Old 06-28-2012, 04:15 PM   #5601
OgBL6
Member#: 306368
2011 Impreza 2.5i
finally picked one up yesterday.
2011 2.5i sedan
8120 miles
5spd
OEM Subaru Rainguards
looking into lowering ASAP!!
then some wheels & exhaust
more pics coming soon.
OgBL6 is offline   Reply With Quote
Old 06-28-2012, 04:57 PM   #5602
Navysesal
Member#: 305008
2008 outback sport
Newport Blue Pearl
Did any of you clean your carb and fuel injectors? I heard you don't need to if your using top brand gas, but I feel I should be on the safe side
Navysesal is offline   Reply With Quote
Old 06-28-2012, 06:47 PM   #5603
theoutbackdream
Member#: 301179
2009 Outback Sport
Sage Green Metallic
Nope, never.
Are you trying to cure the rough idle? because some of your recent posts have been about engine stuff to cure out the rough idle to me.
theoutbackdream is offline   Reply With Quote
Old 06-28-2012, 09:31 PM   #5604
Navysesal
Member#: 305008
2008 outback sport
Newport Blue Pearl
Originally Posted by theoutbackdream
Nope, never.
Nah, it was more towards keeping my car in tip top shape and getting better fuel economy :P
But my cars fine with idling ever since I cleaned the Maf sensor
It's just my friend has recently had some problems with his car so I have been a little paranoid haha
Old 06-28-2012, 10:42 PM   #5605
scoobymatt93
Member#: 254115
2009 Impreza 2.5i
Dark Grey Metallic
FINALLY got some new wheels! My car's almost exactly where I want it. Rallisport UEL headers are on the way, Tsudo N1 is sitting in the garage, and coilivers are the last purchase on the list. She's coming along perfectly
scoobymatt93 is offline   Reply With Quote
Old 06-28-2012, 10:59 PM   #5606
theoutbackdream
Member#: 301179
2009 Outback Sport
Sage Green Metallic
ah no wonder
Nothing really helps fuel economy IMO, other than your mood and the weight in your car. I removed my spare tire + spare parts during weekdays during the school year since that took off a lot of weight (id say about 30-40lbs) and then that boosted my mpg 0.3 but i say its BS, since im thinking it would boost only 0.1mpg...
Old 06-29-2012, 01:34 AM   #5607
Navysesal
Member#: 305008
2008 outback sport
Newport Blue Pearl
ah no wonder
Lol yah I knoe, just giving myself false hope
Lol well .1 adds up ya know
Old 06-29-2012, 02:41 AM   #5608
theoutbackdream
Member#: 301179
2009 Outback Sport
Sage Green Metallic
Haha it does. Btw have you calculated your mpg? Seems to me like you should.. The one displayed on the dash is off IMO, and usually are.
I haven't though since mpg isn't such a worry for me at the moment.
Old 06-29-2012, 03:43 AM   #5609
Navysesal
Member#: 305008
2008 outback sport
Newport Blue Pearl
I'm getting around 24-25 I haven't checked in a while
EDIT: http://slikdial.com/index.html
i found this very interesting, anyone seen this before?
Old 06-29-2012, 06:21 PM   #5610
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
I use one bottle of name brand ''complete fuel system treatment'' once a year with full tank of gas. I did that this year on my last tank, I got it at NAPA for about $7. Who knows if it helps, it's possible it does, and I thought I remembered seeing something about that in owners manual.
I run 87 octane 99% of the time. I see slight mileage increase with 89, but not much. Car runs absolutely perfect always.
We have no carburetor.. if that's what you meant by ''carb''.
BWX is offline   Reply With Quote
Old 06-29-2012, 07:18 PM   #5611
premier00000
Member#: 251060
2008 Impreza Outback
So today (about 10 minutes ago) I decided to completely FILL my gas tank (until the pump clicked) for the first time in about 6 months and when I went I turned the key to start my car it completely died (no lights on, nothing) so I popped my hood and then heard the door ding. Went to start the car and it didn't turn over at first but fired right up on the second try.
The clock reset as well as everything on my radio.
Any idea what the culprit could be and what I can do to make sure it doesn't happen again?
premier00000 is offline   Reply With Quote
Old 06-29-2012, 07:21 PM   #5612
theoutbackdream
Member#: 301179
2009 Outback Sport
Sage Green Metallic
Your battery lose? I noticed my battery terminal became lose after awhile
Old 06-29-2012, 07:57 PM   #5613
premier00000
Member#: 251060
That was the first thing I checked. Everything was nice and tight.
Old 06-29-2012, 08:36 PM   #5614
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
Check all ground wires on both ends.. to engine/ chassis/ body. Something is definitely loose, or maybe battery failing? ECU failing? Bizzare! Check all fuses and check all relays next. Do our cars have fusable links? I don't have repair manual yet.
Old 06-29-2012, 08:53 PM   #5615
premier00000
Member#: 251060
Whatever it is seemed to correct itself when I opened the hood. I guess it's time for an Optima Battery
Old 06-29-2012, 09:30 PM   #5616
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
My battery was still fine but I got a Yellowtop and I'm really happy with it. When coming to a stop at night and idling, like at a red light, especially when it's raining- when lights, defrost, wipers, stereo amp/ subwoofer etc. are running; you can really tell the difference. With stock battery, even when brand new, everything slows down, dims, and has less power. With Optima, it feels like I have three stock batteries hooked up.. you never get that dimming of lights at idle, and voltage sag.
I can run my stereo system without car running and not worry too. Car starts up with more power.. cranks faster. Yup, Optima battery is a great investment.
You might have other issues though.. that new battery may or may not fix.
Old 06-29-2012, 09:51 PM   #5617
premier00000
Member#: 251060
I used to have a Red Top (that was in 3 different cars) that unfortunately stayed with the last one when I traded it in. And that thing would last thru 4 movies at the local drive in theater when the stock ones only lasted thru only 1 (wouldnt start after the 2nd)
Old 06-29-2012, 10:12 PM   #5618
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
Yeah I'm amazed at how much more power is in my Yellowtop. I'm into LED flashlights driven hard with Lithium batteries.. I know Optimas aren't lithium, but compared to the stock battery, it's like the difference between a nickel–metal hydride (NiMH) and lithium-ion (Li-ion) in a flashlight or drill. Great upgrade.
Old 06-30-2012, 12:36 AM   #5619
Navysesal
Member#: 305008
2008 outback sport
Newport Blue Pearl
Alright good to knoe
Old 06-30-2012, 06:37 AM   #5620
bidaci
Member#: 291519
2011 OBS
I posted this elsewhere but figured this would be the best spot to ask. Does an 08 Wrx axleback bolt up to the 2011 2.5?
bidaci is offline   Reply With Quote
Old 06-30-2012, 09:40 AM   #5621
JourdanWithaU
Member#: 146287
2009 Impreza 2.5i 5D
Sunlight Gold Opal
Yes..
JourdanWithaU is offline   Reply With Quote
Old 06-30-2012, 09:48 AM   #5622
premier00000
Member#: 251060
Originally Posted by JourdanWithaU
Yes..
Thank you. I was going to quote all the other questions and answers located through the rest of this thread.
Old 06-30-2012, 11:32 AM   #5623
bidaci
Member#: 291519
2011 OBS
Yes..
Thank you. I spent hours last night searching this board, forum and Google and just couldn't find the answer on a axleback. Tons of info on catbacks.
Old 06-30-2012, 11:56 AM   #5624
Digital Dillon
Member#: 288727
2008 WRX premium
Obsidian Black Pearl
A lot of people are running the Nameless Performance axlebacks on their cars!
Digital Dillon is offline   Reply With Quote
Old 06-30-2012, 12:37 PM   #5625
theoutbackdream
Member#: 301179
2009 Outback Sport
Sage Green Metallic
Just wondering, did that Yellow top help with any of the somewhat rough idle the imprezas have? because im noticing that the battery is fading away too during idles
08 2.5i and 08 Sti Suspension WRXbrother Brakes, Steering & Suspension 7 03-24-2012 02:14 PM
Will an 08 WRX intake fit an 08 2.5i? Racing101 Normally Aspirated Powertrain 26 01-19-2012 11:57 AM
08 STI Wing on 08 2.5i impreza juny102004 Interior & Exterior Modification 13 01-18-2012 09:46 AM
Will 08+ WRX gauges swap into 08+ 2.5i? Simeon Priest Interior & Exterior Modification 10 03-26-2010 02:17 PM
08 2.5i mod question deunique1 Impreza Forum 1 10-03-2007 02:35 PM
Message Board Statistics All times are GMT -4. The time now is 08:02 PM.
