#5551 | |
Member#: 249696
NESIC
Vehicle:2010 Outback Sport Black |
Or even cheaper, these: http://bit.ly/LNW6Ta
#5552 | |
Member#: 310053
Tri-State
Vehicle:2008 Impreza 2.5i Dark Gray Metallic |
#5553 |
Member#: 254115
Tri-State
Vehicle:2009 Impreza 2.5i Dark Grey Metallic |
I'm at about 17k miles I believe. When it comes to maintenance and keeping my scooby running for a long time, what should I be doing? Oil has been changed regularly thus far.
#5554 | |
Member#: 288727
NESIC
Vehicle:2008 Impreza 2.5i Satin White Pearl |
![]() Just follow the service manual for the car or you can find it on SOA's site. |
#5555 | |
Member#: 1748
NESIC
Vehicle:'09 Outback Sport OBP over DGM |
Take care of the little problems fast, before they become big problems, and find an independent mechanic that you trust to tell you when stuff needs to be replaced or fixed, and when it doesn't, even though the manual may tell you it does. It was a resilient car, to say the least, because I was a less than stellar driver during the 13 years that I owned it. |
#5556 | |
Member#: 301179
BAIC
Vehicle:2009 Outback Sport Sage Green Metallic |
![]() Heres cheaper: http://www.ddmtuning.com/Product-Cat.../Festoon-Bulbs ![]() |
#5557 | |
Member#: 268328
BAIC
Vehicle:2011 2.5i prem pckg SSM |
#5558 |
Member#: 305008
BAIC
Vehicle:2008 outback sport Newport Blue Pearl |
I have the panel ones with the "fake" bulb that connects with car and they work fine 0_o
Not sure if your talking about those tho Also, what is the point on 89 oct? Would it be better? I tried it l last fill up and the performance and mpg was similar. I'm running 91 shell for a tank cause I'm going to be driving a long distance so I need the higher level. and it is suppose to "clean out the gunk" not sure if that is a marketing scheme our notLast edited by Navysesal; 06-26-2012 at 06:26 PM. |
#5559 | |
Member#: 268328
BAIC
![]() As for the 89 octane I honestly have no clue, every car ive seen is either regular (87) or premium (91), however I have heard the same idea that the higher octane will clean out your engine/tank and mainly because it will burn a little bit cleaner/hotter. Anyone else have some feedback on this? |
#5560 | |
Member#: 236778
Tri-State
Vehicle:08 Impreza SWP |
From what I have heard theres two tanks at a gas station. One holding 87 and 91 or 93 depending on the station and there is a ratio of 87 mixed with 91 to make 89. As for the "additives" that the gas stations claim to put in, a truck driver told me its up to the tanker driver to pour the additive in the gas tanks when they are filling them up. Some drivers don't add the additives. |
#5561 | |
Member#: 288727
NESIC
#5562 | |
Member#: 262503
MWSOC
Vehicle:2008 Impreza 2.5i |
#5563 | |
Member#: 288727
NESIC
#5564 |
Member#: 236778
Tri-State
Lol Ive driven back and forth from White Plains,NY to Toronto,ON many times and I can make it up there on about 7/8 of a tank with 93 with 87 I have to fill up in Niagara Falls. Your welcome to join me next time.
#5565 |
Member#: 310053
Tri-State
Yeah, my dad knew a trucker who told him that it's pretty much the same gas at most of the stations.
#5566 | |
Member#: 236778
Tri-State
#5567 | |
Member#: 305008
BAIC
for the gas, i seem to get around 27-28 city & highway if i'm not WOT it all the time compared to my 24 on 87. but it does feel like the throttle response is better and i don't have that sputtering when im engine braking in 3rd or 2nd |
#5568 |
Member#: 305793
#5569 | ||
Member#: 301179
BAIC
As for the gunk cleaning, im not sure if it really helps clean the engine..... However, I know putting premium gas into bad gas (gas sitting in tank for a few months), then it could help the bad gas ignite (i say this because i had this issue, where my gas had been sitting and there had been a possibility of water in the tank). Anyways my belief is that if those fuel cleaner systems, etc dont work from the auto store, they wont work from the pump either. |
#5570 | |
Member#: 301179
BAIC
There is no way you got a boost of +90mpg with just switching over. |
#5571 | |
Member#: 262503
MWSOC
#5572 |
Member#: 301179
BAIC
#5573 | |
Member#: 262503
MWSOC
#5574 | |
Member#: 249696
NESIC
#5575 |
Member#: 301179
BAIC
| Thread Tools | |
| Display Modes | |
| 08 2.5i and 08 Sti Suspension | WRXbrother | Brakes, Steering & Suspension | 7 | 03-24-2012 02:14 PM |
| Will an 08 WRX intake fit an 08 2.5i? | Racing101 | Normally Aspirated Powertrain | 26 | 01-19-2012 11:57 AM |
| 08 STI Wing on 08 2.5i impreza | juny102004 | Interior & Exterior Modification | 13 | 01-18-2012 09:46 AM |
| Will 08+ WRX gauges swap into 08+ 2.5i? | Simeon Priest | Interior & Exterior Modification | 10 | 03-26-2010 02:17 PM |
| 08 2.5i mod question | deunique1 | Impreza Forum | 1 | 10-03-2007 02:35 PM |
