock. |
#12859 | |
Member#: 73068
Vehicle:2008 STI Boost Wagon 2012 Impreza Limited ISM |
#12860 |
Member#: 300420
Wat kind of yellow fogs did u put? Did u separate the connection from the headlights? I hate how u have to turn on the headlights in order to have the fogs on... So tacky...
I just got the crossbars but im gonna wait til i put the 3m film on the roof before installing the bars. ...no holes to drill. ![]() Speaking of bars, r the bars pretty safe to keep once installed? There r four torx screws to tightened and thats it. Who's to stop from someone to just prop it loose and take it??? :/ maybe im just paranoid but i do live nyc and leave my car on the street. I was thinking of installing my bike rack and use its lock to secure the bars, but that defeats the purpose of being more aerodynamic. |
#12861 | |
Member#: 73068
Not sure about the cross bars, surprised that there is no protection against theft. Do you park on the street? |
#12862 |
Member#: 300420
Yea. :/ i really like jdm's system of lights. Want to do the same on mine. A little jealous he's got the white, super sexy! But I'm loving mine with silver on black look. Gonna tint out the rear lights, got black grill, hood deflector, side deflectors, and the black tints will definitely make it look very aggressive. After Jd's retrofit lights, im thinking of putting offroad piaa lights inside the grill.
^_^ |
#12863 | |
Member#: 313502
#12864 |
Member#: 322264
Tri-State
I was going to put yellow Lamin-X on my fog lights like I did on my VW Golf, but Lamin-X said they hadn't created a template for our cars yet.
When you put the yellow material from eBay on yours, did you have to cut the material to fit, or was it already sized correctly? And did you have to remove the plastic trim around the fogs before putting on the yellow material, or could you get a good result without removing any trim? |
#12865 |
Member#: 322264
Tri-State
Oops, double post.
#12866 |
Member#: 300420
Hmm. Soldering IS a good idea...
#12867 | |
Member#: 73068
#12868 | |
Member#: 322264
Tri-State
It should be easy, but I'm something of a bull in a china shop when it comes to removing plastic snap-in trim, and generally end up breaking something in the process. |
#12869 | |
Member#: 73068
I didn't want to risk damaging the bumper or trim. |
#12870 | |
Member#: 322264
Tri-State
#12871 |
Member#: 73068
#12872 |
Member#: 322264
Tri-State
Ah, gotcha. This sounds similar to the "belly pan" that VW puts under the engine on its cars. But those are held on with screws. How do these push pins work? Are they reusable, or are they one-time-use?
#12873 |
Member#: 314216
Vehicle:2012 2.0i Sport 5MT DGM |
Maybe some day i will report on my headlight armor fog light cover install, just need time to do it.
What is the easiest way to pop out the fog light housing so i can have better access? |
#12874 |
Member#: 73068
They are reusable. Just take a small flat head screwdriver and pop the center of the pop-it out. Then the whole pop-it will pull out.
#12875 | |
Member#: 302491
Tri-State
Vehicle:2012 Impreza 2.0i Pr Dark Grey Metallic CVT |
| Thread Tools | |
| Display Modes | |
| 2012 Impreza STI concept art | khaki_man | Member's Car Gallery | 37 | 03-15-2011 02:02 AM |
| Newsflash: 2012 Impreza looks like BigElm's Butt | WagonMonster | Off-Topic | 4 | 02-28-2011 07:11 PM |
| 2012 Impreza Concept | Zakster87 | General Community | 14 | 11-17-2010 04:09 PM |
| Possibly looking into a 2011 or 2012 Impreza? | xenonk | Mid Atlantic Impreza Club -- MAIC | 1 | 08-05-2010 09:48 PM |
