Old 06-28-2012, 10:35 PM   #501
vicious_fishes
Member#: 158864
2003 SOHC destroker
alright so let's get a group buy going on this thing.
vicious_fishes is online now   Reply With Quote
Old 06-28-2012, 11:31 PM   #502
bettner12
Member#: 56179
05 LGT 407hp/372tq
Tuned by [email protected]
http://forums.nasioc.com/forums/show....php?t=2341424
bettner12 is offline   Reply With Quote
Old 06-29-2012, 01:05 AM   #503
vicious_fishes
Member#: 158864
2003 SOHC destroker
that one is closed. ryan said he'd be running another one.
i want another one
Old 09-20-2012, 10:33 AM   #504
FXTSPORTS08
Member#: 232340
2008 F XT Sports
Dark Gray
i want another one
Just to let people know, Ryan posted another group buy!
http://forums.nasioc.com/forums/show....php?t=2395474
FXTSPORTS08 is offline   Reply With Quote
Old 11-11-2012, 06:51 AM   #505
Tenament
Member#: 246813
what fantastic news to come back to after a ~2 year hiatus from NASIOC. $300 for the setup?! Sold
Tenament is offline   Reply With Quote
Old 11-13-2012, 07:43 PM   #506
04stigeorge
Member#: 177402
05 STI and 08WRx
blue and white
Default newish 6mt n/t
First id like to help finish this thread off by mentioning the deference in the late model case design....its changed in the 5mt.
I have a few pics I cant get at right now....however the newer late model
6mt n/t not the sti trans...the 6 speeed manual in non turbo late models
again pics would help ..the cases are hugely beefier. The internals share some of the 5mts but for the most part make more sense..better synchros balk rings, fatter center diff...helical reverse gears very simillar to the sti.
Once I get a chance i will post some pics...i may need a reminder...or maybe someone already has. Why they are not being used in the wrx...
I can see a version of this unit going in and even replacing the 5 mt altogether...yup i am going on a limb making that assumption..but things change...i dont have esp or a secret informant...time will tell this post will be here when it does and i can get a cookie
04stigeorge is offline   Reply With Quote
Old 11-13-2012, 09:29 PM   #507
charliew
Member#: 125304
They probably were designed for a lower torque application. The turbo having more torque can pull through wider spaced gear ratios where the na motor needs the closer spaced gear ratios to perform better. Just my guess. When this tranny first came out the first thing I thought about was 6 thinner gears to fit in the same space as 5 gears.
charliew is offline   Reply With Quote
Old 11-14-2012, 06:01 PM   #508
04stigeorge
Member#: 177402
05 STI and 08WRx
blue and white
Well good points...I will check the gear size and tooth count. The late model sti's have ratios closer than older ones?...especially 3-4 ,5 is the same as its always been...in the sti.
Also the 6 non turbo has a reverse lockout like the sti..worth mentioning...just googled it you can read and see the blueprint on this link.
http://driveperformance2.subaru.com/.../blueprint.asp
Feeler: Developing a reinforcement for the 5mt case jhargis Transmission (AT/MT) & Driveline 36 09-24-2008 08:18 PM
The power switch is going out in my case. bomber991 Off-Topic 9 02-05-2008 04:54 PM
What is going on with my '99 legacy GT LTD 5MT jw5216 Electrical & Lighting 1 11-24-2007 10:54 AM
WTB: 5MT case Starkiller New England Impreza Club Forum -- NESIC 6 09-21-2005 12:04 PM
v6 STi RA gearset in 5MT case, motor, and VF22 BoostdScubaru Private 'For Sale' Classifieds 42 10-22-2004 06:15 PM
