Old 06-30-2012, 03:27 AM   #1
crimsontide
Member#: 320631
Default Do I need injectors to support VF35 upgrade
Hi all,
I'm currently thinking of gettting a VF35 turbo upgrade for my 2007 JDM 2.0l (auto) WRX. Would getting new injectors, such as those from 2.5l WRX's or STI's be absolutely critical? Or would I be ok using the stock injectors already in my car?
Thanks alot!
crimsontide is offline   Reply With Quote
Old 06-30-2012, 05:43 AM   #2
Dat8687
Member#: 243261
2004 WRX
Java black pearl
Im not sure of the size of the stock jdm injectors on the 2.0 for that year. But im guessing at stock boost levels it would be fine
Dat8687 is offline   Reply With Quote
Old 06-30-2012, 12:39 PM   #3
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
If you use stock injectors you will blow the motor. All turbo upgrades need bigger injectors. Call your tuner and ask him.
Old 06-30-2012, 04:53 PM   #4
FakeIt2MakeIt
Member#: 240500
2006 STI
SGM
^ Ask your tuner.
FakeIt2MakeIt is offline   Reply With Quote
Old 06-30-2012, 06:12 PM   #5
brew02wrx
Member#: 259970
2002 wrx cobb stg2+
psm proper fitment
Originally Posted by crimsontide
Hi all,
Thanks alot!
Ask your tuner as to which size injectors you will need
General rule of thumb is when upgrading the turbo you gotta upgrade the injectors, people even upgrade the injectors with a stock turbo (wrx and sti's) to get more out of their stage 2 setup and to set themselves up for a larger turbo down the road
You will also need to replace your fuel pump to a higher flowing one to accommodate the increased flow of the injectors, again ask your tuner about this
brew02wrx is offline   Reply With Quote
Old 06-30-2012, 06:39 PM   #6
Brother EddieJ.
Member#: 181617
2004 wrx
6speed/ 330whp/ 300wtq
Ask your tuner.
Brother EddieJ. is offline   Reply With Quote
Old 07-01-2012, 02:13 PM   #7
Dat8687
Member#: 243261
2004 WRX
Java black pearl
Originally Posted by Brother EddieJ. View Post
Ask your tuner.
Definitely do that. But I saw this one on youtube with the VF35 it doesnt say anything about upgraded injectors. Then again its only making 250wheel but im guessing its tuned
This is a stock 2.0 litre with Rocket Rally's Up and Down Pipes, STi cat-back, V7 Top-mount, APS 65mm intake, and a Perrin turbo inlet, plus a few miscellaneous items. Nowhere near as much torque as a 2.5L, but lots of fun!
Old 07-01-2012, 04:41 PM   #8
DoogieSTi
Member#: 247023
2007 STi
I wouldn't trust YouTube with my vehicle... Ask someone who knows or has the setup you desire.
DoogieSTi is offline   Reply With Quote
Old 07-01-2012, 06:18 PM   #9
brew02wrx
Member#: 259970
2002 wrx cobb stg2+
psm proper fitment
i posted this in your other thread
if you really have a jdm wrx then you already have a vf35.....and if you already have one then you already have the proper injectors for it
WTB : sti injectors or any injectors to support vf39 subilife SCIC Private Classifieds 1 08-10-2011 05:25 PM
What else do I need for my Stage 2 upgrade? dauss AccessPort 12 12-07-2007 08:32 PM
Proper injectors to support 18G? BadTrip Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 11-05-2004 02:37 PM
What do I need with a torque converter upgrade? topgrinder Transmission (AT/MT) & Driveline 4 04-06-2003 01:33 AM
when do I need injectors Hypnotic Perf Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 02-05-2002 01:42 AM
