Old 06-28-2012, 02:43 AM   #1
oguitar
Member#: 206720
2002 WRX Wagon
Default Koni inserts with STi springs. Time to dial in.
I have finally finished installing my koni inserts with STi springs. Now I need to dial them in a little. I am using the skidpad part of the Dynolicous app to help me see what is going on. I can feel the improvements but this is a little better.
Stock
Another one with stock worn struts where I really almost broke loose.
Rear koni's and STi springs installed.
All 4 Koni inserts and STi springs.
So now I have to dial the inserts in. I wish there was a click or some kind of indicator that would help me turn exactly the same on each test.
My question is this should I dial in the rears first and then move to the fronts? I am doing this on a small curvy back road by my house. It is not heavily travelled and I only test during times when people are normally sleeping. I am keeping my speed close to 40 MPH on all tests. On the stock worn out struts I was probably going slower because it did not feel safe. I am making sure my iPhone is steady while taking the test.
Any help would be appreciated.
oguitar is offline   Reply With Quote
Old 06-28-2012, 02:56 AM   #2
teiva-boy
Member#: 22825
I've done all of my adjustments in 1/8 turn increments starting from full soft.
For the most part, I did the same setting all around while driving all over the west coast.
On occasion there were some weird oscillations, and I firmed up the settings on that end. Then drove over those same sections again, changed the setting, and tested again.
Though in the end, it's all subjective. Go with what you are comfortable with.
teiva-boy is offline   Reply With Quote
Old 06-29-2012, 11:37 PM   #3
Back Road Runner
Member#: 60082
2004 Forester STI
It's a rebound only adjustment, so focus on chassis motion on rebound. Basically I mean don't pay attention to how the car feels or moves during the bump. Pay attention to how it moves after the bump. Impact force is compression dependent which is fixed on the Konis. Rebound will control bounding after as well as the sum total motion/oscillations after bumps.
I have not used the Koni inserts personally. I've owned the AGX and the D-Spec.
From my experience, I will suggest that you tweak the front first. Set the rear overly stiff. I say this because the back end bouncing around can affect what you're trying to do. With the back firm, start toying with the front. Go softer, work your way up. You can be coarse at first. Work higher and higher until you start to feel the car fall after bumps. If the rebound is too high, the suspension will have trouble extending quickly after compressing. The car will quite literally fall after every bump. It will feel like you're getting air time. This is rebound set too high. It can also negatively affect traction over bumpy sections and make the car quite skittish. You want to go excess so you can feel and understand what excess is.
Dial it back down. Keep going down. What you'll notice is that air time disappears. Now the tire remains in contact with the road much better. Dial it down more. Now you'll start to notice the chassis bounds and wallows a little more, has a little extra motion after bumps. Go lower. You'll start to notice that the chassis begins to oscillate continuously, albeit slightly. If you look across the hood to the road, you can see the hood bounce up and down and the frequency of the suspension and never stop. The car goes over bumps and there are gross movements, but this tiny bounce is just always there. That is when you're too under damped to control the chassis. Konis do have moderate low speed damping, so there may be less of this than what I've personally seen with the AGX and D-Spec struts. Still, soft will have a lot of chassis movement after bumps. It will bound and wallow.
The ideal point is somewhere in between. You want it firm enough to get rid of the extra motion, but you want it soft enough not to cause traction issues with the tire losing contact with the road. That range may be small, maybe a turn, maybe half a turn. You need to toy with the strut till you find that sweet spot. If you question your ability to do so, repeat by going excessively stiff and then excessively soft. Go up and down the range several times. Get a feel for it. Train your mind to recognize the variation in chassis motion. Then tweak again and find that sweet spot.
Why'd I say the front first? Well, the back end is hard to feel from the drivers seat. You get a good sense of the front end from sight and feel since you're sitting on that end of the car. You have a significantly harder time feeling out the rear end. I say set the rear end stiff just so it's not bouncing around and affecting what you think you feel on the front end.
Repeat with the back end of the car. Start soft and go up. Go to excess and then back down. Repeat until you get a feel for the range and what to feel. You will be able to feel the back end dropping after bumps if the rebound is too high. You will also be able to look out the rear view mirror and see the chassis oscillate continuously if you're too low. It's harder to sense the back end, so learn from the front end. If you know the size of the sweet spot and how far up or down you should go from a particular cue, then you can mimic that on the back end without specifically having to feel out the motion in great detail. For example, I set my D-Spec struts to not oscillate and go just high enough to stop that motion to where I visually can't see any extra movement both line of sight off the hood and via the rear view mirror out the back window. With the D-Spec I can't go much higher till I start getting contact issues with the road, so the sweet spot is narrow. I can use the rear view mirror and set just high enough to see that oscillation stop, and I know I'm where I want to be, even if I can't really feel the back end well. Again, the Koni damping is a little different, so you will need to find visual or feeling cues that work for you. The AGX and D-Spec don't have high low speed damping, so they are more sensitive to being slightly under damped. I would expect the Koni to be a little more forgiving and likely have a broader range that still works well. That's just a personal guess though.
Experience is the best teacher. Just tweak the struts, repeat, and repeat again. You will quickly learn the breadth of influence, how it affects the car, and what feels and operates the best.
Old 06-30-2012, 03:03 AM   #4
oguitar
Member#: 206720
2002 WRX Wagon
Awesome. Thanks for the feedback. I will start tuning the fronts first and then move to the bad when I feel the front is properly tuned.
Old 07-16-2012, 04:17 AM   #5
oguitar
Member#: 206720
2002 WRX Wagon
4 notches on the front.
I am impressed by how much the car responds to these little adjustments. The car feels much better going down this road. Might adjust the rear next or should I just keep adjusting the front and see what happens?
Old 07-16-2012, 10:20 AM   #6
redline23
Member#: 285799
2012 WRX 5-Door
Thanks for the awesome post Back Road Runner, starting to get a feel for how dampers work.
redline23 is offline   Reply With Quote
Old 07-16-2012, 11:06 AM   #7
jorge0886
Member#: 269257
2011 STI Limited
Wow. Do you think this app is worth the $13, I'm curious?
jorge0886 is offline   Reply With Quote
Old 08-06-2012, 01:25 AM   #8
NY_subie
Member#: 327925
anyone in NY that can install these for me?
NY_subie is offline   Reply With Quote
Old 08-06-2012, 01:27 AM   #9
NY_subie
Member#: 327925
i just bought 04 sti takeoffs, the ones with the red struts. when the struts go i was going to put on the koni shocks bc they are cheaper than new sti struts from subaru.
I only see them for the wrx not the sti. do they make them for the sti?
Old 08-06-2012, 03:07 AM   #10
teiva-boy
Member#: 22825
The STi struts can be rebuilt and run much better than stock, and can be made to last longer than stock. Contact Feal Suspension for their services.
2010 wrx koni inserts with eibach springs baba0023 Brakes, Steering & Suspension 0 08-08-2011 11:28 AM
04-06 sti springs okay to install in 02-03 wrx Udaman Brakes, Steering & Suspension 8 08-09-2010 01:34 PM
Koni inserts with Perrin springs Pete Holt MWSOC Private Classifieds 8 10-12-2006 05:52 PM
Koni inserts with Perrin springs Pete Holt Suspension/Brakes/Handling 6 10-12-2006 05:39 PM
Which springs with Koni inserts on Sti? meajas12 Brakes, Steering & Suspension 6 07-12-2006 12:43 AM
