#176 | |
Member#: 284046
Vehicle:2000 Impreza w/ WRX |
#177 | |
Member#: 284046
OP I would suggest just leaving it. It's a bumper and will get chipped up, eventually forgetting about a slight discoloration. This color has a reputation of being hard to match and having them repaint the whole bumper could turn into a can of worms. Congrats on the new car! |
#178 | |
Member#: 321659
Vehicle:2012 WRX 5-Door SWP |
I have no idea how experienced their paint shop is, so I think I may just leave well enough alone. With my luck, it will end up looking WORSE! I probably would have never noticed it if my nephew didn't point it out. Of course, now I can't HELP but notice it... ![]() The bumper is already collecting 90MPH bug strikes, and the damned birds have gone out of their way to 'christen' every other square inch of paint, so this minor flaw will be forgotten soon enough. Maybe I should just plasti-dip the fogs black... Then they REALLY won't match the bumper!... ![]() -Eric |
#179 | |
Member#: 284046
Please don't plasti dip them. |
#180 |
Member#: 306368
Vehicle:2011 Impreza 2.5i DGM |
Hello, I just picked up a 2011 DGM 2.5i sedan this week
Hood has crazy swirls/scratches, nothing deep at all but if you look close enough you can see them used some ice liquid wax & it kinda hid them but they're still there is there anyway i can get rid of those by hand, or would i need a buffer? types of wax? |
#181 | |
Member#: 284046
#182 |
Member#: 290151
Vehicle:2005 WRX porsche silver |
Can anyone help me with this problem?
Bought a 2005 wrx with a kakumei rear widebody kit on it. The dude who installed it must have done something wrong because small cracks started showing up. Wile at school they only got worse, and I couldn't do anything to fix it because I had no garage. I am finally ready to take the kit off, fix everything up and put it back on. My question is about paint chipping agian. I plan on using 3m panel bond and from what I have read, it should work great. Do you have any advice for me? also, I am not sure how it will look molded/not molded and I feel like molding it guarantees eventual paint chipping. If you think it should be molded, I'm not even sure where to start because I wasn't planning on doing that originally Any advice would be appreciated edit: also, where there are cracks, there is rust :/ Last edited by tssmith11; 07-02-2012 at 01:06 AM. |
#183 |
Member#: 239497
Vehicle:2003 Impreza WRX WRB |
I have no advice in the respect of Repair work. But I'd like to give my .02 here. You're already starting over, don't skip the step of not molding it. Molding it would bring sheer perfection to the
Car. Make it look like its supposed to be there. No some civic hack job (no offense to anyone). |
#184 |
Member#: 290151
but it will crack if I mold it. then it will have to be done again.... that seems like an endless and pointless circle
#185 | |
Member#: 239497
Obviously been done ya know? In any case, it's your car. Do what fits your taste. I'm just a guy with an opinion. |
#186 |
Member#: 290151
anyone have advice/techniques for molding without eventual cracking?
#187 | |
Member#: 284046
http://www.3m.com.au/intl/au/auto_ma..._Wallchart.pdf Follow that for the application, then use a fiberglass style filler for any seams. Smooth with a flexible polyester, then prime. I'm currently installing an Aerosim wide body on my GC and will have the process here: http://forums.nasioc.com/forums/show....php?t=2374401 Let me know if you have any specific questions, this is an extremely broad topic and you might want to wait for my write up to be done. Post pictures of these cracks/rusted areas. |
#188 | |
Member#: 284046
#189 | |
Member#: 239497
#190 |
Member#: 284046
I'm not looking to ruin anyones dreams, and with an attitude like that one day you'll have a wide bodied wrx. Check that link I posted and in a couple weeks should have a pretty good write up.
#191 | |
Member#: 290151
I think with this situation I will attach the panels like I originally intended and then see how they look and update this forum as I go. As for pictures of the rust... i'll get some tomorrow when its sunny. Thanks for the help, its really appreciated |
#192 |
Member#: 284046
Anyone need some auto body help?
#193 |
Member#: 290151
Alright sorry it took so long.
Here's pictures of the body kit... left side is much worse than the right. these are all left side... ![]() ![]() ![]() these are all right side.. gas tank is ok, I dont think i'm going to remove it. ![]() ![]() ![]() Here are all of the tools I plan on using. (not pictured - roloc clean n strip disc) ![]() ![]() Matt, I saw in your widebody write up that the car had duct tape holding the panels on, do you think I should go that route rather than trying to use the C-clamps? I really only think that the 18" clamp will fit around the kit and the door.... Here's my thoughts, please let me know what you think. 1. use the clean n strip along all sides of the body kit so that I can see bare metal and exactly where it attaches. 2. Use sharp knife to cut underneath kit and free it from the body (not sure about this step.. might work since kit is coming off a little already...) 3. once entire kit is removed, grind down any rusted metal with roloc clean n strip OR grinding disc (will either work?) 4. smooth out edges of body kit, get paint off around the edges, and clean with my 3m cleaner. 5. mount kit to make sure proper fit (i'm not too worried about this step, it should fit fine, given that not too much is taken off when cleaning.) 6. tape off edge where panel bond will be applied, and apply rust fighter to entire area underneath the body kit. 7. remove tape and begin applying panel bond, smooth out the bead so that it reaches the edge of the area where rust fighter was applied, then place another bead on top. (I've seen how to's on the application of the panel bond and think i'll be okay with that part.. the only confusing part to me is the rust fighter, in all of the instructions it is applied last which doesn't make sense because the body kit will be covering areas that need it..?) 8. secure body kit to car with either clamps or duct tape. please let me know what you think and thanks again! |
#194 |
Member#: 290151
gas tank picture didn't make it...
links not working for whatever reason, you'll have to trust me that its alright edit: this should work ![]() |
#195 |
Member#: 239981
Vehicle:01 OBS WRX Silver |
Wow, that's depressing. Good luck with that, make sure to slap the PO in the face with a sea bass when you're done.
#196 |
Member#: 293159
South East
Vehicle:2005 WRX CGM |
I recently swapped trunks with someone, and the new trunk was keyed by his ex-wife.
Pretty deep gouges, he tried to touch them up, but it doesn't quite look right. Suggestions? (Ill get pictures tomorrow when its daylight.) |
#197 | |
Member#: 284046
2. I don't know what was used to bond the over fenders, but using a sharpened putty knife would be my first option. If a proper adhesive was used, this may not work. Let me know. 3. Use the roloc, just don't use it on one area for too long or you could warp the metal. 4-7. Just follow the directions outline in the flow diagram. 8. I used the duct tape just to check it out, that will not be how a hold the over fender while bonding. You need to use a method that creates a tight seal to the body. I would suggest either rivets or using Cleco fasteners. I would also refinish both sides, there is no sense to repair the left and not the right. |
#198 |
Member#: 284046
Post some pictures and there might be some tricks to "hide" them a little. If they are deep a repaint might be your only option.
#199 |
Member#: 296602
Vehicle:2012 WRX Limited Satin White Pearl |
Howdy Matt,
Question: How much do you think it will cost to install a paint-matched 2012 STI spoiler onto a 2012 WRX that has the stock premium wing? (Filling the holes, drilling new ones, etc...) Ew: to: Ah! ![]() Thanks Matt! |
#200 |
Member#: 293159
South East
You'd be better off just to try and trunk swap with someone.
| Thread Tools | |
| Display Modes | |
| How Bad Are Auto Sales? 10 Questions and Answers | AVANTI R5 | Non-Subaru News & Rumors | 1 | 07-07-2009 05:14 PM |
| Anybody in the auto body/paint business? | markman | Off-Topic | 4 | 05-17-2008 10:40 AM |
| Auto body/paint in SW Houston/Stafford? | petregeus | Texas Impreza Club Forum -- TXIC | 4 | 04-01-2006 01:11 PM |
| auto body paint | blaznasn | Interior & Exterior Modification | 0 | 09-17-2001 06:32 PM |
| Looking for auto body/paint shop | Vestas | Tri-State Area Forum | 1 | 07-03-2001 09:02 PM |
