Go Back   NASIOC > NASIOC Classifieds > Vendor Storefront Forums > IAG Performance
Old 01-20-2012, 11:52 AM   #1
IAG Performance
Member#: 158123
Default 5-10% Off Our Most Popular Services - IAG Performance Service Special Sale is ON!
For a limited time, we are offering discounts on all of our regular MAIC Service Special Thread prices! The best service deals in the area just got better! Call, PM, or email to schedule your service today!
FREE Alignment Check Special
Call now to set up your free alignment check using our floor mounted Hunter RX Scissor Lift Rack and HawkEye High Definition Digital Imaging Wheel Alignment System. A quality alignment is essential for safety/drivability, good handling, and consistent tire wear. Have your alignment checked 100% free-of-charge, and we will supply a printout of alignment results for your records.
Once you’re on the rack, if you decide to have us perform a 4-wheel alignment, we are offering 10% off our regular alignment price of $99! Join 1000+ Subaru owners in the area who have experienced the IAG Performance Alignment… Satisfaction guaranteed!
IAG Performance Subaru Scheduled Maintenance Services
30,000 & 90,000 Mile Service - Was $399 - NOW $379!
-Oil change using your choice of Motul, Eneos or Valvoline Synthetics
-K&N or Purolator Pure One Oil Filter & new drain plug washer
-Replace Transmission Fluid w/ Motul 75w90 (Motul Gear300, Extra-S, and other fluids available upon request)
-Replace Differential Fluid w/ Motul 75w90 (WRX) or Motul PA 90 (STi)
-Coolant flush and inspect cooling system, hoses and connections. Global coolant w/ 1 bottle of Motul MoCool
-Air Filter Service (replace factory filter w/ K&N Drop-In, or clean & lubricate existing filter)
-Flush & replace brake fluid w/ your choice of Ate SuperBlue or Motul DOT 5.1
-Inspect brake pads and rotors
-Inspect brake lines and check operation of parking brake
-Inspect Front & Rear axle boots and axle shaft joint portions
-Inspect clutch operation
-Inspect Steering & Suspension
-Inspect tires & rotate
-PCV Valve
-Top-off all fluids
-Replace fuel filter (vehicles vary) and inspect fuel system
60,000 Mile Service - Was $499 - NOW $474!
-All services performed in 30K Service
-Change spark plugs
105,000 Mile Service - Was $899 - NOW $854!
-Replace Timing belt
-Replace water pump & water pump gasket
-Replace thermostat & thermostat gasket
-Flush coolant & inspect cooling system. Global coolant w/ 1 bottle of Red Line Water Wetter or Motul MoCool
-Crank Seal
-A/C & P/S Belts
-Cam Seals
-Timing belt tensioner
Timing Belt/Water Pump Service Only - Was $499 - NOW $474!
Brake Packages
Stage 1
Hawk HPS Front/Rear Pads
Techna-Fit SS brake lines
Motul DOT 5.1 or Ate SuperBlue
WRX - Was $499 - NOW $474 Installed
STi - Was $549 - NOW $522 Installed
Prices vary - Also available for other Subaru models - Call/PM for details and pricing!
Stage 2
Techna-Fit SS Brake Lines
DBA 4000 Series Slotted Rotors
WRX - Was $1049 - NOW $997 Installed
STi - Was $1199 - NOW $1139 Installed
Prices Vary - Also available for other Subaru models - Call/PM for details and pricing!
Suspension Services
Alignment/Corner Balancing
Performance Alignment - Was $99 - NOW $94!
Performance Alignment & Corner Balancing - Was $199 - NOW $189!
Install Springs/Coilovers (purchased @ IAG) w/ Performance Alignment - Was $299 - NOW $284!
Install Customer supplied springs & alignment - Was $349 - NOW $332!
Install Customer supplied coilovers & alignment - Was $399 - NOW $379!
*Coilover installation includes initial ride-height set-up. Additional changes to ride height are extra. Alignments are subject to additional charges for extra time (seized bolts/hardware, extreme fitment/aggressive set-ups, etc.)
Fender Rolling Services - 10% Off!
10% Off Regular Fender Rolling Prices! CALL FOR DETAILS!
Guideline for our basic pricing can be found here:
http://www.iagperformance.com/fender...g_service.html
Fender rolling service pricing may vary depending on vehicle/extent of service - Call/PM for details and scheduling info!
Transmission Services
Exedy Clutch Specials
Exedy Stage 1 clutch package – w/ resurfaced flywheel & Motul or Eneos 75w90 fluid
WRX - Was $899 - NOW $854 Installed
STi - Was $999 - NOW $949 Installed
Exedy Twin-Plate clutch package w/ performance flywheel & Motul or Eneos 75w90 fluid
WRX - Was $1999 - NOW $1899 Installed
STi - Was $2099 - NOW $1994 Installed
ACT Heavy Duty Street Specials
06+ WRX Special - ACT Heavy-Duty Modified Street Clutch, resurface factory flywheel - Was $1149 Installed with your choice of fluids - NOW $1092!
05-09 Legacy GT Special - ACT Heavy-Duty Modified Street Clutch with your choice of ACT Streetlite or Subaru OE 06-07 WRX Flywheel - Was $1399 Installed with your choice of fluids - NOW $1329!
04+ STI Special - ACT Heavy-Duty Modified Street Clutch with resurfaced flywheel for 04-09 STI 6-Speed - Was $1249 Installed with your choice of fluids - NOW $1187!
OEM clutches & other Exedy and ACT Packages Available Upon Request!!!
Accessport/Protune Special
As always, buy your Cobb AP from IAG & Receive $100 off protuning - AP/Protune Combo = $995
Window Tint
Window Tinting @ IAG Performance - $10% off*!
Our window tinter has been in the business for over 15 years, and does an absolutely incredible job. We offer Johnson high quality window films, available in shades from MD legal all the way to limo dark.
Our tinting services come with a lifetime warranty against bubbling, peeling, fading, purpling, hazing, & more.
If you're looking for high-quality tint for your Subaru, shoot us a PM or call at the shop any time!
*Vehicle doesn't have to be a Subaru, but you MUST mention this ad to receive 10% off window tint - This is a NASIOC-only special!!!
IAG Performance is offline
Old 06-27-2012, 01:26 PM   #2
Joekaml
Member#: 248596
2003 Bugeye WRX
CBS
Is this still going on? Do you charge more to mount and balance tires, if not purchased through your shop?
Joekaml is offline
Old 07-09-2012, 03:36 PM   #3
looch
Member#: 214346
2009 Impreza WRX
Spark Silver
If you guys carry Cusco 2E's, can you please pm a quote of them shipped to 14586 for a '09 WRX?
looch is offline
Old 07-13-2012, 08:42 AM   #4
IAG Performance
Member#: 158123
Sorry for the delay! Unfortunately this special has ended. We do charge less for tire services when the tires are purchased here.
PM'd you.
IAG Performance Service Special Thread - Now Including Mobile Electronics Specials!!! IAG Performance MAIC Vendor Classifieds 450 01-06-2012 01:18 PM
IAG Performance Holiday Specials - KillerB, ID, Walbro, TONS More!!! IAG Performance Engine/Power/Exhaust 17 03-02-2011 05:45 PM
IAG Performance Holiday Special Service Thread: Free Services & Discounts? Mmmhmmm! IAG Performance MAIC Vendor Classifieds 27 01-02-2010 06:16 PM
The IAG Performance Service Special Thread! IAG Performance Services 29 11-23-2009 07:52 PM
