#5576 | |
Member#: 276915
Vehicle:2010 Impreza OBS Steel/Spark Silver |
Hey guys! I mostly post in the OBS thread, but I have a question, what kind of oil do you guys run in our NA engines?
And to provide something to the present topic.... Quote:
#5577 | ||
Member#: 305008
BAIC
Vehicle:2008 outback sport Newport Blue Pearl |
#5578 |
Member#: 276915
Would you recommend 5w-40 Rotella T6? For some reason all the Subie guys around here live by it. But it's against the recommended weight on the Subaru cap and it's typically used in diesel trucks so thr doesn't sound like the right option but of course I know nothing about oil. I do drive about 50% "spirited" at mid to high rpms.
#5579 | |
Member#: 305008
BAIC
#5580 | ||
Member#: 268328
BAIC
Vehicle:2011 2.5i prem pckg SSM |
![]() Quote:
![]() Should have some updates for tomorrow as well ![]() |
#5581 | |
Member#: 288727
Vehicle:2008 Impreza 2.5i Satin White Pearl |
#5582 | |
Member#: 268328
BAIC
#5583 | |
Member#: 301179
BAIC
Vehicle:2009 Outback Sport Sage Green Metallic |
I believe Turbocharged guys need the 5w-40 because Turbo'd engines run at higher idling temps than we see in a N/A car. Without the ability to maintain efficiency of the oil viscosity, it can cause major damage to the engine. |
#5584 | |
Member#: 301179
BAIC
![]() Seems like a great way to blow an engine using 0w-20 throughout the year. |
#5585 |
Member#: 276915
I wouldn't be hurting anything running a full synthetic 5w-30 all year right? Pittsburgh weather, about average of 75ish during the summer, average 30ish in the winter?
#5586 |
Member#: 301179
BAIC
^shouldn't be, but if it were me, i would switch to 0w-XX during the winter time.
#5587 |
Member#: 276915
I always let my car warm up (blue light off) if that accounts for anything hahah
#5588 |
Member#: 288190
Vehicle:2009 Impreza 2.5i Spark Silver |
The Subaru dealer recommends 5w40 cuz of the weather conditions but with all my cars, and pretty much everyone else here runs 5w30 with no probs.....I'm about to switch but Idk if ima jump the gun. We average about 82-90some degrees daily
#5589 |
Member#: 280582
Vehicle:2009 2.5i premium ssm |
I'm in mi and I run mobile full syn 5w-30 all year with no problems. Been doin it for past year and half. I've ran valvoline full syn in other cars with no problem but in this car it started ticking real bad. Also don't use mobile syn extended performance. It's junk....at 3k it was black and a quart low
#5590 | |
Member#: 216858
Vehicle:2009 Impreza OBSlow Steel Silver/Spark Silver |
And, of course, don't forget the Fumoto drain valve if you are doing your own oil changes! http://www.fumotousa.com/ |
#5591 | ||
Member#: 272381
Vehicle:2008 Impreza OBS Silver |
#5592 |
Member#: 249696
Vehicle:2010 Outback Sport Black |
I decided to paint my grill dark grey yesterday. I actually used plastidip as primer so I can always take it off if I want to.
Before: ![]() After: ![]() ![]() |
#5593 | |
Member#: 301179
BAIC
#5594 |
Member#: 229726
Vehicle:'09 2.Slow OBP |
#5595 |
Member#: 276915
Well I decided on Moble 1 5w-30 to be safe and run what my cap says. We will see how it goes! Thanks for the input everyone!
#5596 |
Member#: 268328
BAIC
Hey guys here's a lil update:
![]() ![]() I got a sweet deal on a seibon wrx/sti spoiler that I couldnt pass up. Overall fit is great, and the quality of the spoiler is excellent as well. I like the CF look for now but may end up plastidipping then painting over it down the road. My plan for each area is as listed below: Suspension: koni's with some RCE yellow springs w/ 09 wrx struts, whiteline positive power kit bushings, Front control arm bushings (all), and gearbox positive shift kit! Exhaust:HP2 Magnaflow resonator in hopes to reduce raspyness after initial startup Brakes: Install Goodridge SS lines, "" wrx caliper brackets, dba t3 rotors F+R, and HP+ F+R Wheels/Tires: Enkei PF01's 17x8 +45 w/ 235/40/17 Michelin Pilot Super Sports -Sorry for all the info, just thoughtd I'd share my plans ![]() |
#5597 |
Member#: 301179
BAIC
Any overall pics??
![]() Looks like some sweet plans + new spoiler on there!! ![]() |
#5598 |
Member#: 268328
BAIC
Not yet. Ive seriously been busy everyday this week
![]() Thanks man, it will be awesome once all my money goes down the drain ![]() |
#5599 | |
Member#: 248840
Vehicle:2011 Impreza Satin White Pearl |
#5600 | |
Member#: 288727
| Thread Tools | |
| Display Modes | |
| 08 2.5i and 08 Sti Suspension | WRXbrother | Brakes, Steering & Suspension | 7 | 03-24-2012 02:14 PM |
| Will an 08 WRX intake fit an 08 2.5i? | Racing101 | Normally Aspirated Powertrain | 26 | 01-19-2012 11:57 AM |
| 08 STI Wing on 08 2.5i impreza | juny102004 | Interior & Exterior Modification | 13 | 01-18-2012 09:46 AM |
| Will 08+ WRX gauges swap into 08+ 2.5i? | Simeon Priest | Interior & Exterior Modification | 10 | 03-26-2010 02:17 PM |
| 08 2.5i mod question | deunique1 | Impreza Forum | 1 | 10-03-2007 02:35 PM |
